noel_colledge
Posts posted by noel_colledge
Congratulations on what you have achieved so far Keith. Awesome build.
- Keith Black, KeithAug and mtaylor
- 3
What an absolutely fantastic project and finish, very original and educational throughout.
Thank you for sharing, very inspirational
You should be very proud
- mtaylor, Retired guy, paulsutcliffe and 2 others
- 5
Might be a bit obvious, but if the boat is for sale with a broker would it be worth dropping them an email to ask them directly. You might get cold shouldered but you never know..
- mtaylor, Keith Black and KeithAug
- 3
The turning mentioned by Bedford is called involuted turning.
The idea is to take 4 square and numbered pieces of timber. Glue a piece of paper between the mating faces, making a larger square. You then turn the required design. Once complete you separate the pieces and glue back together so the design is now on the inside. You can now turn the external design of the item.
Important to go with the grain in order to ensure on invisible join.
- Keith Black, Retired guy, KeithAug and 1 other
- 4
5 hours ago, No Idea said:
Your work is just simply stunning and very inspiring too.
Can I ask about the vice you use on your mill? I see that it tilts which is a very useful thing to have. Did you purchase it as a tilting vice or have you modified an existing vice. The reason I ask is because I could do with one just like it.
Rutland do a version of it.
Here is the link for you.
Great to help out a fellow Yam Yam
Regards
Noel
https://www.rutlands.co.uk/sp+woodworking-tilting-angle-vice-100mm+DK7104?tyah=y
There may be one relevant information on Vanhorn's document Eighteenth Century Colonian American Merchant Ship Construction on the following site
https://nautarch.tamu.edu/academic/alum.htm
My apologies if if is the wrong era for you.
Regards
Noel
Your work never ceases to amaze me Johann.
Thank you for the video, it pulls your progress together so far perfectly.
- billocrates, mtaylor and EJ_L
- 3
Although I can't disagree with you about your comments on apprenticeships Mark, I also think that necessity is the mother of invention. Too many times when asked why something is done the way it is, they answer is Because that's the way it has always been done.
Sometimes a different approach is all that is needed to improve a process, there are lots of different skills on this forum which makes the sharing of knowledge possible. After all an apprenticeship with one master does not mean that another will do it the same way, but the end result can be the same.
We can see this by all the different ship build methods in a particular era by different yards or countries to achieve the same results.
So long as you learn by mistakes the apprentice eventually becomes the master regardless of the approach.
- druxey, mtaylor and Hubac's Historian
- 3
Fantastic efficiency
- Louie da fly and mtaylor
- 2
The trick is relearning how to saw again. Western saws definitely need a different approach to Eastern saws
No pressure is certainly the tactic, let the saw do the work. Start off on the right and square line and stick to it. They don't like changing course part way through.
One of the hardest parts I had to relearn was to fight the years of muscle memory pushing a saw with tension which is a certain way to damage any of these pull saws and easy to fall back into once you get into the rhythm
Not sure if it is any use to you at all and even less sure of how to, and even if I am allowed to mention or post and upload. I was lucky enough recently to pick up a number of old nautical research journals from flea bay which I am steadily reading through. There is an article in vol 14 nos 3-4 (1967) about the building of a 1/4" scale Boeier by Harry V Dunn Jr. More than happy to copy and send PM or upload if the site allows.
They also do a round handle SF1 to SF4 depending on the length you want, which makes them a little easier to use than the standard handle if it helps.
- Canute, thibaultron, Bill Tuttle and 3 others
- 6
Have you tried the Sydney Maritime Museum, they have a full size replica there, might be able to help you out
YOUNG AMERICA 1853 by Bitao - FINISHED - 1:72
Hi Hyw.
You mention 5 of your favourite ships you wish to build, what other 3 masterpieces can we look forward to seeing in the future.
Regards
Noel
