michael mott
Everything posted by michael mott
  1. Hi Mark, Life does show us what we are made of. The lessons it presents teach us how to move forward, and it sounds like you are sorting it out. Happiness comes to us when we engage in what it is that gives us focus, and it sounds like a great idea to begin a fresh build at the moment. I look forward to the new build. Michael
  2. Well let me see that would be 1/4 ish the size so pretty tiny, That would be pushing my limits to the edge..... I'm not sure I want the stress. I fitted the bracket to the door today also turned up the other lenses and began trying to get the cap parts looking right. The bracket for the door was riveted on with some clock-makers taper pins. The cap looks better out of pressed plates than a solid turning I will need to make a couple of new formers I think. I am really pleased with the bracket riveting. Also brought the keel down to contemplate my next move. Michael
  3. Looks like an interesting build I shall follow along. Michael
  4. Kurt, thanks, I am happy that you are enjoying this journey. And as you know practicing what we do does take some time to get proficient at it, seeing the improvements as we go along I think is what keeps us going, there were a few time yesterday when I really was ready to toss this lamp across the room. Carl reminded me that there is a better way to solder this sort of work. Michael
  5. Carl, Yes and working on this project has convinced me that I will need to invest in sorting one out. Druxey, thanks and yes old chucks are very useful. Steve and GL thanks for you kind remarks. Michael
  6. Thank you all for your compliments and encouragement. Today was challenging to say the least,probably the most fiddly soldering I have ever done, I have been at it a good 6 hours or so fiddling around setting it up then rearranging it again, and again. Making the lock for the door took a bit of time I had to anneal the music wire, the first effort the wire snapped. the hinges are just wrapped .008" stips cut with the scissors. then folded over the steel wire, they needed to be soldered with the wire in place and it took three tries to get it done well enough the I could operate the bar. The rotating tab for the locking bar to slide into was done by folding a bit of .008" x 3/32 over 2 different wires the small one for the hinge and the larger one for the locking bar. tab positioned ready to accept the locking bar tab rotated out of the way so that the door can open and the open door, The hinges were soldered onto the door plate in situ I soldered the top together as a unit before soldering it to the rest. then held the top upside down in an old chuck The body was held in the third hand and a weight placed on top of the body before fluxing and placing a few small snips of solder. Still need a bit of cleaning and the cap and the other two lenses but I am happy with this one. It has been a long day. Michael
  7. I hear you Eberhard. your comment about the packing tape, when I was a boy we called it "Butchers tape" it is still available and is a good material to use The sail hoops I made for the Buzzards Bay 14 were made from it and once it is completely dry it works like fine laminated veneer. and very strong. Have you thought about using that Keith, the brown gummed tape? Michael
  8. Andy wonderful! just the right scale to I might add. can you give a picture or shot of the drawing of the dingy that you used. You mentioned pine and limewood (linden) the ribs look like ply I did not know that you could get pine plywood that thin or did you laminate it yourself from veneers?. Lovely workplace too. Michael
  9. Eberhard have you studied some of the work that Doris has done with paper? I have a completely new regard for what can be done with Paper. I had not realized how versatile it can be. Michael
  10. Dave, Thanks Judy and I enjoyed our visit this morning, and I am looking forward to seeing that Bluenose kit build log. Michael
  11. Exquisite work Javier, I too am amazed at the level of detail you achieve on these tiny models. Michael
  12. Keith very nice looking hull, a question why the alternating colors for the fairing? Michael
  13. Thank you for the close ups Rob. I also appreciate your thoughts on the sails on models in your last two posts. Michael
  14. Thanks Greg, But I am already using Vimeo and it works for me so I had to make a new top because the earlier one was just eyeballed and was not quite symetrical and was too wide for and aft. I reworked the original form in the vice with a flat file. I like to use a black felt pen to help with the process of knowing what to remove. Then using the same method described earlier I formed a new top. this was drilled and the hole cut out with the jewelers saw and then the hole was opened up with a round file. Next was to open up the hole as described earlier hopefully this little video will clarify the way I did it. Michael
  15. Rob that is a lot of work, is it possible to show a close up of the cringles? The sails are looking great. Michael
  16. Hello Mark. Thank you for your detailed description of the way you made the sails. replicating a particular material at scale can be daunting, it looks like you pulled off the Dacron nicely. I am guessing that Canvas would be easier at 1:8 But your model of the Dacron sail might work for my cutter since it is a modern refit of an older version. Anyway nicely done! Michael.
