michael mott
Everything posted by michael mott
  1. I have been absent from the forum for a little while because I have been caught up with summer model railway stuff. I have to squeeze past the boat models as i go back and forth to the bench. The garden railway needed some maintenance and well you all know where that leads. I have also needed to spend time in the house with Judy so took up a kitchen table work spot to work on a couple of sculpy figures for the 1/8th scale Montague's Carriage . Carriage and railway. Which led to trying the live steam loco for the first time, it ran very fast and so i needed to build an inertial wagon to give it something to work against which led to a load of work. This was the final version of the gear train. and then it needed to be tested. It worked very well and so then needed to be dressed up a bit. Here is a Mars on a test run So even though I have not been active here I have been busy with model work all the same. Michael
  2. I remember that Model Dennis, I wanted to build a live steam version at one time in my earlier crazy modelbuilding habits. Michael
  3. A masterful job indeed Keith. The hull really does look spectacular. michael
  4. Ed looking at you photographs, give me pause, And you are only showing the lines! to think that sails had to be set amongst all that boggles my mind. beautiful work as usual. Michael
  5. Keith, superb work on both the binnacle and the rudder. I always enjoy seeing how you tackle and solve the little details that mark your background knowledge and skills. Also I am thinking that the hull would look absolutely stunning with the right white above the waterline with the varnished mahogany below. But that is only my opinion. Michael
  6. Hi Keith, just catching up I have been busy off site for a while. Beautiful work on the hull, and clever solutions on the binnacle. Michael
  7. Very nice Paul and good to hear that your mind is in good shape as well, we often take our bodies for granted until something serious happens then we cherish how wonderful life is. Complaining about the weather the heat or cold of it is acceptable in any part of the globe though. One of the reasons I moved to where I am now the outside temp has no affect on the inside temp provided I pay the bills and the heater doesn't have a malfunction. !7 years Hmmm that is dedication to the task and a beautiful result. The nail is intriguing as well. Michael
  8. Good evening Keith.... yes I know it's morning there. Have you thought about making a small tube drill saw, by turning a short bit of drill rod or an old 8mm drill into a micro hole saw a with a 2mm pilot drill You would not even need to harden it if toy went slow enough but mate sure to make the teeth knife pointed on the outside diameter I think that would be better than a forstner bit. Michael
  9. Your situation does not sound pleasant at all. I hope that you recover soon and that nothing really serious is going on. Michael
  10. Steve I really don't want to go that route. The ribs were steam bent in this launch and I loose only 100% of the time when I fight with nature. I am doing some tests to see how things look at the bow and some deadwood is definitely in the cards. the cross floors are 1" thick and are made of Castello and there is a space for the limber hole which is formed by the rib not reaching the top plate. this is how it is on the restored launch. I have places a piece that is 3/4 inch thick down on the form then the keel is placed on top the Keel needs to be tapered at the bow and stern. I will set the width of the top plate by a combination of the width of the ribs at the bow and the keel adding a slight bevel to the end of the ribs lets them sit well next to the floors. The ribs are not lined up with the station bulkheads, there were no drawings of this and the ribs are generally spaced at 12 inch intervals which at this scale is 1 1/2 inches apart, so as I am typing this it occurs to me that there would be fewer ribs in any case. I am also guessing that there won't be much of a limber hole on the first couple of ribs in the bow. Michael
  11. Kevin thanks for the video on the clamps, I found it very useful. Michael
  12. Nice solution Pat. That jig for holding your dremel is interesting. Did you make it and also tell us about the little saw holder I really like it. Michael
  13. I only asked a question.... Keith your work is masterful and that is the only reason I can rib you, because I have the greatest respect for your skills. Cheers Michael PS Oh yes and the speed control does look respectable now. fantastic work all round, well hexagonal at least.
  14. Gary just catching up. If my hull comes out looking anything like as clean as yours I will be a very happy camper. The whole model is looking great. I have followed Chuck's work for a long time, he has to be the consummate artist when it comes to making a scene look absolutely real. I am looking forward to seeing how you finish the hull weathering. Michael
  15. Mark, my that link is great those guys are insane... amazing sailors but insane 1000 square feet on a six footer now that is pushing the envelope. Thanks again. Michael
  16. Hi Mark thank you yes I can see that they can lie perpendicular to the keel but follow the curve of the hull at the same time . Michael
  17. Hi Kurt I missed your post as I was composing at the same time. Thanks for you kind words. Michael
  18. Thanks for the comments and visits. I have a question regarding the ribs in the launch. In the following pictures are some tests with Castello and Yellow Cedar. I am told that the frames or ribs in this launch are 1/2 inch by 1 1/2 inch wide. The bulkheads are for getting the shape of the hull correct, ostensibly. I have been attempting to form the ribs to the shape that is left in the form after sanding and this is not working I have snapped three or four while working to bend the rib against nature which logically does not make sense. if the section of these ribs were square I can see this working but not with these. What does make sense is to make the ribs follow the curve of the hull and lay them flat. This does not then add all sorts of twisting stress to the rib this is obviously not a big issue in the full rounded area but at the bow and stern. I am inclined to space the ribs logically at the bow and stern and let them lie flat next to the hull there will be a slight twist which is ok but not the Houdini twist I was attempting. And of course critical council is welcomed.......Keith. I await the collected knowledge of the membership. Michael
  19. Carl, that did cross my mind but I thought that it would have been more work, the error was annoying but small enough that I was able to fix it. Michael
  20. Good morning Druxey, I don't think you are missing anything. It is me who missed an error in my drawing, as it has turned out I would have not got the keel correct at the bow and stern from the drawings. I probably could have done away with the #1 set of ribs because after shortening the hull to match the overall length as per the numbers from Roger it would have been wise to reset the stations but I did not. I really can see how the use of half models was one of the main ways to get the form right. Working from 2 dimensions with a soft form without using all the conventions of waterlines, and buttock lines to check the shape in hindsight was a recipe for what occurred, it would have been the better way to approach this. I will definitely have a greater understanding of this process on the next hull. I will follow the plans of a tried and true hull, instead of a few measurements of a pretty boat, that are mostly of the inside and a bunch of photographs. At this stage I am confident that it will all come together and will fairly represent the actual boat. I can also see why folk build kits. I can accept that I needed to learn all this the hard way. Michael
