Everything posted by Canute
Looks like the Paasche gives you 3 different tips. Acrylics need the bigger nozzle than enamels and lacquers. The Micro-mark probably has a medium tip, and if you spray acrylics, you'll be cussing the tool. Can you get a larger tip from Micro-Mark?
Eric, it's a sad state of affairs when you get a kit with so many issues. I admire your stick-to-it-tive-ness.
- 113 replies
- Cairo
- BlueJacket Shipcrafters
I remember the cattle ranch around Avon Park Gunnery Range. They roamed at will and once we got a cow running threw the tactics area. The Range Control Officer yelled himself hoarse trying to keep our guys from releasing any ordnance. Unfortunately, the cow took a hit and Uncle Sam bought a cow that was KBA -killed by air..We were pretty bummed by that.
Might try the deck wash RGL/Greg applied to his Heian Maru.
- 113 replies
- Cairo
Nifty little tips for working with the PE. Thanks.
- 23 replies
- Mikasa
- Merit International
Like you're using the tissue paper roofing. I've used that once or twice on cars and structures. The paper used to wrap presents seems to work well for this. Flat black is a light sink for photos. I think a charcoal gray shade would work better. I've used Tamiya German Gray, NATO Black and tire black. They're slightly lighter shades of black
- 113 replies
- Cairo
Rob, I'll follow your build with interest. Like many I built the old Revell box-scale kit way back when. This almost looks like an up-scale of the old Revell kit. With your skills and a box full of aftermarket bits, I think it will turn out OK. Model on!
You can use thin foam pieces, not the strofowm boards with the big white beads, but the sheets used for insulation in some places. Your local big box store may have pieces of broken boards. Rough shape one/two sids and but up against your base in layers, like a cake. Cover with plaster gauze or Sculptamold to cover the ends, Sand to final shape, the paint your ground cover shade. Apply your shrubs and trees. Et voils! Castle Loarre and hilltop site. 😄
Kind of over kill, providing the base and then adding individual clap boards. Unless you're going to lift up selected boards to make a more distressed look to the structure. Much easier with these separate boards, instead of slicing into the base piece to lift up random segments.. I've tried it but is didn't really achieve what I wanted to show. This was is better. 😄
