kurtvd19
Everything posted by kurtvd19
  1. It is a wide angle mirror so clearance of the bumper extension can be seen and presence of any pedestrians can be seen. This is an addition to apparatus since I retired. Check out buses and such for these too - not unique to fire apparatus.
  2. Do a search on each of these topics - they have been discussed many times - lots of advice & recommendations.
  3. Please use English. #7 in MSW Guidelines copied below. - You must use clear and legible English at all times. Some leeway is given if English is not your first language but please remember that this is an English speaking website and English is the 1st choice of language for postings. Moderators may alter or delete posts that don't make sense because of poor spelling and/or grammar.
  4. We will have some news about scale 3D printed figures sometime in the next couple of months.
  5. Muscongus Bay Lobster Smack: A new Shipwright's Series kit. Skill Level 3 Scale 1:24 Kit #MS1472 Overall length 14 1/2 inches – Width 3 3/4 inches - Height 14 inches - Baseboard 4 inches x 10 inches Completed model - Photo Courtesy of David Antscherl This kit is the third in the new Shipwright’s Series of progressive model tutorials designed by David Antscherl for Model Shipways a division of Model Expo. These kits fill a void in our hobby for simple but good kits that teach the new model builders the necessary skills to enable them to move on to build bigger more complex kits. For many years, Midwest Model Products manufactured a great series of kits that were designated as Level 1 through Level 4 and designed to teach the beginner wood boat modeler the basic skills a wooden boat modeler needs to learn. New ownership cancelled the line several years ago and the hobby has needed replacements which Model Shipways is now providing with the new Shipwright’s Series. The instructions for this kit like all the instructions for Model Shipways kits are downloadable as a pdf from the Model Expo website. https://modelexpo-online.com/ If you are curious about this or any other Model Shipways kit downloading and reading the instructions is worth the time. The typical MS blue box Instructions and parts list The Muscongus Bay Lobster Smack kit is labeled as a Skill Level 3 kit both on the box and in the instruction booklet. The first two kits had information on experience needed (or helpful) to have before starting the kits. The level one was simple; “No experience needed.” The level two kit was more specific: “Some previous knowledge is necessary in order to be successful.” The first paragraph on the first page of this level 3 kit has the following advice from the kit designer. “This is not a ‘first time’ beginner’s kit. I want you to be successful, so strongly recommend that you build the Model Shipways dory or pram kit first. You will learn the basic skills and techniques needed to successfully complete this kit.” The author thought this important enough that red ink was used for the entire paragraph. As in the previous series kits the tools needed are called out as well as some that are nice to have but not necessary are listed for the benefit of the newer builders these kits are aimed at. Unpacking the box finds a full color 38-page full color instruction manual, a list of all the parts contained in the box, 16 sheets of laser cut Basswood, cloth for the sail, a plastic bag containing two diameters of nylon rigging line, a plastic bag with Britannia castings: six cleats, two oarlocks and four turnbuckles. Two pieces each of 1/32-inch x 1/16-inch and 1/32-inch x 3/32-inch Basswood strips and a six-inch piece of 3/16-inch dowel complete the kit contents. Overall, the materials are good for the kit’s intended purpose as a learning experience. This kit is a fitting follow up to the Level 1 and Level 2 kits previously reviewed. I recommend it as a good learning experience that will prepare one for the challenges of a multi-masted model. Model Shipways has provided another step in the learning process that is needed in our hobby. Laser cut sheets - 16 total Blocks, nails, eye bolts, rings Cleats 24 and 18 Ga. Copper wire, Brass strip and Brass rod Oarlocks Sailcloth and rigging line
  6. The extended fence is secured with 4 machine screws into the standard short fence. If you have 4 tapped holes close to the ends of the short fence you are set to go. I got mine in 2003 and it was set up for the extended fence at that time.
  7. The best thing you can do so you don't become a statistic would be to put aside the kit you are working on and get a simple kit meant to teach modeling techniques. You are already aware of the issue of how many walk away from first builds that are too complicated - why do you want to go down that road? Do a search of this site for beginner kits - check them out and use the very good instructions in these kits along with build logs here to guide you.
  8. 50 ft. I offer this as a realistic appearing option - that might be much easier and I myself wouldn't hesitate to use the technique. Maybe they do it differently in other areas but every place I have ever visited and looked at fire apparatus the hose beds are covered by removable covers. Water resistant to waterproof canvas covers with easy release snaps or tabs that need to be turned90 degrees to lock in that cover the hose bed side to side and end to end and then hang down at the rear so the hose stays dry on the outside. Dirt in the canvas covering will mildew and get grungy if allowed to get wet w/o being allowed to dry out. Packed in the hose bed it doesn't dry out. Model the rear of the hose bed like the photo used earlier. Make a cover that covers the hose bed and shows just a bit of the rear end that is packed in - using about 10% of what you would need to fill the entire area. Use a Styrofoam block behind the hose to "fill the bed" Just like using a canvas cover on a life boat so you don't need to detail the interior.
