michael mott
Everything posted by michael mott
  1. Wow! I can see that you are able to accomplish a great deal of detail at this tiny scale ant chance of some close ups of the blocks and the rigging at the tops of the sails? Michael
  2. Well all this talk of garages I happen to really enjoy my single car garage converted to a workplace. There was a fair bit O' sandin' today Now I'm getting nervous. Now the serious stuff needs to begin with fine tuning the form I am going to need to be very careful going forward from this point, no cavalier sanding now. I am thinking that the new keel needs to be made before going any further. And because Mark Taylor did this some time ago I thought that it was worth a look. I am in the general ballpark the photo is a bit distorted, I can see that it is going to be alright though. Michael
  3. No but I do set up a negative charge to the table and the dust is immediately attracted to it and not me, so no problem I already clean as I leave the shop.
  4. Kortes, very nice work on the rigging elements. How did you make the thimbles in the second picture? Michael
  5. Keith this is not possible, because my shop in independent of the house systems. and if it is sunny today as it was yesterday it will end up being "A Sunny Sanday" thanks for that Druxey. The Balsa dust is certainly like flour though! Michael
  6. Looks like a fair chop in the last pic while the water looks like it is flattening in the top one. Michael
  7. Further gluing and shaping. The forward section roughed out, waiting for the aft section glue to set up. The rough shaping done to the whole hull with the exception of the area at the bow and stern which will be sorted once the new keel is made. It slips on and off the spline nicely with enough friction to to hold if I tip the board upside down. Tomorrow will be a sanding day. Michael
  8. Personally I would soften the edges away from the mast end. The softer edges will be much easier on the haliards and any other lines. Just keep enough squared to do the clamping at the bracket. Michael
  9. Mark 2 Thanks The blocking is moving along quite nicely. Today i will work the aft section. It was very easy being able to glue up the blocking while each bulkhead was flat on the bench after the rest are glued up I will do the sanding to ensure that they match the drawing and eliminate the accumulated error caused by the tiny thickness overage. Michael
  10. I have started to add the filler blocks and will rough shape them before final sanding to thickness and glue up. I am using a chisel to remove the square edges, no point in sanding more than I need. The next picture shows the relief slots for the floors which will tie the ribs together. Michael
  11. Well the skilled builder is still on a long learning curve. today I began adding some spacer filler blocks of Balsa (not my favourite wood I think I had a traumatic experience with balsa airplane imploding on me after winding up the rubber band driven propeller), the Idea is that the bulkheads will get most of the filler blocks added to only one side at first this will allow me to set the position of the floors. and also I can make any minor adjustments in the thickness of the space. I attached the 1/4 x 1/4 spline to the building base with a few 1/2 inch pins and it will be left on the board the bulkheads slide on easily and the balsa spacers are snugged up to the spline but only attached to the upside bulkhead. Once all the bulkheads are built up they will get glued together and then the whole thing will be able to be lifted off the spline register. This is the plan. I I am being very conservative with the glueing and just adding a few "buttons" of glue to hold the first bits, I do not want to stick any of them to the spline or base. Michael
  12. Nice work with the mold jackets Mark, and this of course applies to all the mold jackets that we want for production runs, not just cannons. Michael
  13. Hi Dan not all the bulkheads were place yet. I have now glued them all together after cutting a 1/8th notch in each to give a 1/4 inch by 3/4 inch slot I have dry stacked them to see how it all looks later today I will cut a piece 1/2 x 1/4 and fix it to a board then assemble the bulkheads with balsa filling between to shape them to the final before making the ribs. after the shaping I am going to make the floors and set them in slots next to the ribs. The top plate for the keel will sit onto the floors then the keel will sit onto it. the ribs are short of the top plate by 1/2 inch according to Roger to create a limber gap running the length of the hull. so the garboard strake will be a key one tying the lot together. Brunch is calling Michael
  14. Thanks for the visits. Making sawdust. The first set of bulkheads these are cut to the inside of the ribs. These are the set for the port side and I have been reworking them, most needed to be jumped to give enough wood to allow for the new shape. The #11 was trimmed from the #12 and so it goes. I will use the port set as templates for the starboard set. Work continues. Michael
  15. Good to hear from you Jeff, once it warms up a bit perhaps we can get together for a coffee. Michael
  16. Nice work on the mast hoops Vaddoc, I chickened out and used gummed paper for mine. Maybe i shall have a go at some wood ones down the road, looking at how well yours turned out. Michael
  17. Kortes, Thank you for the tutorial on the sail making, I really like the results. Michael
  18. An update, I have reworked the lines for the umpteenth time I revisited all the pictures that I have and further correspondence with Roger. I did cut out all the 23 stations in 3/16 basswood and will now need to revisit those and reshape most of them The keel will need to be remade so at some point i will use the old keel for a freelance model. The stem would be the only thing that could be reused so it will be better to start over. I am going to build this, now that all the information matches. and here is a PDF of the plans. new lines march 25.pdf So now I am going to take a break away from the desk and do some cutting. Michael
  19. Hi Dan just catching up, superb job as usual, Those funnels looked like they were a lot of work, nicely done! Personally I am not a fan of laminating thin sheets of styrene and have had some issues in the past with blistering caused by temperature changes, likely caused because I was not able to get a complete surface adhesion even though the liquid cement capillaries a long way. Michael
  20. Doris....I would not expect anything else now! You are gifted there is no other word for it. I do enjoy your updates. Michael
  21. I'm beginning to understand why a large number of the boat builders of the late 19th century and early 20th Century used half models then lofted on the floor from the model.......just sayin' I have been going to bed cross eyed for the last week. why do I feel a spell in the workshop at the wood-bench with planes and chisels might be in my future? Michael
