Everything posted by KeithAug
Nils, Druxey, Chris, Keith, Michael, Dan, Eberhard, Brian, Richard, Pat, Tom, Valeriy, Andy. Thank you all for your generous comments they are much appreciated.
Eberhard / Tom. Yes it is complicated - the gaff is huge so I suspect they need the mechanical advantage. They aren't very consistent on how they rig the peak halyard. Sometimes the top bock is the double and sometimes the double is the middle block.
Druxey / Chris - I'm not that clever. The string is shiny and I think the reflection is giving the impression.
Ras - In a few years time camera bearing nanobots will be crawling all over her, stick with the hidden detail it will soon be visible.
Onwards and upwards -------- it is time to start hoisting the mainsail. I have 5 sails prepared with only the two topsails to do. Here are 4 of them, I'm not sure why I didn't photo the 5, I blame the onset of senility. Because of the size of the mainsail it took a bit of working out how to support it while I did the rigging. What I really needed was that elusive 3rd arm. You would thunk that by now evolution would have sorted the problem. Here is the start of the hoisting process. One of the gaff bridles is attached temporarily to the mast head with a bit of string. With this improvised support the throat halyard was rigged. The next step was to rig the peak halyard. The building frame proved very useful for temporarily holding the halyard tails. Next I went on to rigging the mast hoops using the "Leacher" method. I improvised the knotting of the free ends. My decision to delay the installation of the main and fore mast shrouds proved to be very beneficial for access. It took a while but eventually all the hoops were attached. My knotting of the ends isn't very apparent so hopefully no one will notice my creativity! Then I took a few shots to celebrate.
Thank you Keith. Now I just need someone to interpret the diagram. It's a bit of a knotty problem.
A little puzzle? It won't be long before I raise the main and fore sails so I was looking ahead at the lacing of the hoops to the sails. The Gaff Rig Handbook by Leacher sows this:- But I ask myself ----- what happens to the loose ends?
Hi Michael Sorry but I missed the post about your hand problem. I hope you got the surgery and are now on the mend?
- 2,207 replies
Thank you Eberhard and Keith. I have been getting on with the sails. I needed to cut the clew holes and cutting through the rip stop was proving difficult so I made a cutter out of a piece of silver steel that was then hardened. The inner surface of the cutter was formed with a small centre drill and the outer profile was turned on the lathe - leaving a sharp edge. The holes were punched and small eyelets were pushed through the holes and backed by small brass washers that were glued in place. I then went on to attach the sliders on to the foot of the sail. This done the loose ends were tidied up. With this complete the gaff was laced on to the head of the sail.
Hi Keith - she was searching a wide area to the south west of London as far south as the west coast, but in the end she bought a house about 6 miles away from my wife and I in West Sussex. Brian I haven't taken one recently but I should be getting some of the sails hoisted over the next few weeks. I will make a point of taking an overall shot and posting it soon. Keith, Brian, Pat, Richard, Eberhard, Nils, Gary and Dan. Once again thank you for your continuing support and comments, i do appreciate the time and effort you take in following along. Also thanks to everyone who has visited and or liked my work. I am now in a phase of sail making. I started this in the last post but didn't provide much detail so I will correct this here. I sketched out the foresail on paper and then repeated the process of tracing the seams and reinforcing details on to the PVA impregnated cloth. I then cut wedge shaped templates for the reinforcing from plasti-card. These were then used to cut out reinforcing from rip stop tape. I also used templates to cut out the batten pockets. The batten's were cut from hard brass wire and this was attached to the adhesive side of the rip stop tape. The tape and batten's were then attached to the sail. The reinforcing wedges (made earlier) were then applied. I always think sails with wavy leaches look bad, and even if the sails can't be made taught across their surface they look better with straight or continuously curved leach. It would have been preferable to have the sails modelled as though they were full of wind but getting the curvature set into the sail (given their size) isn't something I know how to do. Because the luff is supported along its length by the mast rings and is tight between the goose neck and the gaff saddle I dint need to worry much about it being straight. I did however reinforce the luff by setting into it a (0.031" diameter) length of braided wire. This was stretched along the luff before being bound in place using rip stop tape. The head and foot were done in the same way as they are also constrained to be straight by lacing them on to the boom and the gaff respectively. The leach was done slightly differently by attaching a length of (0.031" diameter) stiff brass wire alone the edge. The reinforcing around the reefing points and the ends of the batten's was then attached thus completing the sail (except for the clews). I then moved on to the jib sails following a similar strategy, however both the leach and foot was reinforced by stiff brass wire while the luff was reinforced by the braided wire. I have done 5 of the sails, the main and fore sails, and the 3 jib sails. I have left the topsails to be tuned for size once the main and foresails have been fitted. I don't suppose I have pleased many of you purists by my sail making approach but I am going for looks over authenticity.
It is remarkable how quickly you work Nils particularly given the detail and quality you achieve. Excellent job and i look forward to the next one. Keith
- 180 replies
- pilot boat
- Elbe 5
(and 3 more)
Beautiful detail Keith - creating the rigging detail must be a real challenge and you are doing so well.
