Posts posted by Chuck
This 26 foot long was designed based on a contemporary model in the National Maritime Museum shown below. This longboat was used circa 1750-1760 and was typical of this type of small craft. Plans for this model and MS kit prototype were drafted based on the contemporary drafts from the period. The longboat has been decorated to match the NMM model that inspired it. Even though this model was inspired by another, many other color schemes are possible.
There are many more contemporary models that show various decorative themes. Another very good
source of information on these small boats is “The Arming and Fitting of English Ships of War” by Brian Lavery. This book discusses the many details you sometimes find on these Longboats.
Another good reference is "The Boats of Men of War" by W.E. May.
Some references to these book will be mentioned throughout this project.This scratch project was the prototype for the Model Shipways kit. An image of the finished model is posted below and can be compared to the contemporary model above. I Also below you will find the PDF instructions for the kit which has more details.
- Mumin, Nikiforos, Jack Panzeca and 2 others
5
Check here.....the question was asked already...
http://modelshipworld.com/index.php?/topic/279-size-of-photos/
Please read through all of the topic titles in this forum first before you post the question again.
Thanks
Can you give us the info and links where you had the stencils made???
Chuck
Rusty...Its like seeing an old friend again....I am so glad to see it here.
Chuck
Now I only had to add a few small details to finish it up. This was a relatively short project but was a lot of fun to build.
I created the oars in two pieces. The handles were shaped on my dremel which I used as a poor man's lathe. Once it was chocked up....I sanded and filed the square strip until it was rounded to spec. But I left the square section untouched to create the final look which was common for the period.
The grapnel was a casting from Model Expo. Seeing as this was a prototype for a future kit, I was asked to use one that they already had in stock. It was a nice fitting and was perfectly scaled.
That finished off the project. I turned the display pedestals with my Dremel because they were small enough to chock. They arent a perfect mating pair but look OK to my eye.
Thanks for looking and as always, comments and questions are appreciated.
Chuck
- GrandpaPhil, Petit Loir, Mirabell61 and 3 others
6
Next up was the rudder. It was straight forward to cut it out of a sheet of boxwood. Then it was tapered so it would narrow aft, and the fore side was shaped and slotted for the pintles and gudgeons.
I used styrene once again for the pintles and gudgeons. Its easy to bend although you must do it slowly so it doesnt break. If you go slowly it gives the plastic a chance to bend rather than fracture. It drills remarkably well. The bolts heads were simulated as I mentioned earlier.
The tiller was shaped by hand. I patiently filed and carved it from a larger piece of boxwood. Once the rudder was placed in position, I could glue the the decorative transom in place as well. I created it by sculpting the details on a thin sheet of wood with Sculpey. The wood blank was 1/32" thick and cut to the shape of the transom. I added the sculpted details a little at a time and baked it in my toaster oven to cure it.
Once it was completed I made a mold and casted a one piece resin copy which is what I used on the model.
Chuck
I built the four oarlocks next. They were made with two pieces as seen below. They were glued on top of the cap rail and then painted.
To finish off the details on top of the cap rail, I constructed the paneled splash boards by the cockpit. Each splashboard was mad using two layers of 1/32" thick boxwood. One was solid and the outboard one was cut out to create the panels. Once glued together they did a good job of simulating panels. They had to wet down and bent with heat from an old hair dryer. They were bent to conform to the curve of the cap rail. Finally...they were carefully painted as I tried to leave the center panels natural.
Chuck
- Mirabell61, avsjerome2003, Archi and 1 other
4
Looking great. Nice job on the plating...that came out particularly well!!
Chuck
What a beauty....I am so glad you posted the log again!! Thank you sir
Chuck
- ModelExpoOnline and Nirvana
2
Thanks Guys
Ryland...yes they do...the photos show a lot of detail and every little paint smear and mistake...LOL
I am using many pictures because my local New Jersey club will building this model as their next community project. We have fifteen signed up to build it. Its going to start in a few months. I guess I will be building a third Pinnace model very soon.
Chuck
- Archi and Mirabell61
2
Yupp....But wait until you have the inboard planking on....I would aalso use that second layer of the sheer strake to adjust the height of the shear if need be to match the other side...If your starboard is a little low....then add the shear strake a little higher to compensate. Then put the cap rail on top of that after you sand teh extensions down later. But I am only talking about a slight correct if need be. You see how the bort side dips a bit where those extensions are higher?? The frontal bow shot shows that.
Chuck
Looks very nice...The planks look properly done in relation to the bulkhead extension tops. Do your best to make sure that they are consistent from port to starboard. Especially at the stern. The bow look fine.
Chuck
Love seeing this build log back...thank you so much Alex
Chuck
I use Corel Draw to draft all of my plans too. For the friezes I just used the ordinary weight paper that you print day to day stuff on. Its thin and I didnt want to go thicker. It also prints flat with no sheen like some papers. I do however sometimes go with an eggshell color but I didnt do that this time. I will have to send you some files via email some time. I am sure you could laugh like I do when I read that there are over 100,000 lines drawn on a plan sheet. Its nuts. All done one at a time. For plans I think Cad is overkill. 2D is fine for me. AlexM also uses Corel Draw. I have taught others in a few hours how to use it to draft plans over the phone. Its a nice program.
