Posts posted by vossy
On 3/18/2025 at 4:49 AM, James H said:
If you are thinking go getting this kit, I just added the product to the Vanguard Models website for when the product is near.
I'm sure Chris could tell you a little more about ETA.
Is this on the Vanguard Models site yet? I couldn't find it?
Chris
On 3/18/2025 at 4:49 AM, James H said: -
2 hours ago, James H said:
As far as I'm aware, it's only the oars which will change as these were originally being designed for the Nef kit.
James, Pavel did say that the kit is a bit of a constant evolution and may even be upgraded further down the track. Now this is all well and fine but given the postage alone to Australia is almost $200 AUD and the wait time is for delivery is 2 months (both figures quoted by Denis to myself via email), I am sort of loathe to purchase a kit only to find it has been improved whilst awaiting delivery. I understand the current situation in Ukraine and the time and money constraints. Yours is looking awesome btw.
Chris.
I am seriously considering buying this, but now Pavel has posted on FB that the V3 comes with new "improved" oars after April. Sort of makes me wonder when to buy as maybe other stuff will be "improved" in the future?
Yeah this is awesome mate! Well done.
Chris.
- AJohnson, Louie da fly and mtaylor
2
1
1 hour ago, BANYAN said:
Hi Vossey,
I will try to describe the technique I use for 'cheesing' the tail ends of tackles. Not my original idea, but it works well for me. First soak your rope/thread, cut to an appropriate size (if doing separate) in a diluted solution of PVS/water ( I use about a 60 water/40 PVA). If using the actual tail end of the tackle, this still works but just soak the required length of the tail (working end of the falls)
I use two small squares (or round) of clear plastic (from shirt boxes or the like). I punch a pin (usually a tack with raised plastic head) through both (See Photo). Separate the two leaving the upper plastic square/round on the pin, and put the outer/tail end of the rope/thread through the centre hole of the bottom square with about 1 to 2mm protruding to the bottom side. Put the pin back into this such that it holds the end and makes a sandwich with the thread between both plastic squares. Now rotate either the assembly or wind the thread around the centre pin to start making a flat cheesed coil to the desired diameter. Allow the finished coil to dry before removing; the plastic does not let them stick too much but still take some care when separating the coil from the plastic. These 'jigs' are so easy and cheap to make you can dispose and remake as required, especially when the centre holes become too large from wear/use.
Just one way to do it.
cheers
Pat
Thanks Pat, this is the exact type of solution I was hoping to find. Will give it a go.
Chris
- Keith Black and Scottish Guy
2
Hi, can anyone suggest a method to make flat rope coils to lay on the deck behind gun carriages etc?
These cause me all sorts of grief.
Thanks.
I have done the Amati Santa Maria and the Mantua Santa Maria. Both are good kits that can be further enhanced by a bit of good old fashioned bashing.
Both have pro's and cons like all kits really. I would say of the 2 I prefer the Mantua. But you really need to cut down on the ratlines on that one. There's way too many.
You might also like to check out this newer version from Pavel Nikitin
https://shipsofpavelnikitin.com/details?code=CSM01
I will definitely be getting this one day.
- Knocklouder, mtaylor and GGibson
3
It used to film here regularly until the main star was accused of sexual misconduct against many female performers over the years. I must add though, that I think he was exonerated of the charges. But it still stuffed his career.
- mtaylor, grsjax and thibaultron
2
1
Is a shame I live in Australia as I have long admired this model, Amati Bireme Greca Scale 1:35 $75
I am sure you will get many offers.
- Louie da fly and Knocklouder
2
- Thukydides, ccoyle and Knocklouder
3
Hopefully not too late to revive this log. I have been working on this ship for a few since the last update. Sorry for my absence.
Anyway here are a few pics in her current state. I must say, this particular kit isn't for the faint hearted. But I think it will eventually make a pretty nice model.
Borrowed the color scheme from a build of the same kit by Navis Factorium (hope I got that right?) I liked the colors better than the box art.
My camera skills still haven't improved and as per usual, high definition pics show a lot of errors. But in real life I am very happy with how this is turning out.
I think the Amati Bounty turns into a great model but be prepared to undertake a LOT of heavy bashing.
The entire stern galley configuration really needs to be scratch built as the kit supplied soft metal castings simply do not match or fit the fine decorative pieces that are supposed to cover them. I am up to this stage on mine and whilst I think it has turned out pretty good, it has taken months to get it right. Similarly, you will find the overall plans not very good with many wood strips wrongly sized etc. The main wales for instance.
