amateur
Everything posted by amateur
  1. Yup, far easier. I found this on a site of RC-builders. (Rcgroups.com) A very large scale (1/3) model of a DVI. It is labelled as fuel gauge. But still, no clue how this can be created usingthose two parts …. Jan
  2. Yeah, but scoops have their open end ‘face forward’. This one faces backwards. I like these basic planes with their funky camo. Jan
  3. But there are pics showing this part (only head on….) comes from a russian site: https://flyingmachines.ru/Site2/Crafts/Craft25494.htm Jan
  4. Your memory isn’t faulty: both Amsterdam and Batavia show the guns fully rigged and ‘ready for action’. Nicer for the tourists Jan
  5. Friesland is a nice model. Don’t believe the hostorical info given by Mamoli. It is correct as far as dates and places of the battles are concerned. Not with respect to the ship. The model is based on drawings and photographs published in a (at least on this side of the pool) famous german book ‘Hollandische Zweidecker’ by Heinrich Winter. The book shows a contemporaneous model of a (presumably fictitious) Dutch ship that ended its long life in bombing of Berlin in 1944/45. The book is still available second hand, and many of the pictures can be found online. Nice when you want to do some detailing. Jan
  6. Coming along nicely! With respect to wale/transompiece: the connection is not a ‘structural’ one. It should, however, be without gaps, to keep the water out. Deck camber is OK, often the camber of the cabin (top deck) is slightly more than of the main deck. One remark on the deck: The aft deck is lying too low, there is no railing or any planking higher than the deck (see also the statenjacht or the models referred to earlier in this thread) And another point: it looks as if your ship is lying a bit too low in the water. With respect to ‘what next’: I don’t know whether it does anything to your workflow, but the cabins and the decklayout would be nice. Adding leeboards however do the most to the general views Jan
  7. Are you sure it is Corel? I was only aware of the Mamoli-kit mm61, that is called ‘Catalina’, but isclearly modelled to the ‘Groene Draeck’, the private yacht of theDutch royal family. Btw: yourboeier turned out realy well, it is a difficult model to build. Jan
  8. I was wondering whether a ‘boeier’-like planking would be possible, but I guess not, as the bottom is almost completely flat up to the stern. Boeier-jachts are planked using relatively narrow planks, that areheavily spiled and edge-bended. Statenjacht Utrecht is planked in the way Waldemar showed, albeit slightly different, as the planks from the side are slightly spiled, and edge-bended. Jan
  9. Looking good so far. That profiled piece of timber at the stern is one heavy piece. It is one of the structural timbers of the lower stern. It is notched into the stern. Although drawn as a completely flat stern, in many drawings (also the older detailed one some posts before) the tmber is also slightly curved when seen from above, implying a slightly curved stern. Jan
  10. Nice lines! Why do you leave so much room between the planks? Jan
  11. J think the name is Jan Veltman. Not because I know anything of him, or seen a full signature, but Veltman (without d) is still a pretty common name, Veldmand certainly is not. Jan
  12. @Robska: you show a steel tabernacle, made for a mast that is placed on the deck. The construction with masts with a counterweight is stepped on the keel, as you can see in the drawing in #44, this part tend to be relatively heavy in all dimensions. Jan
  13. That traverse rail in #13 is the rail on which the lower block of the main sheet is attached. It goes over the tiller, but has noconnectionto it. and that is why I am not sure about 3referring to this part: it is above the cockpit, while it can (need?) be placed further aft: above the deck where it is not sitting in the way of people getting in or out… jan
  14. @Waldemar By writing that there was no shi built to this drawing, I meant that this drawing is not a detailed construction drawing. Niot that it is notbased onsn actual ship/construction drawing. With respect to the book pf Lemmers: I did not at fist glance see the dofferenced between this drawing and thosein thr book. Can you enlighten me abit more by indicating whete the major differences ate? Jan
  15. Hi, I was about to make a ‘final’ remark on the drawing from the national archive: I don’t know why the drawing is dated 1733, but my guess is that it newer. Also: it had never been used to buuld an actual ship. Doreltomins drawing certainly is contemporeneous. When in doubt, follow that one. By the way: I don’t think these construction methods are unknown. Couple of years ago there was a Dutch book titled ‘ In tekening gebracht’ authors:Lemmers/Hoving, describing these construction methods. Jan
  16. Never seen that on Dutch ships. Would be interesting to see what type of ship that is. Do you have a link? Jan
