dafi
Everything posted by dafi
  1. Great work and tremendeous speed! For the rope sizes consult the AOTS MacKay, but take care, the dimensions are in circumderence and not diameter! Scale down the different sizes to about 5 different ones, that will do the job imho. All the best, DAniel
  2. Wonderful work! Congratulations for the result 🙂 All the best, DAniel
  3. I had already used this technique on my Victory. Here on the left is the picture from which my avatar comes and next to it a picture of the lower deck of the Vasa Coming in the right direction for me. Just a 100 times smaller 😉 XXXDAn
  4. So, I continued with some gardening. When gluing, finger cots are recommended, just cut off the tips of an old rubber glove and put them on again individually ... ... but how do I get all the cherry blossoms off the deck afterwards? After gluing, the whole thing looks very messy at first, so I first go over it with the scraper to remove the worst of it. Then comes the sanding block with the coarse 40 grit sandpaper ... ... then the 80 grit and individual planks that are sitting too low are scraped off with the thin chisel. Here are the two states side by side ... ... but slowly it becomes a deck ... ... if I hadn't run out of planks http://www.shipmodels.info/mws_forum/images/smilies/icon_wink.gif Happy Easter! XXXDAn
  5. And the next step was planking the deck. The adhesive foil is placed on the black side and the foil is carefully peeled off ... ... the planks with the black side down are glued on with superglue ... ... and then sanded to the same height with 80-grit sandpaper. And the parquet is finished. And now diligence work for the rest of the deck. XXXDAn
  6. Thank you Eduard, watch this space, who knows 😉 Meanwhile the hopefully final version of the long guns came out of the printer. All the important details are in place, including the cap square key and the coins's handling cord . Also, the supports are now all in such a way that the part almost falls out by itself after printing and hardly any rework is needed. If you cut out the coin and the stool bed, the gun can also be secured well over the port. But other positions also are possible 😉 Parallel to that I cut planks, glued them on self adhesive foil ... ... and sprayed it black. More about this soon. Then the grain structure of the decks was smoothed with sandpaper ... ... and I marked the approximate position of the deck beams underneath. Even if the position of the passages to the orlop deck do not quite match the plans, the concept could be transferred. These beam lines form the alignment of the plank joints, as these had to be nailed into something, as in between the beams the nails would have hung in thin air 😉 Best regards, DAniel
  7. Hello Tom, nice to see you here! Great start and keep on having fun modeling, that is all it is about 🙂 All the best, Daniel
  8. The main deck guns of the kit are even real beauties compared to the carronades of the upper deck. From a construction point of view, they are supposed to represent the current state of the equipment, but unfortunately their appearance - especially the barrels - is miles away from the original. That's why I took a little break in my day-to-day business some time ago and programmed new ones, but unfortunately I never got around to presenting them due to lack of time. Here is a comparison: Their construction is based - according to Marquardt's AOTS - to the carronades used from 1795 onwards, which were inspired by the British design. Also on the bottom one finds everything your heart desires: the two-stage slot and the pivot pin with the retaining washer And a dafi certainly wouldn't be a dafi if it didn't also play a bit 😉 The gun above is classically printed as one piece. Of course I couldn't resist to print this additionally as a kit - one is a model builder after all And that gives a whole new set of opportunities. According to contemporary plans, the top carriage can also be pivoted, possibly quite convenient for maintenance or in case of problems with loading. Also the whole gun can now be aligned sideways. If the gun is swivelled too far, the carriage collides with the ship's side. That is why there is a second pivot hole further inside to be found on contemporary plans ... ... with which the gun can be elegantly moved to the wall in order to lash it there. If the slide is pushed further back, even the port can be made clear. And if you want, you can also depict completely different conditions. As always: It remains exciting XXXDAn
  9. And since then, I've been itching to put these parts onto the deck. Since I still have to do some research on my Vic, I simply used this compulsory break and lifted the pretty girl onto the tinkering table. First I glued the three deck parts together and reinforced them. Funnily enough, the middle part is 1 mm thicker, so the other sides had to be relined. Then cut off the rim for the positioning of the guns ... ... removed the gratings ... ... and the stubs for the ropes had to be cut off as well. Then, while trying to fit the deck, I noticed that the supports were much too far apart and the deck sagged in several places. So I put a small batten atop the supports for alinement and added some extra supports. I dry fitted once more and noticed that the deck did not sit properly. This is probably because the hull is curved at this point and thus the supports were at an angle. But a quick re-pinching quickly eliminated this and the deck could be laid flat. Then the exciting moment, the guns were put on deck ... ... and they are sitting nicely in the middle of the port It remains exciting. Best regards, DAniel
  10. Welcome to the Jungle! Attentive observers had already discovered the hull of the USS Constitution in my shrubbery for some time. But who now expects a FITZCARALDOOOO downhill is wrong for the time being, it actually goes on in a civilised way The kit has been lying around for quite a while, as it is really great in many aspects, such as the hull, but in others it does not fully meet its own claims, especially with regard to the guns. What could be more obvious than to choose these guns after the purchase of a new printer and to program them in a contemporary correct way. The results were promising ... ... and with a little colour quite convincing ... ... especially compared to the originals from the kit. Grandpa, what big fingers you have!
