ccoyle
Moderators
Everything posted by ccoyle
  1. The contrasting wood colors are the hallmark of kits made in Spain. Constructo made a kit for PdN at one time. We have a build log for that kit here.
  2. Very nice! Though I can see where the endlessly repeating engine start-up loop might do this to a person:
  3. Whew! For the price, it should be able to power a real aircraft! Looks like it will be a hoot to build.
  4. At one time I thought I had some ancestors from Pomerania. All I knew at first is that they were from 'Pommern', so it was a natural assumption to make. I later learned that they were from the other Pommern -- the village in Rhineland-Palatinate. A big difference!
  5. The bridge has been added. The kit includes optional parts for the bridge interior. I decided not to add these, because that would require cutting out the many printed bridge windows and then glazing them. It's a difficult task to do neatly, nearly impossible actually, and the finished interior would be difficult to see -- just not worth the extra effort IMO.
  6. Welcome aboard!
  7. Work on these small models progresses pretty quickly. Next we have the hull plating. I'm not completely satisfied with my work on this part, but as you'll see shortly there's a way to deal with this -- kind of. P.S. While I was trying to get the port-side plating on, the model popped off its glass plate, which actually made the job easier, thankfully. Next we start attaching the laser-cut railings. These add a substantial amount of 'wow' factor to the model and help draw attention away from less expertly done parts of the model. Moving forward, we install the inner bulwarks, stanchions, foredeck railings, and caprails. That's all for now!
  8. Yes, it certainly does! Your 3D printed upgrades should spruce up the basic kit nicely.
  9. Step 2 in the build sequence is complete, consisting of the amidships main deck structures.
  10. Welcome aboard! Your models look great!
  11. And here is the completed internal framing. For anyone unfamiliar with the process, the hull base plate is temporarily glued to a piece of glass to keep the hull flat during construction -- just a small spot of glue at the bow and stern. This is typical "egg crate" construction, but this newer design has two additional longitudinal frames (older kits typically only have the center-line frame), which should greatly aid in construction. To provide additional strength, I soaked all of the frames in thin CA -- before adding them to the base plate, obviously, otherwise the hull and glass plate would be mated for eternity.
  12. Welcome aboard, Jim, from South Carolina, where the big question is never "When will the first big snow arrive?" but rather "Will there be any snow at all this winter?"
  13. Well, thank you! Ironically, my actual-and-not-figurative top shelf is still empty at this point. 😅
  14. Did you think I was going to take a break after finishing my Bf 109 last night? Ha! That is where you'd be wrong! Of course, you are also wrong if you thought I might be going back to work on Phoenix. The reason I'm not is because I only have a month before I'm taking a long-ish Christmas break, during which there will be no modeling. 😒 So I've decided to tackle a small project that I think I may be able to finish within four weeks. That project is the Norwegian excursion steamer DS Børøysund, currently home-ported in Oslo. She began life in 1908 as the Odin. She went through a number of owners over the years, all of whom it seems didn't care for whatever the ship's previous name was, so they changed it. She became the Børøysund after being acquired by the Norwegian Veteran Ships Club in 1968. Børøysund is 33.1 m long with a beam of 5.5 m. Her triple expansion steam powerplant can whisk 100 passengers along at a breathtaking 9 knots. At 1/250 scale, the model consists of only two pages of parts and when completed will be a shade over five inches in length. I also have the laser-cut detail set. Look for first cuts soon!
  15. Thanks, Paul! That filter is called a vignette -- just one of the filters available on my phone's camera.
  16. The Big Reveal! And so, just two days shy of two months from beginning to end, we reach the end of this journey. As is usual with Halinski kits, which have sometimes been described as 'over engineered', this model was quite a challenge to build and thus very rewarding to finish. It is not a kit for the faint of heart or neophyte card modeler, but its degree of detail and realistic artwork are matched by few other publishers in the hobby. On to the pictures! Thanks for stopping in, and I'll catch y'all on the next one!
  17. Between last night and today we finished off the drop tank pylon, gun sight, canopy, armored headrest, antenna, aerials, wing cannons, aileron balance horns, and pitot tube. And with that, she's all done. And that's all you get to see for now, because it's way too late here to be taking more pictures!
  18. Here is the finished gun sight. Yes, there was certainly some eye strain involved. I'm down to only 18 parts left to add to the model, so the next post (whenever that is) will be the Big Reveal.
