Everything posted by amateur
Hi Piet, She' s getting better and better every day. (and at an amazing speed ...) I wish you 'prettige kerstdagen en een gelukkig 2014'. Jan
Looks a bit Russian to me Jan
Sorry to correct you: I think you mean "Addie M Lawrence" see www.afn.org/~stan/ships.html Jan
At least, it is one mast short of Thomas W Lawson... Jan
I never had any connections to any shipyards. I guess that was another Jan Jan
No, it is one of the other 31 ships of her class (techniclally speaking, it's even an other class). So guess again No kidding: it is HrMs Leersum, one of the ships of the Wildervank klasse, which is on the outside almost identuical to the Dokkumclass of which Venlo is part. Over to you (btw are you really living in China?) Jan
British pre-dreadnought. around 1900: First guess: HMS Albion? Jan
We had the Queen of Kent, quite recently. This one is of the same build, but a different funnel-configuration... Jan
One of the english island ferries PS Waverly and her friens, Nice ships! Jan
I see many similarities, but Norrskar is still with us (the original one). Although the one still sailing wasn't build under that name.... Jan
If your ultimate goal is building a kit everyone else is doing...... When I started my Prins Willem-log (long, long ago) I couldn't find any other. Now there are many. Shouldn't I have started long ago, did others notice PW becuase of my log? I don't know. My idea is that you should buy a kit that is in line with your possibilities (although: skills will improve along the road, so you can try slightly above your level) But a victory as your first is perhaps a bit too far (although: many logs around) First of all you should buy a ship you are happy with, and would like to invest time and money in. I don't know this particular ship, but my impression is that kit-makers put nameless ships on the market, provided with a fake history (Friesland by Mamoli is a nice example: the ship never existed, but the story sounds great). Perhaps your kit is in the same category. Is that a problem? That fully depends on you. You still may like the ship as it is (even without the Nelson-connection. Perhaps the ship has a proper nelson-connection. Does that make the ship or the kit nices? That again depends on you.... The only thing you want to be sure of, is the technical quality of the kit. IN case there is a problem there, you may reconsider.... Jan
Papegojan 1627 by mati - FINISHED - 1/48
amateur replied to mati's topic in - Build logs for subjects built 1501 - 1750
asphalt? My first idea with asphalt is 'roads'. Do you have a link? Jan -
Actually, it's the other half of the twins: Soemba. But as these two are completely identical, it's up to you to post teh next one. Pic is taken somewhere in the east-indies, as she has her sun-gear installed on deck. Soemba and Flores were 1920-ies build gunsloops, in active service till after WWII, were they were involved in actions in the mediterranean and at D-day. Flores has been used as instruction vessel until the eighties. Jan
Never realized these ships were as large as your living room she's an impressive build. Spray at the club, and afterwards detailing her there, or are you going to get her home every time after (re)spraying? Jan
- 382 replies
- stadacona
- sylvan scale models
Real wood ? I like your plane: how large/small is it? Jan -
I do it the other way round: start with square, and first taper it. After tapering, round it. I found it easier to get hte right tapering while the piece of wood is still square. (but I didn't use a lathe or any other machinery.) Jan
Household Ammonia
amateur replied to Q A's Revenge's topic in Building, Framing, Planking and plating a ships hull and deck
I only use it in 'extreme conditions': The railing on the top is a walnut-strip of 0.6 mm thich, and 2 mm wide, bending without ammonia tended to result in an unevenly curve. I soaked in it a 10pct ammonia solution for half an hour or so, and than I could almost make a knot in it without braking it. It did however, result in severe bleaching of the wood, and the structure of the wood deteriorated (after drying it was more brittle than before) Jan -
I don't know. Queens come and go (although, perhaps not in England. ) Jan
some paddler on the Medway? one of the Queens perhaps? Jan
PS Waverley and his friends Jan