  11. @Ian_Grant I think about 5 🙂 Mainbuild 1910 Technology carrier for etch and print oob from someone else for reference new one no wip yet XXXDAn
  12. Used the nice weather to sand outside. Good for the tinkering cave, the nose and the soul. Just enjoy. XXXDAn
  13. After raising the bow and stern, it was time for the upper deck. To do this, remove the deck, fix the polysterol strip for the new bulwark with clamps ... ... and scribe the curve of the lower deck with a blade. Then set the cut, put the deck back in, clamped the fitted bulwark piece again and scribed it with a block on the inside to have a uniform height above the deck. Then removed, cut the height cleanly and ... ... glued in place. You can hardly see it, there are little wooden blocks glued under the clamps on the outside of the hull, just like on the bow, so that it is flush on the outside. And slowly it's becoming "something" 😉 The elements on the deck are still orientation aids made of cardboard and not dimensionally adjusted, but you can already see where it's going. The raised bow ... ... the quarterdeck with Nelson's sloop under the poop ... ... the small guard house, behind it two flag boxes still missing and probably the biggest surprise for the most of you ... ... the forecastle over the forecastle, the fore-fore-castle so to speak. Hardly visible from the outside ... ... unless someone is standing on it :-) XXXDAn
  14. Thank you gentlemen 😀 One already suffers as a model builder 😉 And when I'm not doing such nonsense, I'm busy at the moment with the elevations of the sides. During the rebuilding in 1816 the high round bow was installed according to Seppings. Everything was first a cardboard template. Here is the immensely high new bow ... ... then along the upper deck ... ... and the built poop. A face that only a mother could love - or a dafi http://www.shipmodels.info/mws_forum/images/smilies/icon_wink.gif Then transfer of the masks to 2 mm polysterol ... ... warm up this round nose part ... ... and pre-bend it. But 2 mm polysterol doesn't quite want to go the way I want, even with heat, so I cold bend it over the edge of the table until it's nice & soft. And for further help I had already installed supports inside ... ... and since I still have concerns, I also glued something on the outside to hold it up, no, it's not hawse-pieces, that's coming off again http://www.shipmodels.info/mws_forum/images/smilies/icon_smile.gif And somehow it was important now that I got the next parts done, just so for the sore soul ... And now the worst part for me: patience to let it dry well! XXXDAn
  15. Actually I only wanted to cut a new upper deck. To do this, I put the large 2mm polysterol sheet on the table, pushed the model to the edge and ... ... must have been one of the active gale-force winds, I can't explain it any other way. First look, everything went well. Second look, no, 2 windows are missing, stupid but no problem, I have already produced enough replacements. But then ... ... I had glued the struts for the elevation of the bow on a section of the upper battery deck shortly before. This, of course, was also loose. And when I tried to reattach it I noticed, ****, the hull is suddenly 2 mm wider than before !?!! The two upper decks were only put in without being glued in order to be able to take them out again for the installation of the window panes. But the gap on the side is clearly visible. So I did what was only thought of much later, cut the "carriages" off the windows ... ... and the upper 2 decks were succesively taken out and the culprit was discovered: the lower gun deck. This was the only one glued in and was it broken and tilted and so could not flex back. So I drilled some holes and used hooks to lever the deck back up ... ... and re-glued it well. In the meantime I found 6 more loose windows, but they could all be kept in situ, only one at the very front I had to glue in a replacement part. The other decks are now also back inside and I could continue. XXXDAn
  16. And we continued with sanding and filling ... ... there is still a long way to go ... ... until its smooth as a baby's bum 😉 XXXDAn
  17. Wonderful work 🙂 For the netting beside the heads, there is the middle stanchion for the top bar in the etch set. All the best, Daniel
  18. Since I have once again scored some stupid mistakes, I recant all and everything and claim the opposite 😉 First for orientation the side view with port numbering, the original photo is mirrored, as the following interior views also show the port side. First the fat mistake: when I was sitting in front of the hull and wanted to sand it, I suddenly thought, oh my dear, since when are the signal guns not in the upper deck but in the middle deck? Its because I had mistakenly assigned the following picture to the upper deck because of the gun mounts :-0 But it is clearly the middle deck, also recognisable by the top of the forward capstan. What confused me were the guns behind the signal guns. So I looked at the photos again and rediscovered a detail I had already had forgotten a long time ago: Windows 4,5,6 with the yellow circle are the signal guns of the middle deck, followed by an obscured window and then in 8 and 9 guns! The interior view shows 3 guns at this place. Further beyond a gun can be seen at the very back, which has the breechline lying on it like in this picture: You can also see that there doesn't seem to be a booth at the entrance port, only a small indistinct structure can be seen. I have also numbered the picture of the upper deck according to the outside view for better understanding. The pipe inside is between ports 7 and 8. The pipe outside can be seen just before port 9 and is probably hidden behind by the hanging knee. As described before, I suspect a booth around of window 10 due to the shadow on the deck and the 2 guns - also guessable in the deck shadow - in 11 and 12 and behind the bulkhead gun 13. It remains exciting, DAniel
