Everything posted by Overworked724
Good ideas!!! I’m always looking for space!
- 436 replies
- Syren
- Model Shipways
Take a look at my build. I think that’s a problem for most folks. The way I did it (lifted from another Syren log) was use a self adhesive rotary (disc 5”) sanding pad 120grit. if you peel off the adhesive from the back and double it on itself, it’s thick/stiff and a little malleable. You can also trim it with scissors so when you sand the inside bulkheads the sanding pad will ‘skip/slide’ over the frames as you sand from stem to stern near the deck. Just one idea you might want to try. Looking good!!!!
- 100 replies
- Syren
- Model Shipways
By the way, if you look back on how I made my carronade sled wheels, I used that same technique to make perfectly round wheels of the same diameter...only problem was the metal plate was too thick for the cathead sheaves. Something to think about...all I really needed was a slightly thinner piece of metal with a round hole and you're set. Then you could make a ton of sheave wheels of the same thickness, diameter without sweat. I'll remember that for future...just didn't occur to me until now!
Bingo!!!! And since I don’t have a mill or a lathe, modeling with the sculpy gave me an opportunity for realistic illusion. Might not be wood or metal, but I think it looks pretty bloody good for a first attempts at catheads with sheaves (sans lathe). By the way…I’ll give all the credit to my knowledge and fearless attempts at ridiculous but fun uses of this stuff to Chuck since he used this stuff in his Sultana Practicum (my first and only build). 👍🏽
Interesting note. When I trimmed off the sculpy sheaves from the sculpy rod I baked, it’s hard to make them “clean” (i.e. perfectly cylindrical). This became more of an issue with the outside sheave. So….I ended up again using some double sided tape on a popsicle stick and stuck them on. Then used a fine emery board to fair them up and take off the uneven edge to give them uniform thickness. Worked perfectly. 👍🏽 Live and learn…sculpy is fun stuff.
There are also CA glues of differing viscosity from water like to gel. They can be bought at Lowe’s. I like the medium CA from Lock Tite. Then I use a long toothpick to touch on the spot I need to glue. For the water like CA, which I used often for rigging or siezing knots, I use a large needle 🪡 with the end clipped to make a U. The CA will wick into the U and then you have conttol on where to apply. I used a dowel as a handle…and just jammed the needle into the end.
- 436 replies
- Syren
- Model Shipways
Finished off remaking the gun port doors. Shown below stuck to some Tamiya tape. This time I left out the rabbet on the side with the gun indent. I think it looks better and also didn’t think that edge needed a rabbet. 😁 Also made the ring handles (not shown). Will paint the doors tomorrow and size out a drill bit for installing the faux hinges. In the background…working out the plan for the P&G’s. It’s coming along.
So…I could start on my coppering any time. The only thing holding me back…are the pintles and gudgeons. Because here is the thing…I struggled with the Sultana for the same reason. How to mount the things without creating a mess? Even more critical with coppering which can get marred/bruised just by looking crossways at it! But…I have an idea! Finally… So my next side project while I whittle through my plan of attack on my P&G’s will be… STERN cannon of course! 🤣 Moving on…with a plan.
Remade the gunport doors. No pics yet, but glad I did it. The reason being was the gun port doors were about 0.5 to 1mm too narrow…when mounted they would have looked off. When I was dry fitting them to set up the hinges and start the mounting process I noticed the visual disparity and it was pretty obvious. I think it happened because I didn’t consider the loss of wood during the cuts. So…my bad. Live and learn. On a positive note…I’ve got a crap ton of scrap doors to play with to get the technique down for the hinges and rings. Moving on…
Just messing around with the uncut cathead lumber. Figured since I drilled out the holes for the sheaves, might as well drill the axle hole and fit in the Sculpy sheaves. This was identical to how I made the bulkhead sheave blocks. So it was pretty quick work. I also slid in the external sheaves which will be covered by wood framing later. Like I mentioned, I made 2 sets of cathead lumber but can always mak more if I screw up. 😁 Gratuitous pics… Moving on to other distractions. 👍🏽
Some good news and bad news. Bad news first…I think I need to redo my gun port doors. Sh*t… Good news…my frustration at the doors made look into something I CAN do…so I prepped the lumber for the catheads. Made 2 sets because I don’t trust myself. Will add the sheaves/axles a bit later. x-y tables in a mini-Drill press for the win. 🥸
Woohoo! Another Syren build! I'll follow along with interest!!!
- 100 replies
- Syren
- Model Shipways
Beautiful build!! Congrats 🍾🎉🎈 on a job well done! Your build has been an inspiration for me and I’m doubly motivated to complete her now. 👍🏽 what’s your next build?
- 950 replies
- syren
- model shipways
Well...finally got around to finishing the carronade side project using the 3D printed cannon. They aren't perfect, and some are a tad tilted...But I did pretty good for my first attempt at cannons and it was fun working around the little problems. Drilled in the small holes in the elevation screws for the 'handles' and threaded them on a piece of wire. The used a touch of CA to lock each 'screw' as I slid them off and clipped them off the wire...taadaaa...instance handle. Used a little piece of wood to set the pieces in and 'glued' the little round handles on each end followed by painting. I left the upper part unpainted so I could thread the screw into the carronade when I was locking them in place. Got the metal pieces and eyebolts set in...then loaded up the carronades. After that, just touch up painted the tops of the elevation screws and reconsidered leaving the wheels brackets unpainted. The brackets themselves would have been metal, so decided to paint them black...which also gave it a cleaner look. Still glad I made my own wheel assemblies. The proof was in the pudding...using a little jig to ensure my cannon were set at the same depth/angle, as well as how the wheels assemblies were mounted gave a nice appearance. The pins in the front slide right into the little holes in the swivel brackets - so gluing them in later will be a breeze... Moving on to new challenges....!
Well...life has certainly gotten in the way these past few months. But...no negative waves, just trying to focus on positives. I'm slowly plunking away at the carronades. Decided to mount the carronade brackets on the sleds and prep for painting. So Assembled the sleds and predrilled the eyebolt holes: You might notice I added a pin (used brass wire) in the front of the sleds to ensure when I glue them on the swivel brackets they are easy to align by setting the pin in the little hole in the swivel bracket. I also slightly sanded the inside edges of the carronade mounts to make the carronade fit a bit better....seems to look ok on my test carronade...but the proof will be in the pudding. Once painted (which is next), the photoetched sled components which are glued to the front of the sled (and also behind the carronade) will completely cover the brass pin (if it's even visible under the paint). I'm using double sided tape with Tamiya masking tape on top to make my 'painting board'. The parts come up easily and I don't need the bottom painted. Getting there...
I think it's looking great, Bill! Keep in mind you'll be sanding/staining, adding the cap rails, channels, cat heads, port doors, carronades, etc. There a ton of visual noise which a viewer will see and ignore the small things. You see them because your are the modeler and you suffer the same curse as the rest of us...perfection is the only bar! 😃 But don't shoot for perfection....shoot for enjoyment....it's a lot more fun. You're doing superbly!!