  17. Hi Carl I can see why you would do that. First I use a round file to open up the hole to close to the right diameter . Then I use the tip of an exacto knife and with practice you can make the knife slide smoothly like a miniature pairing chisel without causing the chattering which causes the saw tooth finish that you speak of. The point of the blade has to be just at the right part of its depth into the hole to work efficiently. I will see if I can make a short video to demonstrate what I mean. It is a simple operation but like many things take a bit of practice to get proficient at it. I have produced the effect you speak of myself on more than one occasion. Michael
  18. Daniel I have to echo Pat's comment! Michael
  19. Dan Just catching up. superb work on the ship a lot of interesting detail at a small scale. Michael
  20. Ed thanks I appreciate you compliment. Hi Mark, the form for the top was all hand filed and polished. The brass form was placed in the milling machine vice so that the form was raised about 3/8 off the base with a wood spacer. The annealed sheet of .008" brass was stood up between the former and the smooth sanded block of Linden with the end grain facing the brass. The closing of the vice pushed the form into the brass and squashed the sheet and the form into the end grain of the linden. A shot of the mess on the bench. I wanted to see whether I could do a better job of the top of the lamp especially the tree like vents. So I did a new drawing in Cad and set up the measurements to be easily transferable to the dials on the mill/drill., but before that was done I wanted to see if I could form the two bands above the vent holes. A small piece of annealed brass was taped to the cutting mat and a rod of .021" music wire was taped into position then covered with a slab of I/8th inch brass and whacked with a hammer. I seemed to be successful, so I trimmed it up to see how the vent holes would work and then see how it curved into a tube. Teh trimmed piece was stuck to a piece of Cherry and using a combination of drills and burs I roughed out the holes. Then placed the piece in the vice to shape the holes some more with the fine rat tail file. It seemed to work in principle. so now to make the final part. It formed into a tube easily without distorting the brass looks terrible and dinged up because it was just a scrap. The new drawing gave me a better way of sequencing the body part so on to version 4 The folding was done on a hard surface which improved the results. After drilling and fretting out yet another three holes I am pleased with the results. The holes were slowly opened up with the exacto knife in the same way the you spin the knife around in the end of a tube to remove the burr. You can see the tiny shavings, it is slow but very effective way to set the holes. Next a top ring sheet for forming the vent tube was cut to match the cad Drawing and using an .8mm drill and an included 60 degree burr I was able to make a better looking series of vent holes. The top plate needed to have a hole cut and this was done the same way as the rest of the holes. The top plate was polished up and reduced the flange to better reflect the original. The vent tube was trimmed until it fit snug into a 5/16 diameter hole. a flanged retaining ring was turned for the base of the tube so that it could seat properly for soldering to the top plate. and an inner collar was turned up for the top of the tube. That's it for today. Michael
  21. Well thank you Keith, and like all magic we have to practice our craft. Roger's photos this morning caused a rethink. The test is to see how well the integrated hinge will work. I went back to some .005" brass with some .011" music wire, a fold back with the wire placed at the apex and taped to stop it moving. Next a bit of evergreen to use to close the brass with a tap from the small hammer. The styrene is able to slip a little without damaging the brass. After both ends were folded it was back to the drilling and fretting out the three holes again. I also turned up some new lens tubes with a bit finer detail Using the jewelers saw to cut out the spaces for the hinge tab locations. then made a door using the same procedure. The hinge fitted better than I expected first time. The next task was to fold up the body this was a little easier not having to make the closing fold. again the same methods were used to make the folds. A small tab was folded to act as the closing piece. All dry assembled and the locking tab will need to be redone with the folds opposite to each other. The top is also new and follows the design of the original more closely. That's it for today. Michael
  22. Stunning Work Gerald! The overall shot with the tools etc, Will the tools be on display as well as the models? Michael
