russ
Members-
Everything posted by russ
Sometimes that happens. Analyze and retry. Russ
- 449 replies
- sultana
- model shipways
Whilst waiting for some supplies to arrive, I got to work on the pilot house. The house sits on a raised base and that was the first order of business. Here is how I made the base. I made it this way to be able to more easily and in the round up of the bulkhead frame tops into the bottom of the base. Russ
- 420 replies
- captain roy
- lugger
Lawrence: Thanks for the kind words. I also find the lines of these boats very appealing, especially up forward. The planking should be fun. Russ
- 420 replies
- captain roy
- lugger
That looks good. Different challenges require different solutions. I spend a good deal of time just thinking about how to get a particular piece made. The first pass is rarely the last, but it is fun and it keeps the mind active. Good work. Russ
- 449 replies
- sultana
- model shipways
Beautifully done. Love the rigging details. Congratulations on a really nice model. Russ
- 165 replies
- cape cod catboat
- Finished
The volutes you came up with look pretty good. Nice work. Russ
- 449 replies
- sultana
- model shipways
She looks great. I would not have known about the topmast shroud had you not said anything. Russ
- 745 replies
- francis pritt
- mission ship
The rigging looks good so far. The deadeye strap issue is a problem. The CA will hold it, but getting it to look neat is a different problem. Soldering is a good way to keep that from happening. Russ
- 250 replies
- willie l bennett
- model shipways
I agree that the fourth rail is a bad idea. When you look at these rails from the side, there should be a graceful sweep towards the stem head. That is what you are looking for. Russ
- 144 replies
- surprise
- artesania latina
Yes, the top rail should sweep upward more at the bow. Russ
- 144 replies
- surprise
- artesania latina
Your model is coming along really well. Nice work. One thing you might want to look at. Look at the top headrail from the side. It seems to me that the headrail should curve upward a bit more than it does. The curves from the top view look good. However, check the view from the side and make sure you have the proper curves there as well. Russ
- 144 replies
- surprise
- artesania latina
SS Mariefred by captainbob - 1:96
russ replied to captainbob's topic in - Build logs for subjects built 1901 - Present Day
Bob: This looks like a very interesting subject. It is great that you actually found the plans for it. I am guessing that there are many photos of it. Was it wood built or steel? Will you model it at a particular point in its career? Russ -
Michael: Thanks. The sheer line is an important design feature of these luggers. If it is not correct, it will show. Russ
- 420 replies
- captain roy
- lugger
Well, I have done it now. No guts, no glory. The bulkhead frames are glued in. No turning back now. Russ
- 420 replies
- captain roy
- lugger
It is your model so do what you think looks best. The grain is attractive. Russ
- 449 replies
- sultana
- model shipways
Pat: Thanks. I am very pleased with the shape thus far. Russ
- 420 replies
- captain roy
- lugger
Kees: Thanks. I also think she has nice lines. The upright stem is an attractive feature on these boats. Russ
- 420 replies
- captain roy
- lugger
I recall using diluted white Elmer's glue on rigging line way back when. I use beeswax these days. You can get a cake of it at a local sewing or crafts store. Un the line along the edge of the beeswax and then run the line over a hot light bulb to melt it into the line. Russ
Here we have the framing almost complete. The knightheads will go in next. Once the framing is complete, I will spend some time fairing the hull. That process will take several days to make sure I have a good fair surface for planking. Once that is complete, I can begin lining off the hull for planking. Russ
- 420 replies
- captain roy
- lugger
Ken: The spanker rigging looks good. The brailed sail has a nice effect. Russ
- 481 replies
- rattlesnake
- model shipways
