TomShipModel
6 Followers
About TomShipModel
  • Gender
  • Location
    East Brunswick, New Jersey
  • Interests
    All things Nautical but my primary interest is Sail between 1750 and 1815. Previous builds include Sloop of War Wasp, Screw Sloop USS Hartford, Training Ship Empire State (all scratch Built) as well as Destroyer Escort USS Camp (scratch built excepting the hull from an old Revell kit - Long Story). Current Build in HMF Liverpool built 1757 at 1:96.
2,888 profile views
  1. Good afternoon, I am currently building a 1:96 scale Argus. Have you read the book about your ancestor? It is a very good read, and I recommend it. I was intending to use the Syren kit as a base for Argus, but having built a 1:64 Wasp, space dictated a smaller scale. The other reason is that my comparison of the Argus lines with those of Syren show that they are very different. If you are contemplating building Argus from the kit of the Syren, please reconsider. While both were built about the same time, excepting that they are both brigs and similar overall dimensions, the hull form is very different. The Argus was reputed to be a much better sailor than Syren. She also had much less tumblehome than Syren (for example, her upper hull at midships is more vertical than Syren). I am using plans by Howard Chappelle and a large-scale model of Argus that was the subject of an article in the Nautical Research Journal as a starting point. The NRJ article includes a detailed listing of dimensions for masts and spars of Argus when she was inspected after her capture and a deck plan with deck furniture, pin rails etc. While the Chappelle plans and that large model show a billet head, a merchant captains report to the captain of the Pelican noted that the brig had yellow sides and a bust for a figurehead. The question is a bust of whom? I know that a carving of the figurehead of Argus does exist, and I have seen it at the Naval Academy, but it has since been returned and I lost the photo that I had taken of it. If you wish, I can provide a few more references to Argus. I would be very interested in any information that you may have discovered. Best to you, Tom
  2. I'd be interested is how they work. I've also smoothed out the wrinkles with a weight bristle brush. On first impression, the sponge may not be stiff enough smooth out the wrinkles. I think that these are intended to apply glue etc. If they work for you that's great. Tom
  3. Good evening, John, The reduction in the height of the sail depends on how much you wish to furl; meaning completely furled or, as I did, partially lowered. 50% or so worked for the look I was working toward. If you wanted to lower the gaff more, 25 to 30%. Just keep in mind that the number of gromets and lacing line around the mast would be the same as for a raised sail. Regarding color, for some reason the brownish gray that I got gave me the look that I wanted. Rather than dying, some have used acrylics to gt different coloring and effects. I hope that this answers your question. Happy ship modeling, Tom
  4. I use silk span for sails. At this scale, I use three plies of silk span with each plie 90 degrees to each other. My work surface is glass, and I use dilute white glue at approximately five to eight parts water to one part glue. Too much water defeats the process, too little water the glue is too stiff to spread. Hope that this helps.
  5. I meant, a sales brochure for a full size boat. AN interesting fact with photography is that no matter how good your model looks at a comfortable viewing distance, the photograph shows all of the imperfections. The galley on your model looks like it was taken on actual boat. Fantastic!
  6. The photograph of the galley on a model looks like a photo in a sales brochure. Fantastic clean work Michael. Tom
  7. Welcome to MSW.
  8. Welcome to MSW.
  9. Welcome Herby, You will find great support here. I'm very interested in seeing your Mikassa build. Tom
  10. Welcome. You will find plenty of support on MSW.
  11. Welcome to Model Ship World. You will find plenty of support here.
