Everything posted by rafine
Back home, and work has begun. It appears that I may be the first to use the the laser cut keel former and bulkhead set from Chuck. I'm also using the laser cut parts for chapter one. While I admire all of the great work being done by the group in cutting out their own parts, I am at an age ( just turned 80) where I would rather spend my time on other aspects of the build. BTW, the laser cut framing parts are virtually perfect, and required almost no sanding to fit snug and true. I began by assembling the stem parts and the tapering them. I then assembled the keel former and added the rabbet strip. Then, I tapered from the bearding line using a chisel and sandpaper. Next, I attached the stem assembly and the keel pieces.Finally, I drilled for, and added black monofilament line for the keel bolts. The next order of business was to construct the build board, using laser cut parts for the supports. The last task was to dry fit all of the bulkheads to the keel former. Now, it's time to glue in the bulkheads and fair up the hull. Bob
Congrats Mark. A beautiful piece of work. Bob
- 331 replies
- nuestra senora del pilar
- occre
Thanks so much Thomas. Bob
- 78 replies
- medway longboat
- Syren Ship Model Company
We're back in Florida, and the longboat remains in New Jersey. Before leaving, I was able to make the mast, boom and gaff, which were all made from the square stock in the masting and rigging kit. I also made the horse at the stern from wire and mounted it. I was able to mount the mast, make eyebolts and hooks from wire and make the belaying pins. We are planning to be back in New Jersey for Thanksgiving and hopefully I will get a lot of the rigging done at that time. I will do the stropping of blocks and deadeyes here in preparation for that. Bob
- 78 replies
- medway longboat
Thanks so much Art for both your comment and your concern. We will be staying in New Jersey until the storm situation is over. We have someone taking care of the house ( closing storm shutters etc.) and I wish the best to all of you in the area in a scary situation. Bob
- 78 replies
- medway longboat
Thanks so much Rusty and the "likes". I'm really looking forward to starting Winnie, as well. Bob
- 78 replies
- medway longboat
Thanks so much Nils, Grant and the "likes". Bob
- 78 replies
- medway longboat
I've now completed the hull portion of the longboat. This included making and adding the windlass, making and adding the block on the stem and the roller on the stem, and making up and adding the rudder and tiller assembly. The last thing was to make and add the thole pins. I've started to make the mast and spars, which I hope to complete before I leave for home. Bob
- 78 replies
- medway longboat
Great to have you back Ryland. I've had two bypass surgeries, so I understand the feeling well. The good news is that my last one was twenty two years ago and I'm still here. Obviously an unpleasant situation, but you have a lot to look forward to and you'll feel much better. Do your rehab, and enjoy your modeling. Bob
- 263 replies
- Medway Longboat
Thanks so much Nils and Jason for the nice comments and thanks also to the "likes". Bob
- 78 replies
- medway longboat
Thanks so much Art and the "likes". Bob
- 78 replies
- medway longboat
David, say what you will about difficulties and redoes, it was all worth it. This is a truly beautiful model, and a reflection of your skills. Bob
- 145 replies
- model shipways
- charles w. morgan
My time in New Jersey is growing short and there is much to be done on the longboat. I've now added and painted the cockpit seats and transom knees, and made up,notched and added the thwarts, including the hardware on the thwart supporting the mast, and the thwart knees. Now it's time to face up to doing the windlass. Bob
- 78 replies
- medway longboat
Thanks so much Bob, Dave and the"likes". Always appreciated. Bob
- 78 replies
- medway longboat
