Canute
Everything posted by Canute
  1. We got into the Space Race in the late 50s. We designed our version of a Mercury capsule and I "volunteered" my sister's doll. Had it fitted with a pressure suit (electrician's tape). Planned to launch with an M-80 someone "acquired". Unfortunately, my sister threw a hissy fit and I had to return the astronaut. We launched the "capsule" but it didn't get very high. The 2x4s may have something to do with the poor thrust.
  2. Glen, your masonry work turned out well. Very interesting subject, I'll slide in here to watch the build. Hope the recovery of your S.O. is progressing well.
  3. I read somewhere that the Arados were used as recce birds over the Remagen bridgehead.
  4. Jeff, it looks like it'll fall down in a strong wind. That shed is beat. Well done.
  5. She looks fast. The Italians built some good looking aircraft. Best of luck for this build.
  6. Rob, I have an old source book on the Luftwaffe and may be able to dig up some codes. Then again, I don't think these jets actually flew combat missions, so the codes would be speculative.
  7. Superb work with all the details and "clutter". Very well done. Jack's video steer is spot on. Just make sure you have no openings where you pour or you'll end up repouring the water. Don't ask how I learned that.
  8. Wow, what an improvement, Craig. The metal spokes will look great. Are you going to use metallic paints for the new chrome?
  9. I'm in, Eric. Be interesting to see your plans, since there apparently was a similar boat out here in western NC on the French Broad River, a tributary of the Tennessee. I've only seen 1 picture of that boat, the Mountain Lily,
  10. Thought that went without saying.😉 It is impressive work to date.👍
  11. Nice, tidy installation, Eric. And as Brian said, having a business standing by their order. Can't wait for you to do up and oven fired, thin crust pizza.
  12. Do you have enough material to pin the joint? Clean up the old glue, insert a pin to line the parts up and reglue.
  13. Very well done on your clutter, Grant. Gives a busy "worked in" look.
  14. Having followed several of your recent builds, I'm signing on to observe a master at work.
  15. Great to see you've got your mojo back, OC. Looks like a real tussle coming up.
  16. Very good looking a/c, Craig. She's a beauty. 👍
  17. Magnification and light are the keys. Although some fine tweezers and cutting tools are also helpful. Age and decreasing physical abilities are unfortunate limiters.
  18. Great for gluing PE to plastic and resin or wood to plastic or resin, too.
  19. I use tape when working on alignment issues, but some parts are OK to use clamps. All depends on what the situation requires. And I'm glad to see a model of the Big E here. She was a mainstay for the US Navy. She should have been preserved after the war.
  20. Slog, I have a similar Hakko and really like it. I may need to acquire that particular tip, tho. I really like this solder station; the temp settings are spot on.
