Everything posted by kurtvd19
Realistic Water
kurtvd19 replied to taylormade's topic in Painting, finishing and weathering products and techniques
SeaWatch Books published a book by Justin Camarata called - Waterline Dioramas: A Modelbuilder's Artform with a review here on MSW - It might be out of print but if you can borrow one it will be a good read. Check the model railroad sites as they do a lot of realistic water. -
Deleting albums
kurtvd19 replied to ChuckB's topic in Using the MSW forum - **NO MODELING CONTENT IN THIS SUB-FORUM**
Chuck: Go to the started album you want to delete and look at the top left box where your write up and other data is and note at the bottom right in the gray box with MANAGE ALBUM and a drop down arrow. Click on it and there is a choice to DELETE ALBUM. Click on it and the job is done. Make sure it's the one you want gone as it's final. -
If you want a lathe for model building this is not what you want. Do a search here on MSW for TAIG Lathe and Sherline Lathe there are also some others used for our hobby. There are several topics about picking out a lathe - check them out. Then if you have questions about a specific one for your use ask and you will get answers/opinions.
I usually use my Preac for the brass but the Byrnes saw just uses larger diameter slitting blades like on the Preac. I like to make a sandwich of light aircraft plywood with the brass sheet sandwiched between the ply - everything stays nice and straight and the cut edge hardly needs to be sanded. Drop the cut piece in acetone and the glue is dissolved. The only thing I have ever used Duco cement on.
Mike: Looking good. Airbrushing will not fill in gaps. Don't even try. Your plan to use the filler is the way to go.
I use acrylic paints exclusively. I seal off the wood prior to painting with shellac - it dries very quickly and seals off the wood from the acrylic primer I use without raising any of the wood's grain. When the primer is applied there is no worry about having to knock down the wood fibers that are raised when acrylics are used w/o a sealer. I use a primer - Badger's STYLNYLREZ not only as a primer but sometimes as the final color. It's made in 16 different colors. I recently did a model sailboat that won a gold medal and it was painted exclusively with STYNYLREZ as the final colors. An added bonus I didn't have to take it home and put it in a case because a fellow modeler offered to purchase it and I said OK. I used to spay the wood with water - a light coat - to raise the grain, let it dry sand and repeat until no more raising of the grain occurred then I would prime/paint w/o having to sand wood fibers between color coats. I decided to simplify things and shellac was the answer. Others have said sanding sealer, etc. - nothing wrong with doing it tat way - but shellac works for me.
Lighting should be the first thing considered when trying to improve seeing the work. Years ago my Ophthalmologist told me to use bright white light and recommended Halogen lighting for reading and model work. I followed her advice and my eyestrain was no longer an issue. Later when my eyes were changing with age the new Ophthalmologist told me to do away with the hot halogen lights and switch to white LEDs. Changed my reading light and workbench overhead lights to LED and after getting a cataract fixed the LEDs look like the current answer. I had switched to glass lenses in my optivisor before the lighting issue and the combo of glass lenses and LED lights has been my answer. As to plastic lenses I wish they would just go away. My Ophthalmologist has just told me I need a minor procedure to fix my recent blurred vision issues because my implant lens (plastic) is clouded just like some car headlight covers get. A simple 5 minute laser procedure in the office will make the implant clear as the day it was implanted. Nobody ever told me about this - I would still have done the implant because I went from 20/400 w/o correction to 20/20 with the implant and have been assured my vision will again be 20/20 after the laser procedure. So if I have to get this done every 5-6 years no problem. I am sure the plastic lens implant is better than an actual glass lens in the eye so I will live with a plastic lens in my eye but not externally to help with magnification.
Chris: Hang onto the expensive set - especially if the lenses are glass - you will probably need the better setup as your eyes age. I used a plastic lens Optivisor for years - a few years ago I tried an Optivisor with glass lenses at a trade show and it didn't take me more than a few hours later that day to order an Optivisor with glass lenses. Difference is light night and day.
Which Ship Modelers Shop Notes
kurtvd19 replied to Dave_E's topic in Modeling tools and Workshop Equipment
I have to agree with Bob's reasoning and his recommendation to get Vol 2. -
2021 NRG CONFERENCE
kurtvd19 replied to kurtvd19's topic in NAUTICAL RESEARCH GUILD - News & Information
I can say with complete confidence that the NRG - and MSW - have never been in better shape than right now. We have experienced continued growth and member involvement. It was common to get less than 100 members responding to surveys and voting and we now can count on hundreds participating in votes and feedback. We will be sharing a lot of information with the membership tomorrow about growth and activities. -
2021 NRG CONFERENCE
The Zoom invite will go out to all members tomorrow for the Annual Member Meeting as per the email sent recently. -
2021 NRG CONFERENCE
I hit the send button too early. Check the NRG's website - https://thenrg.org/events - the events page has shown the 2021 Conference as being cancelled for several months (Feb or March I believe). -
2021 NRG CONFERENCE
Justin, we have sent out all member emails every month, sometimes more than one in a month. Check your spam folder. -
Trying to understand white balance
kurtvd19 replied to Gaetan Bordeleau's topic in Photographing your work. How to do this.
