ccoyle
Moderators
Everything posted by ccoyle
  1. Congratulations -- she looks great!
  2. Welcome aboard! Sounds like you got your hands on a Shipyard kit. We have a small group of enthusiastic card modelers lurking about here. I built Shipyard's Wuetender Hund wood kit a couple of years ago.
  3. I'm not pickin' up what yer layin' down. The right-hand drawing makes the frame appear to be bent, or curved, which is impossible to do with the 3 mm thick pieces.
  4. Okay, hit my first big snag already! This instruction basically says "build the cant frames." Sounds easy enough. Except I can't for the life of me figure out how to interpret the 1:1 scale drawings for the cant frames. The image on the left I was able to solve, as it simply shows the overlapping frame pieces (four in total). It's the drawing on the right that I can't figure out. As you can see in the image that comes later in the construction manual, the cant frames need beveling (duh), but they don't appear to be bent in any way -- seen from the side, they appear to be straight up-and-down. So what am I reading wrong in the drawing?? 🤔
  5. Looks-wise, they both look good, but off the top of my head i can't tell you which one would be a better choice for your subject.
  6. Okay, so here are the parts for the keel. In the center are the two bits of scrap that I test glued and let dry over night. I couldn't get them apart with finger pressure, not even while twisting them, so the char does not appear to be a problem for gluing. Here's a close-up showing a laser-cut edge. Like I said earlier, the char is medium-brown in color, not black, and personally I kind of like the bit of contrast. But what do you think? Fly's name plate arrived in the mail today, but I will wait until the "big reveal" to show what it looks like with the model.
  7. As a kid, I built Revell's 1/72 scale version of Goering's mount.
  8. Hi, BG. Check out the work of Bob Wilson (click here for website). He offers quite a few downloadable how-to files. Cheers!
  9. Hi, gang. So, while I'm still waiting for some materials to finish up USS England, I've decided to start up a new project. This is the 1/70 scale Hannah kit from Ship Model Okumoto. I won't do an unboxing here, since James Hatch already wrote up an excellent review of this kit, which you can read here. Mr. Okumoto's kits are basically POF, but without the 'P' part -- just the framing. I may decide to add some planking later to make Hannah more of a conventional POF model. As you will note in James' review, the instructions for this kit are entirely in Japanese -- I am only able to begin work on it now because I was recently forced to replace my dying cell phone with a new one that includes Google Lens, which has a built-in translation capability. I can attest that Lens does a more than adequate job of translating the kanji characters. As James also noted, the laser cutting on this kit is very good, but, interestingly, there are no laser-engraved numbers on the parts. The instructions say that the first step is to write the numbers on the parts in pencil, using the kit's printed part sheet templates as guides. Not knowing in advance how much of those numbers will eventually remain visible, if any, I have gone ahead and written them adjacent to the parts, just to be safe. James mentioned removing the char, but I intend to do a test bond on some pieces of scrap to see whether it is really needed. What little char remains on the parts is not loose or sooty, and its medium brown color actually pairs well with the tone of the wood used in the kit. If I can get away without having to do all of the scraping and sanding, it will save a huge amount of work. We'll see how it goes. Cheers!
  10. Yikes! My short-term memory isn't what it used to be -- but your model proves the point I was making! Cheers!
  11. She'll go back in the bookcase with glass doors.
  12. Welcome board, Charlie!
  13. Nevertheless, it is to these same cruel taskmasters that we must ultimately answer. 😉
  14. More progress. The Swan-class sloops had a very small number of belaying pins, located in racks along the quarterdeck railings. As usual, these off-the-shelf pins benefit from being chucked in the ol' Dremel and being turned down a bit. And the hammock cranes are done as well. No netting -- sorry. Just don't feel up to the additional effort. The black line is also a little on the thin side, but I didn't have anything on hand that looked 'just right', and all the other available cordage was too thick. Believe it or not, there is not much else to do. I'm planning to replace the kit swivel guns with parts from Vanguard Models once they are back in stock, and I also plan to add one or two of the anchors to the display. I also ordered a brass name badge -- she deserves at least that much. So, once all those things are in place, I will report back, but that's pretty much it for now.
  15. I'd be inclined to believe that they would modify captured vessels to configurations they were familiar with.
  16. Yes, those came in the upgrade kit. But if I were to do this one again, I would do the upgrading differently. The guns in the kit are Amati off-the-shelf parts and not period correct; you can order replacement gun sets (including carriages) from Chris at Vanguard, although he does not currently offer 6 pdr guns -- only the carriages. I would also use one of Vanguard's or Master Korabel's wooden boat kits to replace the cast metal boat. None of those aforementioned items was yet available back when I started in on this project. Thanks. Well, the deck is, for the most part, but you'll notice I haven't included close-ups of some parts of the hull, which is the primary source of my dissatisfaction. Lessons learned!
  17. I'd follow the plans. It looks a little odd, but marine engineers often come up with different solutions for the same problem. It will make a nice conversation starter when viewers ask why that piece appears to be crooked -- kind of like the canted engines that some aeronautical engineers opted to use to offset yaw in their designs.