  17. It is also possible that the deckplan shows the deck-layout. In that case the line of the caprail falls even inside the line drawn, as the railing falls slightly inward. so: no errors, perhaps some slight imprecisions. I do not know of dutch inland craft that had a cable-run rudder. It was - as far as my knowledge goes - whipstaff or tiller. Jan
  18. With respect to size, can you explain how you end up at 18 meter. I made a print of the drawing om a A4, the length of the scale in my print is around 4.3 centimeters, the length of the hull between perpendiculars around 19 centimeters. Dividing implies: 19/4.3*9 feet = 40feet. (Which is a nice round measure for a design drawing ). 40 feet equals 40 * 28.5 centimeters = 11 meters. That in turn is a relatively common measure for an inland sailing craft as this one presumably is. With respect to your questions: 1: belaying point. See picture below, heavy, slightly curved piece of wood, with a iron spike 2. difficult to say, but most probably a hole to feed the running part of a backstay, or of some lines to handle the gaff. Other option: iron ring used to fix the lower block of the tackle of the backdstay (or some line to the gaff). See below, Statenjacht Utrecht has both at this location: attachment of the tackle blocks, as well as the place for the running parts to feed through to the belaying points at the inside of the bulwark. 3: definitely not a whipstaff or tiller. Tillers were fixed at the top of the rudder, and sat ‘on top’ of the cabin. Tiller is not shown in this drawing. It micht be the ‘luiwagen’ for the mainsheet. However, I would have expeted it in the topview also. 4. and 5 already explained. You can see the arrangement in pne of the drawings I linked to: the mast can pivot backeards, and 5 is a hatch that can be removed to let the mast pivot backwards. The wider part up front is needed to accomodate for the counterweight. Bit difficult to see in this pic, but the sustem is a bit outdayed nowadays, so not many pics around in the net… with respect to your decklayout: I still prefer the two-cabin option over the one cabin/ open deck version. You may discover that your floor in the aft cabin sits too low: due to the form of the hull (and the thickness oh the frames), you may end up with a rather small floor in the cabin when laid to deep. Raising it will give more square feet. Second: in most drawings I know, there is a bench below the windows, in such a way that the windowsill is at ‘bench level’. I think in your layout this distance is a bit large. Jan
  19. Which is consistent with the drawing we started with: the sternview shows the rudderpost from keel to the upper deck. I checked: all three models I posted have this setup/layout of the stern. Low res, but stull visible Jan
  20. And another. I’m inclined to believe that this two-cabin was for one readon or the other a common layout https://www.maritiemdigitaal.nl/index.cfm?event=search.getdetail&id=101005505 It is a pity thst these ics can’t be doenloaded at high resolution….😟 Jan
  21. https://www.maritiemdigitaal.nl/index.cfm?event=search.getdetail&id=100146019 model from the collection in Rotterdam, datimg around 1780. Two cabins, like many of the posh yachts from that period. I dont see how you arrive at a depth of 3 meters for the cockpit. It is smaller. You need that depth anyway, as the door of the aft cabin is at that level. The depth is the distance beteen the two dotted lined in Waldemars sketch. My guess: only half of your estimation. This one is also intresting. Drawing of around 1750 of a jacht: https://www.maritiemdigitaal.nl/index.cfm?event=search.getdetail&id=100196711 This one shows another possibility: deck level in aft cabin lower than in the cockpit. Also here: no open space forward, but a deck that is raised till ‘standing height’ below deck. Jan
  22. Yes, that would also be an interpretation. You can find drawings of both layouts: with and without a well, with/without forward cabin. That is why it is a pity that there are no deck-lines in the drawing. Jan
  23. In reply to @Lieste. In larger ships the deck is at the level of the wale, but in smaller yachts and inland vessels there is hardly any bulwark around the foredeck. Hence the level of my blue line. The point were the leaboards are attached is quite often a rather heavy doubling, so there need not be a relation to the decklevel (but it can be) As said before the drawing leaves some space for interpretation. and with respect to size, the overall length of the hull is somewere around 40ft, wich is around 11 meters. The Statenjacht Utrecht measures 24 meters lenght at the waterline, which is around 85ft. This yacht is a small vessel, comparable in size to the smaller wooden yachts that are still around and have almost no bulwark, except around the cockpit. (Boeierjacht Sperwer, Enkhuizen) Jan
  24. Need not be: deck planks are non-structual parts, the sode of the ship is. All ships I know of have some pretty sturdy frames at the location where the leenoards are attached. Only if there is a deckbeam at the ondicated location the connection is stronger. Althoug I very much doubt whether such a heavy connection is really necessary. Jan