Members are obviously interested in photography and I would bet some are saying "it's about time". The great thing about MSW is there is something for everybody. Another great thing about MSW is that if a subject doesn't interest you then you are completely free to skip over it and go on to another subject. Everybody is free to have their own opinion on any subject and you have expressed yours. I personally have enjoyed reading the recent posts on the subject. To each his own. -
NRG VIRTUAL WORKSHOP USING THE TABLE SAW SAFELY Saturday, December 11, 2021 Plan to attend the next NRG Virtual Workshop on Saturday, December 11, 2021, at 10:00 AM CST entitled "Using the Table Saw Safely". Presented by NRG Director Kurt Van Dahm. This is an updated version of Kurt's talk which was presented at the 2018 NRG Conference in Las Vegas. As usual this event is free to NRG members while others can attend for the bargain price of $5.00. The safe use of smaller table saws, like the Byrnes saw, will be the subject of the presentation. Though smaller than full-sized table saws, model-sized saws can still take a finger off or severely injure the modeler if they are used in an unsafe manner. Kurt will show how to perform rip cuts, cross cuts, lap joints, miters and other common operations in a safe and efficient manner. Many modelers say they are totally intimidated by the dangers of the table saw and that they are hesitant to use the saw they purchased. After this program, these modelers should be less hesitant to use their saw. And those modelers who routinely use their saws will appreciate the tips on proper saw set-up. At a minimum this presentation will provide a helpful review of safety tips and might even prevent an injury due to complacency. Pre-Registration is required, and registration is now open. Use the link below to register. This is free to NRG members and non-members can attend for the low price of $5.00. Follow the directions on the website link page to register. LINK https://thenrg.org/event-4571585 NRG members should be able to select the FREE registration option after starting the registration process and entering the email address on file with the NRG. You may need to log into your NRG account to register for free. If you're not sure how to log into your account, click here for more information. Not an NRG member? Click here for information on joining! We plan to have several of these Workshops each year. With NRG memberships starting at $40 you will receive the quarterly Nautical Research Journal, discounts on NRG products and FREE admission to the Workshops.
I used to do forensic photography back in the days of film. Correct color balance was vital and you didn't dial it into the camera. We used filters to correct for the lighting and it was tricky. I used to start every roll of film with a shot of an 18% gray card with color chips (of a known value) and the lab used the settings they got when printing the gray card/color chips (standard tools of the trade) to print the rest of the prints so they all matched. It was so critical that I used only Canon lenses - no Vivitars or other brands - and the guys who shot with Nikons only used Nikon lenses - no other brands. Just like light meters are hardly used today ask anybody today about a color meter and they will look at you like you are from Mars. Setting a white balance today is a walk in the park in comparison. When digital first appeared on the scene there were all sorts of articles in the pro publications about how the images could be manipulated and the courts would never allow digital to be used in court. They were wrong, but when the first digital images were finally allowed it was a real challenge to provide everything they might require the photographer to provide to make them certain the image(s) were accurate. It got to the point where I was happy to get out of the business because of the hassle. I had to give up a very lucrative business I did on my days off from the FD when I got promoted and put on a 40 hour M-F work week. It came at the right time for me (getting the gold Chief's badges and pay raise mostly made up for the loss from the business) because it was getting to be a grind. -
I suggest you apply CA to the end of the line and while it is still wet use your fingers to taper the end of the line - just apply pressure to the line and draw the line between your fingers. This is often adequate but you can also try to cut the end of the line at an angle after the CA is applied. A sharp blade is necessary. I usually cut the line at an angle.
Broken link to the NRG store
kurtvd19 replied to EricWilliamMarshall's topic in NAUTICAL RESEARCH GUILD - News & Information
Our webmaster has been notified. Thanks for letting us know. -
Smartphone digital loupes
kurtvd19 replied to modeller_masa's topic in Modeling tools and Workshop Equipment
This seems to work great for you. You will be happy with less eye issues. I advise anybody buying the Optivisor type magnifiers or any other type of magnifiers to not waste money on plastic lenses. Go for the real glass lenses and you will not believe the difference from the plastic - I used plastic lenses in an Optivisor set (they make plastic and glass lenses) for 20 years before my ophthalmologist told me to throw away the plastic stuff and get glass lenses - it was like a different world when I got the glass set. -
I have to disagree with Bob regarding the Medway Longboat. Chuck doesn't recommend this as a starter kit. It's pretty darn small and finicky for a beginner. We did this as a group project at the local club and few were completed though those that were are excellent models but they were built by some of the better modelers in our group. Bob's entirely correct in start small and simple. Kurt