  9. Try gluing or soldering the hose fittings to the metal before the heat shrink is added and make a smaller shoulder on the fitting for the heat shrink to grasp
  10. You can also use the one piece bottom provided. Please do yourself a favor and read the instructions all the way through before you glue a single part together. I always tell newbies this is always step #1. You can weight the center piece on top of a piece of glass or wax paper and put a bit of glue on one of the side pieces, push them together and weight the 2nd piece till the glue cures. Repeat with the third piece. I have a metal assembly fixture with magnets for this kind of work but weights work just as well.
  11. Actually the hose jacket is canvas and the texture is not real rough - remember the firefighters need to be able to drag it and rough ='s hard to drag. It is a heavier canvass than used on roofs of boats. I just looked at the roll of solder-off in my shop and it's way too coarse. The texture will not be very noticeable at 1/24 or 1/25. Smoother would be less noticed than too rough. I forgot that some FD's use extruded hoses - not in this area though - smooth except for the longitudinal grooves. Check this suppliers photos - https://www.edarley.com/fire-hose/ They actually show yellow booster hose now! Never saw any but it is made.
  12. Look for flat shoelaces. When the hose is packed into the hose bed it stands on edge. I don't know what size shoelace to tell you but today they all use 3" hose for supply/attack lines many times with a "WYE" that branches off to two smaller lines - 1 1/2 to 1/34" dia. that is easier to get into a building, up stairs and around corners.
  13. https://thenrgstore.org/collections/guild-products/products/model-ships-2021-calendar
  14. One of my local club members is a member and former President of the Association Professional Model Makers www.modelmakers.org and two others in the club were employed in the field. They have taken a tremendous hit with the advent of 3D printing. One is retired - not by choice but he got his SS within a few months. The other two had shops with machinery and all. One switched to a related production field - making mold boxes for castings and is doing fine. The other still has his shop and the work he does for the Chicago area museums keeps him going. But their prototype work died. They both did display props for trade shows - all gone in 2020. The APMM newsletters are a great resource.
  15. I was interested in both the home ex for cooking and shorthand. Back in 1961 home ex was for females only. No exceptions. I wanted to learn shorthand so I could take notes in classes. NO had to take typing before shorthand. At the time I never envisioned a need to learn typing - if I knew then what I know now I would have taken it. Back then girls were not allowed to take any shop classes except drafting. What should be mandatory is a class on life skills. How to make a budget. How to balance a check book - realizing only dinosaurs actually write checks. How to cook. I had a friend who wound up damn near starving to death when he and his wife separated. W/o carry out delivery he would have starved.
  16. Congratulations. It looks great and you learned from the experience. That's a win-win for sure. Kurt
  17. Tim: I too frustrated my Father after becoming a ME and doing drafting by hand long before CAD, I left the field to go onto the Fire Dept. Actually followed after my Father and Maternal Grandfather going the FD route though they were volunteers. My education sure did help down the road when I became a Division Chief in charge of Fire Prevention and part of the job was to review drawings for commercial buildings. All hand drafted and I was right at home. Then we got our first high rise building - 9 stories tall and they were CAD plans. I became a convert instantly. I am still so many years later trying to learn CAD and resort to the drawing board because I can do it quickly. Those first CAD drawings were so different in their presentation and I haven't seen this method used by any other firm since then but the electrical, HVAC, plumbing, sprinkler and other systems were duplicated on transparent sheets that could be laid over the floor plan one at a time or combined - one could see how one system crossed over another or couldn't because it was blocked completely. Now the CAD programs can check for interference's, etc. that just can't be done by hand drafting. But I have never sat down and looked at a set of CAD plans and marveled at their beauty like I have with hand done drawings. Looking at ship plans done in CAD cannot compare to studying plans done in the late 1800s up to the 1930s where draftsmen showed wood grain, coal in the bunkers, etc. Some of these hand drawn plans are worthy of framing. And I actually do have a large ink on linen drawing of a small sloop designed and drawn by Fred Martin dated 1903. I see new stuff all the time - or maybe I forgot I saw it before - age can do that. Kurt
  18. Right on. Lack of research - even a cursory look at photos would have helped the colors - except the pump being hidden from easy view. I initially got up to walk over to my stash of kits when I realized this is a new kit - not a recycled AMT kit - enclosed jump seats are much more recent than the AMT kits.
  19. Closed cab - pretty close to identical to the one you showed.
  20. I know where you can buy the 1956 ALF pumper I first drove if you still want a big red collectable. When I am in my shop here at home I can see the house but not the back yard where it is parked. I see the front end every time I leave the house and go south and wonder why it isn't covered or in a garage. The guy who bought it was on the FD with my Dad and for a couple of years while I was on the local Dept before going full time with the adjoining town. He's gone now and either his son or daughter now live there and don't know what they have. Or did you mean a 1/25 scale ladder truck?
