Posts posted by rafine
Thanks Thomas. The cannon barrels are painted with what little I have left of my Pollyscale engine black (no longer available).
I've now completed another section of the quarterdeck framing. Before doing that, however, I had to do a chart of rigging sizes so that I could attach the main lower yard sheets to the bulwark cleats that would be inaccessible under the deck framing. The rope sizes were determined by using the tables and formulas set forth in Lees. Rather than using a spreadsheet, I chose to mark the sizes directly on copies of the sequential rigging drawings from the Essex AOTS. I then made a table to convert these sizes to correspond to the rigging line sizes available from Chuck.
I then used the appropriate line size to do the sheets and ran them through the bulwark sheaves and attached them to the cleats. When this was done, I glued down the aft portion of the deck framing, which previously had been left sitting loose. After that, I built two further deck sections off the model, installed them, added hanging knees to them and then filled in the open portions with lodging knees, ledges and carlings. The whole assembly was given an application of Wipe-on Poly.
The final portion of the quarterdeck framing will be done in conjunction with work on the pumps and mainmast bitts, which will be the next items of work.
Bob
Thanks Terry for the kind words. I second the suggestions that you contact ME directly about replacement parts. I've heard nothing new on that front.
Bob
Thanks for looking in Evan, and for your generous comments.
Bob
Thanks so much, Patrick and Sjors. Always appreciated.
Bob
Thanks very much Tim. The gun barrels are painted, not blackened. The Birchwood Casey that I use to blacken doesn't work on the white metal.
Bob
Thanks so much Gary, B.E. and the "likes".
Gary, the blocks are 1/8" (3mm). They appear smaller than kit blocks of the same nominal size, probably because of their shaping and their smaller width. They are beautifully made and a pleasure to work with.
Tedium may have it's rewards B.E., but I want no part of any model that has more guns than this one, particularly at a small scale.
Bob
- Mirabell61 and Martin W
2
Another small, but tedious, step forward. The next batch of guns have been made up, mounted and rigged. I also added some more deck ringbolts. As with the prior gun batches, these were done with the kit barrels, modified Lumberyard carriage kits and blocks and rigging line from Chuck. I have one last batch of 8 guns left to do, but these will wait for a while.
Next up will be work on the pumps and the bitts for the main mast, as well as the remaining framing for the quarterdeck. I'm also working on the sizing of the various rigging lines, so that I can add the lines that need to be belayed before their attachment points become inaccessible because of the deck framing.
Bob
It's looking really good Gary. I like that companionway. It looks right.
Bob
Your usual superb work Remco.
Bob
Thanks so much Tim. I'm sorry for the late reply. Good luck with ME on the Essex.
Bob
It's great to have you back Pete. This is a wonderful model. Are you finishing her and what has become of Fair American?
Bob
Rich, the steps were not pinned.
Tim, I don't know whether ME has made the necessary corrections to the kit yet, or what they are sending out now. I would inquire if I were you. I ,like a number of others on this site, get my wood from Hobbymill. There is a link to the website on this site.
Bob
Tim, with some limited exceptions ( the laser cut gratings, window frames, transom, rudder and stem), all visible wood has been, and will be, replaced with boxwood, holly and some pear. The lower hull (covered in copper) was planked with kit basswood. The framing was done with kit plywood parts and basswood.
Bob
Frigate Essex by Rafine - FINISHED - Model Shipways - Kitbashed
Thanks very much Grant. As to the "smart thinking", I chalk that up to the law of averages -- you can't be stupid all of the time.
Bob