I think a min tutorial is going to be in the works...its cheap if you buy an older version or get the student discount...A copy can be had for $99. So I like to say good things about it.
Chuck
Thank you so much Michael..
The next task was to start detailing the outboard doo-dads. First up was the frieze I recreated the frieze on my computer using Corel Draw. Then I printed it out on my inkjet printer and used some fixative to prevent smudges. I actually use hairspray because it has some UV protection and its cheaper..I prepared one in red and another in blue. I decided to use the red one.
With the paper frieze in position I was able to use the bottom edge as a guide to glue a molding strip across the hull. It was scraped to create a beaded edge.
The transom was carefully painted red but I left a 1/16" natural border around the outside.
At the bow..I added the protective iron strap. I sometimes use paper for this but this time I used a styrene strip. It bends easily enough and doesnt fray when you drill through it. I drilled a series of holes to insert some 22 guage wire. I snipped off the excess so the "Bolts" would stand proud of the surface. I carefully painted it black afterwards....you can see that it could have been a bit neater. I think I cleaned it up a lot after taking that picture.
- archjofo, Blue Ensign, Mirabell61 and 1 other
4
Great to see you start the log...Cant wait to see it take shape. You know where to find me if you have any questions.
Chuck
Then it was finally time for some less time-consuming details inboard. I added the knees on each side of the thwarts and the steps to get in the cockpit. I left these unpainted as Thought it would look better. I also added the locker hinges on the cockpit seat, the iron rings bolted on the floorboards and the stanchions under each thwart. It was finally coming together inboard.
For making the rings...I created the rings from 22 gauge black wire. Then I bent another piece around them as shown below. After they are inserted in the floorboards it looks more to scale than if I used a second eyebolt and inserted the ring. The eye of the eyebolts always look too big to my eye.
Chuck
- avsjerome2003 and Archi
2
Next it was time to create the decorative panels inboard. I used thin strips of boxwood. 1/32 x 1/16". These were scraped to give them a nice fancy profile. The corners of each panel were mitred to keep things neat and tidy. This took some considerable time to complete. As you can imagine...it required a lot of paint touch up. From this point forward I used yellow carpenters glue exclusively because it made clean up easy. After each part of a given panel was glued into position...just a wet brush could be used to remove any excess that squeezed out.
- Michiel, Archi, avsjerome2003 and 2 others
5
When the thwarts were all done...I added 1/16" x 1/16" strips between them. These were filler strips for the inboard planking so I didnt have to notch a wider plank. Then I planked up to the sheer line and painted everything inboard.
The cap rail was added. I made it over sized so I could create an overhang outboard. It was sanded flush to the inboard planking. I then took a scraper to make that overhang beaded. It adds a nice touch. To create the scraper I used various needle files and such. You can see a picture of the scarper posted.
Chuck
- Archi, avsjerome2003 and MikeB4
3
Now it was time to start adding the details...I added the cockpit seat back and painted the risers. The risers are the pieces along the inside of the hull and the thwarts (seats) sit on top of them. With the seatback shaped I added the thwarts and the cockpit locker and seats. The thwarts had a beaded line scribed down both sides. this was easy to recreate. I used a sharp awl and ran it down the thwart edge with a steel ruler used as a guide.
The risers were painted first because it would have been tough to do so after the thwarts were added.
Chuck
Now that the hull is planked, I can remove the bulkhead centers to reveal the framed interior. The centers are held in place with small tabs. Once I file through the tabs along the top of each bulkhead (one on each side), I simply bent the center downward to snap the third tab on the bottom of the bulkhead. Then the bulkhead centers could be removed.
This was done very carefully and slowly. I chose not to use a blade or a saw because that tends to pull the center of the bulkhead and split the frames. I find the file works best and I use a light touch when I get close to finishing each tab. The inside was faired to reduce the frames down to a consistent thickness. You can see all of the glue smears between the frames. After the interior frames were faired, I scraped the inside faces of the outboard planking to remove the smears. This took quite a long time was well worth it. I used the blade shown. Its curved profile matched the concave interior hull shape. Then a coat of wipe on poly was applied. It really cleaned up well!! I was quite pleased.
Then the floor boards were added along with the cockpit floor. To finish off this step I added the risers. They were carefully pre-bent and spiled to make installation easier. I used the outboard planking as a guide to line it up a consistent distance from the shear line.
- Archi, Farbror Fartyg, Mirabell61 and 2 others
5
18th century English Longboat by Chuck - FINISHED - c.1760
To start...the slotted false keel was tapered from the bearding line to the outside edge. This created a simulated rabbet once the two keel pieces were cut to shape and glued into position.
Then the 16 bulkhead frames were added. I had these laser cut to save time. They were designed in a way that the center sections are removable. They are held to the frames by small tabs. Once the hull is planks I will file through the tabs and snap out the center sections. Care must be taken to square up the bulkheads with the keel and ensure they are straight so the the proper hull shape can be obtained. You could further stabilize the bulkheads by gluing a temporary batten across the tops of them which will be removed before I start filing the center sections free. But I am not a heavy handed builder so I just started fairing the hull immediately. I use d alight touch while beveling the outside edges of he bulkheads. The transom and bow fillers were added just prior to the start of planking.