  21. It's going great. Nice work. The part in question is the pump panel - and the drivers side with the gauges etc. The Engineer controls the pump from this position. The other side has a connection or two for additional hose lines. There is nothing inside except the connections to the pump, the wiring for the panel lights, pressure lines to the gauges, etc. Also inside are the water pipe lines to the hose outlets on both sides of the vehicle and the pipe up to the hose reel that sits atop the box. The hose reel is for what we called a booster hose. I have never seen any color of these high pressure hoses except a muted dull red and black. The pressure on this line can be up to 1,000psi - depending on the pump mfg. Most city FDs around here don't use booster lines today but rural areas with field fires do use them. The engineer controls the pressure delivered to the hoses by engaging the pump before leaving the drivers position - if they intend to use high pressure on the booster line he engages the 3rd stage which delivers high pressure after the incoming water enters the 1st stage and the incoming pressure is increased there and then enters the 2nd stage where the pressure is increased further and then to the 3rd stage where it is increased yet again. If the fire is one where quantity is needed vs pressure only the first two stages are engaged. These pumps are centrifugal pumps and I have described how the pumps I have operated are operated. I never operated a pump after August of 1984 when I was injured on the job and when I came back they promoted me to Div. Chief so I might be a bit rusty on specific details. BTW, every fire pump I have ever seen is red. Doesn't matter if it's on a pumper or in a building. ALF purchased their pumps from a pump mfg. who make pumps for many uses. Fire pumps undergo extensive testing to get approval as a fire pump and then each pump is tested to strict protocol at the factory before shipping. Fire pumps cost a lot more than a pump with the identical components that isn't meant for fire service use. These other pumps cam be almost any color but red. I have been inside pump mfg factories and have seen green, blue, orange but never a red one outside the dedicated space they use for the fire pump assembly and testing areas. Most firefighters never see the inside of a pump mfg facility and my seeing the making and testing of fire pumps was because I was the Fire Prevention Division Chief and had to approve all fire pumps for the large buildings in town so their certification was something we had to take very seriously.
  22. When I started driving I had to borrow Dad's car for dates - between 16 and 18 mostly only Friday nights because that was when the local FD met and Dad didn't need the car. The one drawback was the FD radio had to be on at all times - if I was late the radio would come alive with 'Kurt look at the time!" and I better be home very quick after that. I responded with my Dad from home to the fire scene from about 13 on until I got on the FD at 18 - at which point I drove to the firehouse on my own. My job at the fire scene initially was to ask a neighbor to use their phone, call the fire house and relay messages between the Chief and the firehouse. Then we got the first radios and the Chief's "portable" radio required a sling to go on the shoulder - so I got to stand next to him with the radio handy. Shortly after that we got radios in each piece of apparatus - I was about 14 or 15 then.
  23. I am following. The first truck I ever drove (1965) was a 1956 American LaFrance Suburban Pumper - the Suburban model had the pump panel on the right (curb) side for the protection of the Engineer. I got on the local volunteer FD the day I tuned 18 and the next Friday night I took part in driver training. The truck we had was of course much different than this model - more rounded front end and the jump seats behind the driver and officer were single back facing seats w/o doors on the side just open to the rear. Nice and toasty warm returning from fires in cold weather but pretty darn hot when the seasons were reversed. The big V12 engine put out a lot of heat. Dual spark plugs from dual magnetos. I was told they used a old Packard engine. The American Lafrance Fire Apparatus Museum is filled with various types and years of American LaFrance apparatus at Charleston, SC. It was about 1/4 mile from the NRG Conference hotel when we met there in 2013. If you are in the area it's worth seeing. There is even one truck there I have ridden to fires on - the old Snorkel Squad One from the Chicago FD was built by ALF on a GMC chassis - we used to ride with Chicago for training and SS1 was the busiest CFD unit. http://www.northcharlestonfiremuseum.org/ Back in 1956 when they got this pumper American LaFrance presented my Father with a custom built Tonka Toy version of the pumper (made strictly for American LaFrance) that had a plunger type of pump with a coiled Booster Hose that squirted water from a small tank. I wish I had the foresight to put it on a shelf back then but what 9 year old kid isn't going to play with it instead? I used to put on my leather Kairns fire helmet (we each got one when the FD got new helmets) a rain coat and play fireman - I even used the helmet to carry water to the play area in the back yard - at this stage I don't remember what the water was for but I have vivid memories of carrying the water in the helmet and how that eventually ruined the helmet - there are also collector items but not as much as the truck. I have two of the leather helmets that made a comeback (pre-OSHA applying to FDs) exactly as they were originally made that I wore during my career. One is real nice condition the other has the metal piece that holds the shield with the Dept. Name and ID number on the front smashed down distorting the leather shield a bit - a floor above came down on a couple of us w/o injuries other than minor burns we didn't even notice until later. Adrenalin is wonderful - at times. The photo shows my helmets from my career. The leather helmet I got when I first joined the FD where I spent the next 27.5 years - is at the right. The helmet they issued me when promoted to Engineer (the driver and pump operator though I spent most of my time as an Engineer driving the ladder truck) is at the left. The white helmet is my last helmet when I was promoted to Division Chief. Just noticed the cobwebs - this is above the man door in the garage at the bottom of the stairs from my shop. Will get to them someday.... Sorry to have hijacked the thread but get an old fireman feeling nostalgic and I am surprised I didn't go longer.
  24. Maybe Gus would loan you his trained rigging fleas to hold the buck for riveting.
