Everything posted by ccoyle
Is a waterline marker useful?
ccoyle replied to CharlieZardoz's topic in Modeling tools and Workshop Equipment
A waterline marker of some kind is pretty essential for marking waterlines. I have the Amati version, and it does the job well enough. But if you are the enterprising sort, you can make your own, which is what I did for my first couple of models. I got the Amati version because my home-builts weren't very durable. -
For tools advice, click here. Have a look at the other resources available while you're there. Be sure to open a build log when you start your model -- that's the best way to get advice and encouragement. Good luck with your project!
Hello, Jase. The Dandy II is a kit once manufactured by the long-since defunct Dikar company. Billing Boats, Soclaine, and Artesania Latina all still make kits of the same type of vessel. The AL kit can be had new for well under US $100. Given the age of your kit and the availability of newer, inexpensive kits, you might be looking at around US $50 for yours. If you wish to have a crack at selling it, you can post it in the Traders & Dealers section after reading the seller's guidelines. Cheers,
Also have a look at Bluejacket for more merchant/historic sailing vessels.
Any of those ships you list is going to be a challenge to finish within a year. As for Caldercraft instructions, the comment about "as good as you can get" certainly does not apply to their early kit offerings. They only started producing detailed instructions on later kits, and the only large model from that period is HMS Victory; even with that one I'm not sure about the instructions. Hope you find what you're looking for!
Please do not post any links to suspect companies in the forum. We don't want to give these guys any extra face time. If you have doubts about a company, send a PM to any of the moderating staff first, and we'll check it out. Unfortunately, if it's a Chinese firm, the odds are high it will be pirated goods.
A question about Lady Nelson by Amati
ccoyle replied to CharlieZardoz's topic in Wood ship model kits
The similarity to Sherbourne is not purely coincidental. Both kits were designed by Chris Watton. -
Use the MSW search function to search for HMS Surprise -- you will find build logs for both the Mamoli and AL versions. See which one you like better. Cheers,
Unfortunately, it's not uncommon for some manufacturers to describe a kit as POF when it is actually POB, as is the case with the Mantua Astrolabe kit. Like Russ, I don't know of any POF kits for merchantmen other than Alvin Clark. Kit designers will tell you there just isn't enough demand for such a kit, although it would certainly be a welcome choice for kit builders.
The term formers includes both the longitudinal profile piece, sometimes referred to as a false keel, an the transverse bulkheads. The kit you are describing is not a POF kit, but rather a plank-on-bulkhead kit. POF mimics actual ship construction; POB uses a smaller number of pieces to get the hull shape and is the method most often used in kits. If POB is indeed what you are looking for, then that opens up more possibilities for you.
The Lumberyard (dlumberyard.com) used to have a POF kit of a Great Lakes schooner, the Alvin Clark, but I no longer see it listed at their site. Try contacting the owner, Dave (daves here at MSW), to see if he has any left.
Neat trick on the cowls! The whole thing is looking fabulous. Cheers!
- 116 replies
- kilkis
- mississippi
I haven't been at the cardfaq page in years, but at that time it had a lot of dead links. I wonder if that is still the case?
