Everything posted by Seventynet
Greetings, Could someone confirm whether the 2 top timbers for Ha are in the template shown below? I have no idea where they have disappeared but if someone could confirm that they are in fact what I have shown I can simply trace and cut new ones. It shouldn’t be too hard to interpolate the notches. You can see that I cut the top timbers out of card and they seem to fit but it is hard to know for sure. If these are not Ha top timbers can you show where they are? Thanks in advance, Ian
Hi Paul, I don’t know how I missed this build. What organized, precise work you are doing! I need to take lessons from you on how to do a great build log. Keep it up! Ian
- 201 replies
- Oyster Sharpie
- first scratch build
Greetings, Let the real work begin! I am ready to start the frames. I realized that the keel I had made a year ago is slightly thicker than Chuck’s but I think I can get away with a little tapering at the stern when the time comes. The rest of the fittings were straightforward although I had my fair share of screwups. I decided to employ a higher build board jig so that the stern and stem posts were clasped at their tops - though I know that these extensions will get in my way later. I will interchange the lower jigs when the time comes. Cheers, Ian
Hi all, Here is my slightly modified version of Chuck’s Speedwell based on Greg and David’s plan. Over a year ago I had planned on upscaling David’s drawings to the same scale as Chuck’s and proceeded to build the keel assembly. After I made some headway I got wrapped up building a CNC mill and learning how to program it. A year flew by as I watched Chuck’s genius in putting together his kit. I could not resist the temptation and decided that I would go the kit way instead, except for using the boxwood (Castello) keel I had already gotten a good start on. Although Chuck’s version of David’s drawings (scaled up) are very similar, they are not identical. However, the keel assembly is close enough (I hope 🫣). I used a router to make the rabbet. The false keel is ebony. I have used a Mylar copy glued onto my building board. Cheers, Ian
I puzzled over this for a long time as well but for the life of me I can’t remember what the solution was. I am away from home until next week and will get back to you when I have a look at my model and plans. Hopefully David will lend his guidance before that. You are doing a great job so far. Best, Ian
- 89 replies
Beautiful job, Doc! I greatly enjoyed watching this progress. Ian
- 143 replies
Paul, just a beautiful job. You should be very happy with the result. Can I ask what’s next? Ian
- 72 replies
- Glad Tidings
- Model Shipways
Beautiful work! I enjoyed following your progress. Thanks for sharing. Ian
- 475 replies
Thank you, Bob! Every time I visit my daughter’s place and see the model displayed I think it has to be one of my favourite builds. Ian
- 107 replies
- brazzera
- marisstella
Very, very well done, Bob. Congratulations you should be very proud. Ian
- 111 replies
- Nonsuch 30
- Model Shipways
Absolutely masterful job, Greg and beautiful carvings David! I look forward to building this and hope I can come anywhere close to this. This build log and your books will certainly be a massive help. Ian
