Everything posted by Mumin
Great job! You definitely should send some photos to Daniel for his webpage.
- 473 replies
- greek bireme
- dusek
There are more "traps" in this build: 1) markings on B19 are not for beveling, they are guides for gluing L11. And together they form temporary guides for drilling. 2) Waterways should be glued "upside down" (the glue goes on the upper - marked side) 3) Pay close attention to the right and left parts, sometimes they are intermixed on the plates (for example bulwark D2L sits together with R planks and vice-versa).
Pinta by jct - Shipyard - 1/96 scale - CARD
Mumin replied to jct's topic in - Kit subjects built Up to and including 1500 AD
Not now. The second planking should be glued to the bulkheads only (as far as I remember the instruction manual suggests this) and then you will see if it needs filler. -
In Shipyard models the first (of three) layer is just for the strengthening the hull. But fairing of the bulkheads shouldn't hurt... -
Where do I find chuck's practicum?
Mumin replied to jah's topic in How to use the MSW forum - **NO MODELING CONTENT**
ModelExpo has it on Phantom page (separate chapters or all-in-one pdf), just scroll down to Description and click second tab (Instruction and Parts List). -
Dušek sells both turned brass cannons and a bundle kit+cannons. And it's on sale right now There is also "inside the box" video on youtube: https://www.youtube.com/watch?v=IBT3_J9oKsA
Is there a true POF kit in the market?
Mumin replied to Ulises Victoria's topic in Wood ship model kits
They have Canadian webpage... in French only : http://hachettecollections.ca/contact.php -
From what I can see here, Mexico is covered by their division Salvat, so you can contact them directly: https://mx.salvat.com/home/contact -
Hachette in Italy just anounced partwork "La Belle 1684": http://www.costruiscilabelle.it/ if I understand correctly, "tecnica dell'arsenale" means "admiralty model" -
I've just noticed this message on the webpage: To our foreign customers. The translations of manuals into English are currently at the beta state. They are correct, but the language is a little rough. Here is the list of translations that can be downloaded: MK0302 Schooner Polotsk Might come in handy
As I understand, Mantua kit is in scale 1:84 and Mamoli was 1:150. And the second one is not in production at the moment, you should ask Daniel Dusek about it (his company bought the rights to Mamoli models).
What is the meaning of the word "arsenal" in this case? I know that the historical ruins called "Arsenali" (eg. in Heraklion, Crete, from Venetian period) are in fact places where the ships were build, not the places to store the weapons/armaments. If that's the case, then the term "admiralty model" is very close, or even the same? Edit: link added
Chrome sees them as spaces. Just click inside the url (address) bar and press ENTER.
- 6 replies
- Naval topics books
- Pre-copywright pubs
Don't soak the stones and clean afterwards. Keep them in water all the time (add a drop or two of vinegar, to eradicate algae/fungus).
That's "circle cutter" (compass): Take a look here:
- 37 replies
- sovereign of the seas
- model space
Wouldn't it be better to drill small holes and use the pin-pusher?
- 414 replies
- riva aquarama
- amati
Hi Nick, For strengthening the hull you can use the polyurethane spray foam (low pressure variant!). But do it carefully, as it can easilly lead to "banana" hull (or even break it apart). The examples of this method can be seen here and (more detailed) here. Also, if you are looking for other builds of this model you can search for WAK edition. As far as I understand, this is "Maly Modelarz" rescaled to 1:200.
- 20 replies
- maly modelarz
- Batory
Hobbyzone building slip for wooden ship models
Mumin replied to aydingocer's topic in Modeling tools and Workshop Equipment
Richard, the plans and dimensions are for two variants: 60cm length/7 keel holders and 100cm length/11 keel holders but certainly can be modified. BTW, some credits are in order, since the explanations on the plans are in Polish. This building slip is a part of group project "Baltic galeas Karl und Marie" meant as an introduction to scratch building. All the plans are available, along with sample build log by Romek Sobolewski. Original author of the building slip is Marek Mróz, the modifications and all the plans are prepared by Radek Kubera, Mirek Rybus and Jarek Bąkowski. The project was conceived somewhere in 2005, but is still very much alive - just recently several new modelers started their build logs on koga forum. -
The plans are available on Polish modeling forum "Koga" (the link starts the download of pdf file). -
David, The main purposes are two: to protect the ink (print) and to make the paper easier to form. As for the applying - one can use regular flat (about 3cm/1inch wide) paintbrush or by airbrush. Apply to both sides and hang to dry. There is no difference in gluing when using surface cements (like polymer glue or butapren/shoe glue) and little to none with water based glue (like PVA or BCG).
- 243 replies
- borodino
- dom bumagi
