ccoyle
Moderators
Everything posted by ccoyle
  1. This is a normal feeling to experience. I felt the same way after Helene -- my house was untouched, as were most of the others in my neighborhood (young neighborhood = no mature trees to fall down and crush things), but all around us there was devastation everywhere. Glad to hear you are safe!
  2. Okay, the fix turned out to be not nearly as difficult as I anticipated, and the second wing skin is on. I can now dry fit the structure to the fuselage and make airplane noises. 😋 NYEEEEERRRRRROWWWWW!
  3. Haha! Hold that thought! The problem with wings is that there are two of them, providing the modeler with twice as many opportunities to screw something up. I'm working my way through a fit issue on the second wing skin at the moment. Stay tuned!
  4. One of the problematic parts of the assembly process on the E-4 was definitely the wing, so that's something I wanted to 'get right' on this build. First step was to add the central ventral skin ('central ventral' -- catchy) and wheel wells. The wheel wells on this kit are really rather simple and posed no problems at all. The sort of 'antennae' looking bits are fairings/joiners that will wrap around the wing root and blend into the fuselage. Now this is a shot from the E-4 build. The part I've circled was supposed to have been folded upward to be the trailing edge of the wing, but that wasn't clear to me from either the instructions or diagrams, so I left it un-folded. 😬 Fortunately, it's on the bottom of the wing, so very rarely does anyone see it. Here's the properly done E-7. And here's the dorsal side of the wing, with tips yet to be added. You can see how one of the 'antennae' bits has been wrapped and mated to the wing skin. Now, you may have noticed that the wing skin consists almost entirely of a single skin. For anyone wanting to try a model like this, I've found it to be much easier and neater to not attempt to glue the skin on all in one go. Instead, I work in sections, starting at the wing root and working toward the tip, using the various bits of framing to align everything properly (I should mention that I gave the entire wing frame a light sanding before starting this process). You can see in the photos that everything has come together very well at the various junctures, e.g., wheel wells, radiator wells, skin edges and frames, seam between dorsal and ventral skins. This is a testament to the excellent design. There will be a less-glowing testament once the wing gets mated to the fuselage, but I'll save that for when we get there!
  5. Yes, it is not cheap, but the construction method is different. Vanguard kits have a lot of laser-cut parts, but in the Shipyard kits, everything is laser-cut. As a result, there is almost no sanding to be done, other than smoothing the spots that hold parts in their frets. This also means there is no plank spiling to do. This makes Shipyard kits appealing to modelers who may not be able to deal with wood dust for whatever reason. So it's not really a direct competitor to Vanguard in the sense of being a choice between two POB kits -- it's more of a choice between two similar but substantially different construction methods.
  6. Great paint job! It does, though, kind of hide just how many pieces of PE you had to apply to the superstructure. I admire the skill and patience of anyone who can work with that stuff successfully.
  7. Work continues on the empennage. First I completed the rudder actuators. I used the dark aluminum pen from the Real Color markers set for these. Then we have the horizontal stabilizer framing (10 parts per side) and their skins. And the stabilizers added to the growing empennage.
  8. I like them, so far. As I mentioned earlier, they're not exact matches in every instance. Some are better matches than others. The tan is pretty spot-on for the color printed on the model. The olive drab doesn't match the printed color very well, but as an edge color it hides seams decently. Very easy to use, of course.
  9. I got the basic rudder finished and attached to the vertical stabilizer. I say 'basic' because I still need to attach the actuator rods. Just a dry fit for this shot.
  10. The naming instructions are also pinned at the top of every build log category. For finished models, the word FINISHED in all-caps should be added immediately following the user name and set off by hyphens, e.g.: HMS Phlegmatic 1762 by jenny8675309 - FINISHED - Middling Models - 1:50 You can also add 'Finished' as a tag.
  11. I just learned today that Shipyard has released a new offering in their series of wooden kits (it's so new, in fact, that it's not yet even available for purchase in Shipyard's online shop). The new kit is the English revenue cutter Rattlesnake 1777 (the kit says '1776', but I think they got the date wrong). Shipyard have been highly regarded for years for their card model design, but they are relative newcomers to the world of wooden kits. Despite the fact that these kits are constructed of wood, they are designed -- and built -- in much the same manner as one of Shipyard's card kits, using plywood veneers instead of wood planking strips. That makes this type of kit a kind of 'wooden card model', if such a term makes sense. If you want to see what this looks like in actual practice, you can check out my build of Shipyard's Wütender Hund here and gallery images here. The prototype model is quite striking. If you're thinking that it looks rather like HM Cutter Alert 1777, that's because I believe the two ships were in the same class. There are, of course, several very nice kits of Alert already on the market, but this kit gives modelers an option to build something in a manner a little different from the usual POB wooden kits we see. As is usually the case, high quality comes at a cost; in this case, the Shipyard kit will set you back 1546 PLN, or about US$394.11 at today's exchange rate. That'd be eye-watering for a card model, but this is a wooden model -- with all wooden parts laser-cut. I hope we'll see more wooden kit offerings from Shipyard in the not-too-distant future!
  12. I used to only build in 1/72 scale when I was a kid, but between my aging eyes, being accustomed to working in 1/33 scale for nearly two decades now, and seeing your hand in the picture for scale, my first thought was, "Dang, that's little!"
  13. Normally I only do edge coloring. The quality of the graphic artwork varies widely among kits, from no weathering at all to photo-realistic artwork. Some designers color their own models, while other employ the talents of graphic artists. The team of Andrzej Halinski (designer) and Marcin Dworzecki (artist) is one well-known example. Some of the best artwork I have seen is done by Luis P. Igualada, whose models are available as downloads from ecardmodels.com. I have learned a few interesting tidbits about the 109 during the course of this project. If you zoom in on my last photo in post #28, you can see that each of the two parts of the stabilizer fairing has three small, red tic marks. Those marks are tail plane incidence indicators. The 109 had a variable incidence tail plane, which obviated the need for elevator trim tabs. Those Golden Age aeronautical engineers were extremely clever fellows!
