jgilchrist800
Everything posted by jgilchrist800
  1. Alfred A/Deltaville, VA: Send me your address and I'll send the material to you. All I ask is an acknowledgement of receipt so I can claim a donation for tax purposes.
    Thanks.
  2. Jaeger: Many many thanks to your extensive responses to my inquiries. Much appreciated!!
  3. I'm struggling to determine the size of these 4 main frames for the wet well in the Emma C Berry. If anyone can help I would be most appreciative!
  4. Andrew, or someone else: I'm struggling with determining the size of the 4 wet well main frames, as seen below in Andrew's log. I sincerely appreciate anybody's help: Thanks for your help.
  5. Anybody know where I can obtain figures, Bogart and Hepburn, for the Billings African Queen? I believe it's 1:12. Thanks. John Gilchrist
  6. Copied all your pictures and texts. Great job! My next project...
  7. I also have a copy with my 1/2 finished kit. Advise if needed. Thanks. John
  8. What is the website address? Thanks.
  9. Nice work! Finished mine some time ago, first model I did without a practicum or build log and found it quite easy for the most part. Enjoy!
  10. Very nice work. Can't wait until I start my kit, after finish the USS Conny, not in it's 7th year! Maybe 6 months more and than I can start.
  11. Not sure where I put this discussion. Please move if needed I purchased MS 2020 Mayflower at 1:76 scale = 5/32" = .1563" = 3.969 mm I purchased Bob Hunt's Mayflower practicum, without paying attention, which is for the Artesania Latina model, at 1:64 scale = 3/16" = .1875" = .4.763 mm Comparing the two .1563/.1875 = .8336 If Bob says cut 5" do I cut 5"x.8336 = 4.168"? Likewise if he says use 1/4" square board do I use 1/4" x .8336 = .2084"? Using mm may be more precise but the question remains the same. I know I should consult the plans first but if there is not a clear picture can I make the modifications as outlined above? Or maybe I'm simplifying the calculations too much and the approach should be entirely different? I'm obviously not a mathematician! Thanks for your help. John
  12. Nice work! Much better than mine! Like you and others I'm also on my decade long quest to finish up this model, in fact I'm almost finished with the rigging. Maybe 6 more months! We do have patience!!!
  13. I seem to have conflicting plans, or I am misunderstanding the belaying plans, compared to the instructions from the Model Shipway drawings. Drawing 8 calls for the truss to be belayed to the cleat on top of the upper crosstree, as detailed under "lower truss details". Bob Hunt's practicum says that the truss is belayed to a cleat installed on the cross tree. The Belaying Plan, which is printed on drawing 6, calls for the trusses to be belayed to pins 44 and 45 described as "Fore Truss Pendant Tackle", similar instructions are for the main and the mizzen masks. Lennarth Petersson, although a different outline for running through the yards, shows the truss eventually being belayed to the deck as well. So do I belay to the upper cross tree or do I belay to the deck? Many thanks for your help. This forum is a godsend for us amateurs! Thanks. John Gilchrist Rosenberg, TX
  14. Thanks. I have used some message stickers in the past but they would always seem to slip out of the loop. I'll give it another try with newer stickers. I'm also going to order some of the plastic sewing clips. I've used the small wooden clips but they didn't seem to hold the whole loop together as the clamping space was too small. Thanks all for your help!!! John Gilchrist Rosenberg, TX
  15. Thanks Tom. Do the Post-It pads hold up the loop. Since there is no tape on the loop doesn't the rigging have a tendency of slipping out? Thanks. John Gilchrist Rosenberg, TX
  16. In my build of the Conny I prebuilt the masts and hung the various lines, taped together in loops until I installed on the ship. Now as I take the tapes off I'm finding little pieces of glue which are sticking the lines! Major mess! Any suggestions as to a better way to store the lines until they're used? Thanks. John Gilchrist Rosenberg, TX
  17. Painted tends to cover up all the mistakes made by us truly amateur model ship builders! John Gilchrist Rosenberg, TX
  18. Is this what you're looking for? See attached rigging layout for the MS model. MS Const Rigging Plan.docx
  19. Thanks Bill good comments.
