ccoyle
Moderators
Everything posted by ccoyle
  1. The small size of the model and its unusual manner of construction will make such removal difficult, if not impossible. That's part of the dilemma. Mind you, this is interior fairing I'm wondering about. One of the reasons I asked whether just leaving it as-is would be a viable option is that there isn't an 'interior' to this model -- other than the interior sides of the frames, there isn't much of anything else. Like I said, it's stylized, so I'm inclined to believe that leaving the insides un-faired would be a forgivable sin.
  2. I haven't got back to working on Hannah yet, but I thought I'd post some pics of what I'm trying to wrap my brain around regarding the construction of the frames. As I said earlier, the available YouTube videos do not give any hints on what to do here, and neither do the instructions. So, this is frame #5. As you can see, there is not a whole lot of overlap between the forward futtocks and aft futtocks. Frame seen from forward: Frame seen from aft: Frame seen from above: The question again is one of how much interior wood to remove, if any. It's possible that I may have to remove the deck beams to do this properly -- again, there was no advice about this in the instructions (BTW, only a couple of frames have deck beams glued to both sides). I suppose one option (and the easiest) would be to just not remove any interior wood; after all, this is a stylized POF model. Thanks for any and all suggestions on what to do at this point. Having never built a POF model before, I have zero experience with this type of construction and precious few print resources to guide me. Cheers! P.S. Looking down the road, there is also precious little guidance in the instructions and videos on how to keep the keel and frames aligned when it comes time to glue them together. I suspect I may need to make a cheap building board for that sequence, but that's a ways off yet.
  3. Welcome, Sam! I grew up near Eureka, another port with a significant crabbing fleet. Here in South Carolina, we obviously aren't getting any fresh-caught Dungeness. 😥
  4. Check with Model Expo. They are the current manufacturers of the Midwest line.
  5. That's a treat to see the real thing in person! P.S. When copying and pasting text, look for the 'paste as plain text' option -- that eliminates the tan shading.
  6. Welcome aboard!
  7. First suggestion: Make the title of your post something other than "oops" -- you'll be far more likely to get an answer to your question. I fixed this one for you -- no charge! 😉
  8. You should be able to scratch-build the missing hatch elements out of sheet styrene without too much difficulty. The winch might be a little more difficult. 😬
  9. Hi, gang! I just happened to be looking at the tags attached in a build log here. The log features a Model Shipways kit, and as you probably know, there are hundreds of Model Shipways kits featured in build logs at MSW. But . . . This particular log featured a tag that said Model Shipway, not Model Shipways. See the difference? The correct spelling is Shipways (plural). You might think that this doesn't make much of a difference, but it does. A tag search only turns up hits that exactly match the spelling in the tag that is clicked. If a curious member clicked on the "Model Shipway" tag today, the search would yield only seven results. On the other hand, clicking a "Model Shipways" tag yields 716 results -- over one hundred times as many! So please, when you add a tag, make sure it is spelled correctly. I fix the misspelled ones when I find them, but I don't always find them! Cheers!
  10. JSC, Schreiber-Bogen, and HMV are the publishers that come immediately to my mind when thinking of ocean liner kits.
  11. Excellent. I have marked this as 'sold', even though your kits weren't, you know, sold sold. 😉
  12. I'm a big fan of MK's planking philosophy. Spiling is wonderful for those who enjoy it, but I'm not one of those people, so I appreciate pre-spiled planking.
  13. They're not hard to find if you Google "Russian brig Mercury." Her captain's actions lend credence to the adage about fortune favoring the bold.
  14. Welcome! Mercury is a great kit, if not often the subject of build logs.
  15. Given the age of that kit and its Italian origins, I doubt that it came with very extensive instructions.
  16. Hi, Grant. I checked your photo bin. There's 13 images in there with unique file names and 13 in the post, so it looks like nothing is technically amiss.
  17. Allow me to be the first to congratulate you on a job well done!
  18. It's only been a month -- you're gonna have to stay away for much, much longer if you want to join the ranks of the truly great procrastinators in our hobby! 😉
  19. I took the liberty of changing your build log title to Pegasus based on the assumption that you will build this Swan-class vessel as the subject depicted by the kit -- unless, of course, you plan to actually build the model as Swan, in which case you will need to make some cosmetic changes. Let me know if I need to fix anything!
  20. Not sure what the issue could have been, but I have moved it for you. Good luck on your project!
  21. I believe you have succeeded! Thanks for sharing this great resource with our community!
