Everything posted by kurtvd19
Eric - the river project publicity says it will be available later on You Tube.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
I have seen this talk - Eric asked me to review it for him. It is excellent. I highly recommend it.
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Check Bluejackets cross section of the Charles Morgan whaler - larger scale too
This is far short of being a case - dust will still have easy access to the model. If you are contemplating a shelf wide and long enough to fit the model it only takes a few inches more to fit a case with the model inside.
proxxon mini mill
kurtvd19 replied to Anthony Hearne's topic in Modeling tools and Workshop Equipment
This has been discussed here - you can do a search and see if your questions have already been answered. -
C/A glue doesn't have a lot of shear strength - but I don't anticipate planking being subjected to much in the way of shear force. Or decking, or deck furniture. As to hiding the glue on bare wood that I commented on earlier... The Journal currently at the printer features on of Steve Wheeler's models. There is a photo of the hull showing the glue marks in a photo before finish was applied. The photo that shows the marks best is the exterior of the hull but the interior had similar markings and the photos of the finished interior show none of the marks after the finish was applied. Invisible on the finished model.
CA residue problem
kurtvd19 replied to Doc James's topic in Painting, finishing and weathering products and techniques
Master modeler Steve Wheeler used thin C/A on bare wood and never worried about the C/A marks as he applied Floquil's F110015 Flat Finish Matte (the jar is also marked as enamel) as an over spray and the C/A marks disappear completely. Steve showed before and after photographs in several articles he wrote for both Ships in Scale magazine and the nautical Research journal. He only ever used this particular product and it is no longer made but any petroleum based clear should work - acrylics were tested and don't work. The marks were made with thin C/A and no build up of C/A - the thin soaked in completely. I saw his work under construction with all the glue marks and after so I have seen the proof first hand. I have the testing of other flat finishes over C/A glue on my list of things to do - but I think it is something that somebody should look into. -
Reading the instructions all the way through can head off situations like this. In my writing I always advise right up front that reading the instructions completely is the single biggest step one can take to assure a good build.
- 13 replies
If you ever have to repair the model or repair a model made by another you will wish the masts have not been glued in place.
Macro photography on the cheap.
kurtvd19 replied to ausf's topic in Modeling tools and Workshop Equipment
And with digital photography you see immediately if the exposure was good or not - no need to figure the exposure factor for the tube or tubes used. -
At the 2003 NRG Conference here near Chicago Fred Hocker the Vasa curator was talking about their studies of the colors it was painted. He said that he was aware that Vasa builders would argue that the blue used on their model was more accurate than the other guy's paint. He conclude it with a scientific explanation of how the polluted waters of the harbor had chemically changed the original paint and that the studies showed that it was RED not blue!
I have been using STYNYLREZ since before it's introduction to the public. Great primer and it is used by many miniature painters as a top coat - I did the same for a model that was featured in Ships in Scale - only STYNYLREZ paint. It's a primer do the .5 needle is correct but I haven't used anywhere near 30 psi - well under 20 psi. Excess pressure promotes tip dry more than any single other factor. I have not had need to sand it - properly used it is very smooth.
I have it all painted, some assembly done but after doing my analysis of the kit and instructions for Model Expo I had to put completing the kit on the back burner due to commissions and the NRG Chairmanship taking up all my time. My term as Chairman comes to a close in February - maybe I can get back to it in the future. Will still be on the board but without the extra duties of the Chairmanship.
New to PE, need suggestion about tools to fold
kurtvd19 replied to Jsks76's topic in Modeling tools and Workshop Equipment
Drill bits you already have can be used for rounding/curving parts - no $ outlay. But if you are into tools..... -
Ken You just need a new needle. But if you send the brush to Badger they will go over it and repair anything needing work for the cost of the return mailing - I don't know about the needle cost as that's owner damage, but I have sen some real abuse to brushes they receive and they just fix and return them.
Your 105 most likely came with the .5 needle/tip. They do make a .7 needle/tip (you need to match the tip and the needle). Unless you have one of the newer extremes, the 105 with the standard .5 nozzle is perfectly adequate for any acrylics - properly thinned/airbrush ready not tube stuff you need to heavily thin. There is a .3 needle - but anything other than the .5 needle is only available by order.
I believe they are lights. The ones at the rear would elevate with telescoping mast - by hand - and pivot 360. I think the parts above the read cab doors are also lights that may strobe when responding and may light otherwise. Sometimes called alley lights. just guessing on this. Haven't been back to where I worked for about 2 years - only go to retirement ceremonies and the apparatus is usually parked outside so the apparatus room can be used for the ceremonies, so I haven't been up cloase to look at the newer stuff.
