Everything posted by Canute
Yes, that they are. I enjoy these pre-dreadnaughts. I have too many hobbies going and not enough display space. Keep up the good work.
You've said you are super detailing this pre-dread. You've got the parts and the skills to swap these, so why not, Tim? The brass replacement is definitely finer in detail, but you as the builder are in charge of what version you use.
OC rates that Ultra Glue very good. I've been using Gator Glue to attach PE to plastic and resin. So far, I like it a lot. And water cleanup.
We said the same thing about the F-16 early on. Had some air start problems; the high AOAs (angles of AttacK0 they could generate, cut off the air entering the engine inlet. If the one burning ain't turning, it's a blivet and crashes. Reusing the kit cockpit bucket should ensure the nose area will have minimal fit issues. Watching with great interest, EG.
F-86F-30 Sabre by Javlin - FINISHED - Kinetic - 1/32
Canute replied to Javlin's topic in Non-ship/categorised builds
Kit fitting is excellent. Your work fitting the "Office" is, also. -
You've turned out a beauty, Yves. Well done. 👍
- 321 replies
- Finished
- Flower-class
Nice and steady. You'll do fine. Like Yves said, we enjoy watching builds of ships from this era, too.
Best of luck with the eye doctor. It's definitely no fun when the peepers are malfunctioning. I had a long wait for cataract surgery last year. Really got out of sorts with the wait. At least you have an avenue for some work.
- 505 replies
- vanguard models
- Sphinx
Yep, still following this classic jet build. -
Looking for a good "starter" pin vise set
Canute replied to Capella's topic in Modeling tools and Workshop Equipment
Well, you could use an Omega, like I did when I flew. 😁 -
A-26B Invader by Javlin - ICM - 1/48 - PLASTIC - MTO 1945
It does look good. Silver is never easy. -
US camouflage markings are the Ghost Gray stars on the far right. The color markings are for uncamouflaged aircraft, like trainers and some transports. Although, they appear out of register. The red stripe should be centered in the white bar.