  19. I believe that the warping of the bars comes from the movement of the build plate: the dynamics of the resin whilst going up and down. And seen how soft the uncured resin is, and also by the fact that these bars are 0,36 mm in diameter with a height of 7,6 mm it i a miracle that even this result is possible 🙂 I adapted the basic size of the frame to actualk used windowframe, that is 1 mm lower and increased the thickness up to 0,4 mm and will see what the next print does. The new thickness is 10% more 😉 all the best, DAnniel
  20. Here is a small excursion into the interior life of the Victory around 1900. The difficulty is that there are far fewer pictures and it is much more difficult to put them in chronological order. The first picture is of the upper gun deck, the photographer standing at the level of the foremast chains and looking aft. So far this is the only picture showing the signal guns on the inside. All the supports for the deck beams are from iron. The space is empty so far, which seems to be the case in other interior pictures. A picture further back in the ship - from about the middle of the waist - shows the 12-pounders. The structure behind the gun racks is interesting. My interpretation based on the shadow on the deck is a cabin in front of the red outlined window, the light area behind it could be 2 windows with the other guns, and then the partition to Nelson's cabins behind. Plans of 1830 show a bulkhead with doors at excately the same place, and as in the pictures the doors open to the head. So the shadow should not be the door´s one. The chute outside should be between the last and the second last gun, but I can't find any indication of it on the inside. Possibly the small bend to the aft is a sign that a pipe comes from the direction of the window and the cabin, which could indicate sanitary rooms. Another image concerns the two heavy Tarfalgar guns in the mid-deck, recognisable by the two-piece window and the larger angle of the ship's side, marked on the outside picture in the green frame. Whether the view is aft or towards the bow is not yet clear to me. Either the structure behind is the bulkhead to the officers' cabins or a booth of the entrance hatch. But you can see that the gun carriage sits very low and that the gun therefore rests on the port frame below. On the other hand, on pictures of the upper battery deck you can see that the carriages there have significantly higher proportions, which also makes the gun barrels sit higher in the port. Here are two more pictures that I think are from the upper battery deck: One is probably the oldest picture of the series, showing Nelson's cabin, and the rooms in front of it ... ... and once probably also mid-deck with the heavy Trafalgar guns, judging by the slope of the ship's side. It remains exciting 🙂 XXXDAn
  21. Thank you for the hints Kevin, I will have a look at it! Those bars are 0,36 mm, I know that I was going to the limits, as I always do. For a short distance even thinner bars are possible, I realised 0,2 mm is even under best conditions a realistic limit 🙂 This was the white Resin from Anycubic. That is not as good as the black one from Anycubic, that I usually take. The black one has almost no failures, whilst the white one sometimes (rarely) loses the parts from the building plate. Also I have the feeling that the black prints are sharper in the details like corners etc., but that could be a visual desception. In the very start I used the grey eleegoo standard resin and had big trouble as nothing wanted to stick too the building plate, then I tried the black Anycubic with the same settings and never had troublke again 🙂 I do only take the resin out of the tank if a part got lost, otherwise I leave the stuff in and have dozens of prints without any maintenace, even I left the resin in the tank for 2 months without printing, buildingplate down and machine well covered from light, and did not have trouble, just put the plate up and down several times to mix up the color particals well again 🙂 All the best, Daniel
  22. In the meantime, the white parts are also finished. And always these brain pictures. These were the two Trafalgar guns in the first attempt ... ... but when I checked the window dimensions again ... ... crap, the panes only have two parts. Three parts were at the guns in the upper deck. Then glued in the frame as before ... ... filler pieces glued in for better support ... ... and filled with putty:-) This deck is also only inlaid, because I will have to to take it out again and work on the inside later to put the window panes into the frames. For this I will trim back the carriages. That's why I made the new triangular cut-outs on the frontside of the carriage. And I also did a test print. The foremost window in the lower deck had window bars. These are very fine. And they are to be fitted into the already fixed frames. You can see, however, that they are so fine that slight distortions occur when printing - since no supports can be used. Since the frame has too little undersize for its hole, this is of course exacerbated. And then again AAAAARGHH! With the dimensions of this bit, I got the first rectangular version and not the frames with a lower height that were used in the end ... ... ok, can be corrected with the next print, maybe the distortion will be better too. XXXDAn
  23. While the printer was finally processing white resin again, some more planning and work preparation went on. The bulwarks of the open decks will have to be built. This has to be placed on top of the plastic hull shells, so construction, positioning and stability are a challenge. That's why I first filed gaps in the deck support for supports of the bulwarks. Then the supports are glued in place and a 2 mm polysterol plate is put on top. Clamps to press the plate to the support and wire to press the plate down to the hull. Then in the deck, slots for the supports were cut ... ... and the interior panelling added. But it looked too thick compared to the photos. That's why I removed the panelling and the supports and it still holds perfectly. I sanded the cut edge again to get an even gluing surface. Since all my big files have a very distinct convexity, I took a stable piece of wood and glued it on with sandpaper 🙂 XXXDAn