The pre-cut gun ports also need to be addressed as you will find your guns pointing at an obscene downward angle unless you come up with a plan. I rectified this by completely cutting the top off the gun port, doing away with the horrid metal port lining, and replacing the entire assembly with fine painted wood strips.
I will try to post a few pics here a bit later, (probably should have carried on with the log I started a few years ago here), but in the whole I believe the Amati 1:60 kit will make a great model, just takes a lot of forward thinking to get it that way. There are a few logs out there for this kit and they are helpful, plus I can give you a heads up along the way if you decide to go with this kit. Good luck.
Cheers.
Hi, I would suggest starting with something like the Amati Santa Maria. It has all the elements of larger, complex ships but being such an early vessel (15th century), those elements are not as daunting as a Victory, San Felipe, Wasa etc.
With the Santa Maria you will still have to double plank. But being an older ship the shape is far easier to obtain. Tricky bits on Victory like the bluff bow and stern area are not required on a vessel like Santa Maria.
With SM you still have to apply channels, plates and ratlines so you can get a great guide as to how to go about that before tackling more complex models. Rigging is more than substantial enough for a beginner and you can add sails if you wish.
Also as an added bonus, Santa Maria, whilst being one of history's most famous ships also lends itself to many interpretations as there are no known drawings or plans of the actual vessel. So you can add extra deck details etc. as long as they are from the period who is to say you are wrong?
But my final observance would be this: Santa Maria is the most awesome vessel that ever sailed! Just build it. You know you want to!
Your racing through it now David. It looks awesome. Well done. I like the flag addition too.
Chris
Welcome and good luck Sam. Ask heaps of questions!
Chris
- Keith Black, Ryland Craze and mtaylor
3
My first wooden kit was the Amati Santa Maria. Probably not considered a "true" beginners kit but I chose it because I loved the subject. I found it challenging but totally rewarding. Sure there were many parts that really perplexed me at the time, but by asking here, and reading many books and posts I managed to produce what I consider to be a really nice model.
So I always say, with some caveats, choose a subject that interests you. The caveat? I would steer clear of "expert" kits like large Victory's etc. You will see very experienced builders on this forum sometimes can run into problems with those type of kits. Also, I think you should probably prepare yourself for the fact that every kit, no matter what level, will likely present problems of some sort or another. No kit will fit together 100% perfectly the way the instructions say it will. They all require some sort of tweeking to come together.
Building a model ship is a very repetitive process and can even get boring. Especially if you start with something too big. Ask some of the advanced builders on this site how much fun it is rigging all the cannons or doing the ratlines on a large scale Victory? My Santa Maria offered me the chance to do simpler cannons, less ratlines and probably most importantly for a beginner, a far simpler planking due to the shape of the bow. I would steer clear of bluff bowed vessels like Victory, Bounty, Endeavour etc. I would also recommend any vessel you undertake to have double planking. The first planking will give you a great idea as to how planking is done and doesn't have to be perfect. It also makes the second layer, which you want to be a perfect as possible, much easier to do.
Good luck on your journey.
Chris
- mtaylor, Chuck Seiler, Knocklouder and 1 other
4
How about putting a small piece of modelling tape, like Tamiya Tape over the section to be drilled into? Tamiya Tape is very light tack but it should be enough to hold the brittle wood together whilst you drill through it, then you can easily remove the tape and be left with a nice small hole. Plus it wont leave tape glue on your deck once you remove it. Hope this helps.
Chris.
- mtaylor, RossR and Keith Black
3
Hey Bill, well you could argue authenticity about a lot of models. My favourite vessel of all time is Santa Maria. Has been for 50 odd years since I was a kid.
But, there is no definitive pictorial evidence of what she ever really looked like. Same for Columbus for that matter.
Apart from maybe, Victory and a few other super well known and documented vessels, you will find different model companies produce differing designs of
the same vessel. Bounty etc.
I just think that the San Bartolme from Pavel Niktin looks outrageously good. Is is accurate? Maybe not, but was the Mona Lisa?
I still want it!
Chris
- mtaylor, Kingspoke, thibaultron and 3 others
6
'Oseberg' Viking Ship (v3) by James H - Ships of Pavel Nikitin - 1/25
in - Kit subjects built Up to and including 1500 AD
Thank you very much.
Chris
