jim Landis
About jim Landis
2,220 profile views
  1. I think HIS Models (one of our sponsors - see right sidebar) has decals for this.
  2. You might want to consider paper mache, using newsprint paper as well. It sounds like you will need more than one ream of copy paper for that area...
  3. Vanguard has 1:00 officer figures in resin that are very nice, including Nelson.
  4. Got it, thanks!
  5. You might look for how chess/checker boards are made in the wood working magazines. However, I think that the diamond pattern may have been a painted canvas rug in many cases...
  6. The new Heller Victory instructions are listed on the Heller site, but I haven't found a retail vendor that has them yet. HISModels (http://www.radekshipmodels.cz/en/) is going to order them soon...
  7. Rockler, Woodcraft and Micromark all have small triangle setup tools.
  8. Many of the decorations for the Victory at 1:98 are available from Model Shapeways: https://www.shapeways.com/marketplace/miniatures/ships?tag=hms+victory
  9. This is a great idea, I've been having the same problem mounting Dafi's resin steps...
  10. Rubbing alcohol is iso-propyl alcohol and you need ethanol...
  11. I was just able to get some miter gears from McMaster Carr purchased and delivered to my homemusing my personal credit card. No business account was needed...
  12. If you are building a static non-working model, you might want to look at Plastruct tubing and fittings: https://plastruct.com/
  13. I use foamcore as a sheath for knives with mounted blades that are out on the bench.
  14. I got a sleeve of plastic 25 ml sauce tubs at a local restaurant supply store for this application, styrofoam plates also work well as palates for water based paints.
