Posts posted by Chuck
Great start so far....REMEMBER to have FUN with it!!!!!!!!
- justsayrow and Shazmira
- 2
Very nice work. Coming along wonderfully!!!
Many contemporary models and admiralty models were not POF either. The method of construction doesnt really matter....its the end result that matters.....
Unless you really want to build a ship model as it was actually built, or leave the hull unplanked to reveal framing.....there is no real difference in the final outcome. It just becomes a matter of your preference. Which method are you most comfortable with? For those folks that might look down on one method over another for some silly reason....that is a something they must deal with as it is usually just an attempt to make themselves feel better. Here is a perfect example......does anyone want to guess how this hull was made??
Chuck
No not at all...I rub the edge of a sharpened pencil down the edge of the plank and it works fine. You could even use a fine sharpie if you are careful.
Chuck
By the way....shall I move this to the group build forum....I almost couldnt find it again after first looking there.
Chuck
Good start...but the spacer blocks you are using look very thick. Those may be tough to remove so you can snap the bulkhead centers free.
Chuck
You are correct...the upper part being the transom and the lower curved part being the counter. On larger frigates that small band above the counter is angled an extends to become the base of the quarter galleries port and starboard. This was what I was unsure about. I was mistaken now that I see the plan. Rattlesnake didnt have any quarter galleries so I was questioning if it was indeed flat and part of the transom. Based on the plan you show it clearly is. This two pieces of decorative molding that define this area makes it hard to see when looking dead on at the stern. But the profile drawing you show makes it clear that this is a flat area of the bottom of the transom. I wonder if the two pieces of molding were an attempt to make the privateer appear like a larger frigate or if it was merely decorative. Having no quarter galleries would make this tough to pull off such a ruse.
I would still plank it as Hahn did with the p&S planking overlapping the counter planks.
I hope I didnt confuse you with that.
Chuck
Hahns Rattlesnake...Planks overlap the counter planking. You will also see on most ships like this that there are two counters. An upper and a lower under the transom. I am not sure if the kit simplifies this or if it is in fact a flat area on the same plain as the transom. simply a decorative design. My guess is that it is a simplification for the kit so the one piece cast transom can be utilized. I dont have a copy of the rattlesnake plans to double check...But even if the upper counter was relatively flat I would think it at least angled differently than the transom. Less than normally seen on a ship of this type though because there are no quarter galleries..
Its hard to say without the plans in front of me.
BUT...totally unrelated and based on what Druxey has shown. The cutter Cheerful I am working on has this feature of a rabbeted fashion piece. . Its going to be quite a challenge to model it. You can see it clearly in the photo below. This would not have been the case on rattlesnake however based on what I have seen of her.
Wonderful job. That model is really shaping up.
Its not just the cost issue but that is a big part of it. Its also the ability to get enough of the other wood in significant quantities. Consider the amount of kits that are sold each year. Thats a lot of wood. I suspect that if a kit MFG were to open in South America. You would see boxwood being used. BUT the mfg's in North America have a plentiful and inexpensive source of wood with basswood.
Chuck
Very nice images of the frame centers being removed. That shows how it should be done.
Nice update.
Chuck
We would have a look at them and then decide whether to replace those offending cant frames. Other than that we wont post another wntire set of drawings. Just a fix for those that may have been created with errors.
Chuck
Yes I would still only put one. They will get pretty narrow. Here is a site that shows teh Mayflower II being planked. Read through all of the months of construction to see the planking being fixed. There are some good pictures. There were no drop planks at all on teh replica. I would still say its Ok to use one at the bow though. Directly beneath the wales.
http://blogs.plimoth.org/captns-blog/?m=201301
Chuck
I have seen six pounders that were 9 feet long. For teh small cutter I am working on, they were only 6' long. There were no standard one size fits all.
Chuck
Yes the 12 pounders would work for the long guns but I dont have any carronades for sale. Blocks will be ready over the summer.
Chuck
In most cases both...but only one drop plank at the bow usually.
Chuck
Drilled and filled....they are just simulated treenails.
Chuck
Some great looking progress. The transom came out beautifully.
18th Century Longboat by Shaz (Robbyn) - FINISHED - Model Shipways
The reason why I placed two at the top was like you mentioned...to secure the bulkheads. But you could just as easily use just one. Then add the garboard. This defines the area in between to plank so you can line off your hull at each bulkhead. One lined off you just have to keep your planks within your tick marks reasonable well.
Chuck
