Everything posted by ccoyle
Welcome aboard!
Ah -- the sort of vessel "Lucky" Jack Aubrey would have been snapping up during his time in command of Sophie.
- 55 replies
- Le Martegaou
- billing boats
One of the problematic parts of the assembly process on the E-4 was definitely the wing, so that's something I wanted to 'get right' on this build. First step was to add the central ventral skin ('central ventral' -- catchy) and wheel wells. The wheel wells on this kit are really rather simple and posed no problems at all. The sort of 'antennae' looking bits are fairings/joiners that will wrap around the wing root and blend into the fuselage. Now this is a shot from the E-4 build. The part I've circled was supposed to have been folded upward to be the trailing edge of the wing, but that wasn't clear to me from either the instructions or diagrams, so I left it un-folded. 😬 Fortunately, it's on the bottom of the wing, so very rarely does anyone see it. Here's the properly done E-7. And here's the dorsal side of the wing, with tips yet to be added. You can see how one of the 'antennae' bits has been wrapped and mated to the wing skin. Now, you may have noticed that the wing skin consists almost entirely of a single skin. For anyone wanting to try a model like this, I've found it to be much easier and neater to not attempt to glue the skin on all in one go. Instead, I work in sections, starting at the wing root and working toward the tip, using the various bits of framing to align everything properly (I should mention that I gave the entire wing frame a light sanding before starting this process). You can see in the photos that everything has come together very well at the various junctures, e.g., wheel wells, radiator wells, skin edges and frames, seam between dorsal and ventral skins. This is a testament to the excellent design. There will be a less-glowing testament once the wing gets mated to the fuselage, but I'll save that for when we get there!
Great finish! Congratulations!
- 28 replies
- Lowell Grand Banks Dory
- Shipwright Series
(and 3 more)
Yes, it is not cheap, but the construction method is different. Vanguard kits have a lot of laser-cut parts, but in the Shipyard kits, everything is laser-cut. As a result, there is almost no sanding to be done, other than smoothing the spots that hold parts in their frets. This also means there is no plank spiling to do. This makes Shipyard kits appealing to modelers who may not be able to deal with wood dust for whatever reason. So it's not really a direct competitor to Vanguard in the sense of being a choice between two POB kits -- it's more of a choice between two similar but substantially different construction methods.
Great paint job! It does, though, kind of hide just how many pieces of PE you had to apply to the superstructure. I admire the skill and patience of anyone who can work with that stuff successfully.
- 97 replies
- Enterprise
- Tamiya
Congratulations! I think that's a very handsome display.
- 82 replies
- half hull planking project
- half hull
SPAD XIII c1 by modeller_masa - Roden - 1/32 - PLASTIC
ccoyle replied to modeller_masa's topic in Completed non-ship models
Looks great! -
I like them, so far. As I mentioned earlier, they're not exact matches in every instance. Some are better matches than others. The tan is pretty spot-on for the color printed on the model. The olive drab doesn't match the printed color very well, but as an edge color it hides seams decently. Very easy to use, of course.
Build log titles
ccoyle replied to Jim M's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
The naming instructions are also pinned at the top of every build log category. For finished models, the word FINISHED in all-caps should be added immediately following the user name and set off by hyphens, e.g.: HMS Phlegmatic 1762 by jenny8675309 - FINISHED - Middling Models - 1:50 You can also add 'Finished' as a tag. -
I just learned today that Shipyard has released a new offering in their series of wooden kits (it's so new, in fact, that it's not yet even available for purchase in Shipyard's online shop). The new kit is the English revenue cutter Rattlesnake 1777 (the kit says '1776', but I think they got the date wrong). Shipyard have been highly regarded for years for their card model design, but they are relative newcomers to the world of wooden kits. Despite the fact that these kits are constructed of wood, they are designed -- and built -- in much the same manner as one of Shipyard's card kits, using plywood veneers instead of wood planking strips. That makes this type of kit a kind of 'wooden card model', if such a term makes sense. If you want to see what this looks like in actual practice, you can check out my build of Shipyard's Wütender Hund here and gallery images here. The prototype model is quite striking. If you're thinking that it looks rather like HM Cutter Alert 1777, that's because I believe the two ships were in the same class. There are, of course, several very nice kits of Alert already on the market, but this kit gives modelers an option to build something in a manner a little different from the usual POB wooden kits we see. As is usually the case, high quality comes at a cost; in this case, the Shipyard kit will set you back 1546 PLN, or about US$394.11 at today's exchange rate. That'd be eye-watering for a card model, but this is a wooden model -- with all wooden parts laser-cut. I hope we'll see more wooden kit offerings from Shipyard in the not-too-distant future!
