Posts posted by samson
I love all the details you adding - It giv a werry autendik look.
- Old Collingwood, Omega1234, Piet and 2 others
5
Hi Don.
It's probably the most exciting building kit I've seen, I did not know it existed. I am totally envious of the high quality and building information - lucky you,
I'm looking forward to keeping track of your construction project.
Jens
- Old Collingwood, EJ_L and Elijah
3
hi Denis
I think it's a very successful model you've got put together , it looks werry good
- Elijah, Piet, Old Collingwood and 3 others
6
Hi All.
komming along well with "2. floor" - finish maiking brass fiting and started painting . stil som way to go thou
Cheers
Jens
Hi Denis
I just point out that the model ship Norden, which you build model of, is not designed to be landed - the many videos that are with boths are some very special and very few. - they are broader than the Norden and are supplied with support wood keel and extra reinforcements at the bottom. Billing boats also have a model of such a vessel that named Bent. ( 5006 coastbot Bent ). The Norden is a plain boat that needs a harbor space like most other ships
The winz you discussions that are located at the wheelhouse are for unloading via rops throug the mast and the boom . and for other fishing teknike , and for anker up as well , in other words -- multi purpose function .Cheers
Jens
Hi Denis
The netting machine is used to put and record bottom net that is put out and rumored the day after .
the ship Norden is not the type of cutter that can be landed as seen in one of the videos it is supposed to be in port .https://www.youtube.com/watch?v=vlm2G6O3fTw
https://www.youtube.com/watch?v=2q6FPTECYmE
Hi Denis
nice work . your fish cutter looks good I thought if you have googled the boat type to find photos for details? good words to search for are:
Norsø kutter or Fiskekutter or Hajkutter and for old blak and wite pic just at : gamle billeder - or - sort og hvid before fiskekutter .
her just an apitiser
have fun
Hi Denis, it's an impressive pace you're building with and it looks good
- Omega1234, Piet, Old Collingwood and 2 others
5
hi Denis thank you for info. even mizzen mast has one too it's just one thing that's not included in the versus cutty sark construction kit so i'm oriented
cheers
Jens
Hi Tim Thank you for your response, it makes sense that it supports the yarden. I du not think it looks flexible at the bottom. for turning the yard. but then the good thing is that when building a model, things do not hawe to work, just they look right.
Cheers
Jens
hi there is someone who knows what this is and how it works and how are the details at the bottom i have been unable to fine explaining pictures.
good explanations are very welcomeJens.
Hi Eduardo the right color is black but it will downplay the details. so it's a compromise to make metal parts stand out
yes I think it's located right while the boom is downwards and a little ahead, chained from the sail downwards and a little back so they do not meet.
thans for looking in and komment Denis
Hi All.
14-01-2018
Small opdate - thou it tok a houl weeks spartime
Jens
- etubino, JerseyCity Frankie, Elijah and 2 others
5
Hi Nenad
It's a super nice dinghy you've built , it's going to decorate the cutty sark , well done
Hi popeye
yes it is a brass plate i yuses for my brass fitings and so far i yoused 1/3
the thiknes is 0,8 mm and issy to cut witk a mettel sissur .
- popeye the sailor and Elijah
2
Hi Graham thanks , it is also great to bee back
i hope you have pations then , i feel it will bee a waile before finish thisone ...
Hi Popeye love follow your thermopylae and you smaller you harder so good louck.
werry small opdate now im on.
Jens.
- GrantGoodale, Elijah, tasmanian and 2 others
5
Hi All
A little update in the neverending story. I will roughly make all yards and make all the brass rings and fittings before I finally fix the masts - the 9 rings shown on yarde have taken 10 hours to form roughly 1 hour piece
Jens
- Elijah, etubino, popeye the sailor and 1 other
4
Hi Popeye
It feels good to be back. and I am now building the masters finished. Today I have built the last crosstree for the mizzen mast.
Cheers
Jens
- Mirabell61, Tim Curtis, glennreader and 3 others
6
Thank you for saying that Scott
2
Hi Nenad thanks for looking in .
yes sometimes it is not always the most obvious material that has the best effect. but I've been happy with paper for many things, it's cheap. you have a lot of it. it's dull to shape. and in the small scale model is even the thinnest wooden veneer too rough.
cheers
Jens
2
Cutty Sark by deckape - FINISHED - Revell - 1/96 - PLASTIC - 1959 kit
in - Kit build logs for subjects built from 1851 - 1900
awesome model ship. a true bliss for the eye. thank you for sharing it with us
cheers.
Jens .
