Posts posted by Ian_Grant
Dear B.E. --- Thank you so much for taking the time to reassure me on the mizzen gaff!!!
On my model the throat lies just above the blocks for the davit lifts, as it does in your photos. So that's great.
I found when trying to set the angle of the gaff that the limiting factor was the aftermost catharpin, as opposed to the mizzen top. Even in Geoff Hunt's painting the gaff peak lies significantly higher than mine. Now I'm wondering if I set the mizzen futtock staves too low; I made them equivalent to the length of the doubling as for the other masts.
I don't need to think long and hard about changing the futtock shrouds - no way, no how!
Thank you again!
Alas! I have come to realize that my driver gaff is stepped too low on the mizzen mast! I recall at the time looking at pictures of how high the gaff peak reached compared to the mizzen topmast and wondering why mine could not go that high - I operated under the assumption that the gaff throat must be below the mizzen catharpins, in order for the gaff to be lowered if necessary. Now I think that it was stepped above the catharpins, just below the cro'jack yard and remained there when at sea unless damaged. If necessary the catharpin lashings could easily be cut to allow the gaff to be lowered temporarily.
Fixing this would mean re-rigging the mizzen topgallant braces, the gaff peak and throat halyards, the gaff vangs, and more especially the gaff parral beads. It's easy to say but not very accessible to say the least; yet now that I've seen it I can't unsee it.
What to do, what to do??
Very nice! Love the sails - how did you get the sail artwork to be so crisp on the cloth?
Hi Bill, my guess is these are water butts for the crew, up high out of the seas washing through the waist. (Sorry I couldn't figure out how to do one of those "quotes" so I just cut and pasted from your earlier post):
"......Something I am curious about and someone may know. On the deck house in the back there are two elements that look like upside down baskets near the front. No idea what they are..........."
Hi Marten - Yes I understood you were joking about the 21 strands LOL 🙂
Couldn't find an english version of your magnificently titled German tome on "Preussen", but I did come across "Last of the Wind Ships" by Alan Villiers featuring many many photos aboard large windjammers so I ordered a copy out of interest.
Here are a couple more photos of the build. Unfortunately the Li battery for my old camera is on its last legs - now a single flash photo per charge cycle!! - so pictures are limited. I've ordered a new battery.
This shows the evergreen stubs I added to prevent the well deck from falling into the hull when mounting. You can also see a wood mounting block for the stand, and the re-purposed part for the supplied stand acting as a support for the rather flimsy mast step
My lettering arrived and looks great. There's more in gold on the stern but a picture will have to wait. Next steps are to add the forecastle railings and anchors. Then I will reeve the steering cables as you explained (thanks again) before adding the final deck at the poop. EDIT: Doh! Just noticed the gold letter "N" fell off! Will replace and this time brush over with matt varnish.
Speaking of varnish, my old can was a little gummy and tinted; the whitish marks you see all over the black are brush strokes. Any touching of the hull shows up starkly on the black portion. Will another coat with a nice new can of varnish conceal this mess? I could always pass it off as salt stains 😉
I also painted the #63 colour on the bulwark rails. A fiddly job when four coats are needed for coverage. Some touch-ups required. Next I will paint the matte white on the lower part of the inner bulwarks (just below the pin rails) then glue the pin rails in solidly with model glue with no paint intervening, then paint the pin rails and bulwark sides above them.
It's looking nice with railings being added. Will replace this blurred photo later.
I ran into a problem with the ladders, specifically, the ends are mitered in the wrong direction so if you have the nicely molded steps on the visible side then the bottoms are teetering on just the miter points. If you orient the miters flat against the deck and bulkheads then the rather ugly what-was-meant-to-be-the-back-side-of-the-ladder is visible. Not sure how to fix this; would be awfully fiddly trying to add little pieces at four ends of nine ladders. Buy after market?
A second annoying problem is the two pumps. Each is set just aft of a mast, and the mast's bitts enclose both the mast and pump with no belaying pins on the portion of the bitts beside the pump handles. I noticed that the pump shafts touched the bitts before the pump touched the deck. I added tiny slivers of evergreen to make it touch the deck. But now I noticed in a test fit that the pump interferes with the stays running from cleats at the mast foot to the next mast aft. What- really?!
You'll notice I have yet to add a single piece of rigging. Once I have the well deck pin rails installed, I will have to manufacture about 160 "turnbuckles" for the shrouds and backstays from micro brass tube and etched eyelets. Then the rigging work can begin.
I improved the bowsprit considerably by cutting off all the chunky-looking plastic "cleats" to tie on martingales, shrouds, foremast stays etc and adding etched eyelets in small drilled holes. That was another thing betraying the age of this kit. Unfortunately I forgot to take a "before" photo but it was mighty clumsy looking. Also, the supplied martingale was a flimsy little thing, which was to be butt-glued to the bowsprit. Yeah, that'll hold! I made a martingale from micro brass tube with an etched eyelet in the bottom end, and glued it into a hole drilled in the bowsprit.
Nice looking kit. Good job on the planking. I bought a Billings Wasa in the 70's as a teenager. It too was single-planked, with cheap printed decks including hatches, far less nice than yours, and what did I know about it anyway? My planking was so-so. I remember cursing trying to pin them into the balsa blocks at the bow. There was no internet then with advice and examples.
When I got to the point where the next step was "Use the two balsa blocks provided to carve two lions" I decided I was out of my league. I threw the hull out years ago but I STILL have the fittings kit! I've never dared try another wooden kit, although I did make several RC kits and a couple of scratch builds. Then off to University and never touched a ship model for 35+ years.
Looking forward to seeing your progress!
On 6/30/2020 at 3:19 AM, Emgee said:
My stepfather had this kit - the hulls did not fit together so he sent away for a replacement. It has been sitting, unopened, in the attic (UK) for over 10 years, so if anyone wants to follow the above inspiring construction course, give me an offer! I see it is around the £100 mark so will accept lower. Ian_Grant: Mum and he were on the Royal Clipper for its maiden voyage across the Atlantic and they sailed on her a few times more, even paid for my sister to go to Mexico on her, hence the interest in the Preussen kit
Yes, my hull halves were both twisted from being crammed across the box diagonal. If you held the stem and keel together, they both flared out at the stern. If you clamped the stem and stern, then the keel flared apart mid-hull. And it is a very small keel to clamp onto. This long-ish hull is made of very thin plastic, far thinner than the reassuringly thick and solid hulls of "Victory" and "Soleil Royale", and there are very few alignment pins to help you. If you sight along the keel line of each half, the thin plastic ripples up and down a bit as opposed to being a straight line. I decided on a multi-step gluing process. First I glued the stem and 2-3" of keel. After that dried, I glued the stern and 2-3" of keel. When that was dry, with the ends fixed, it was relatively easy to glue the remaining keel, aligning as I went, and clamp with small paper clamps. I added some wood inside to straighten the keel; a bit tricky when there are five mast steps inside the hull.
After gluing, when I dry-fitted the forward well deck it did not align properly with both hull sides - there are little molded-in vertical "stops" in the hulls to locate the midship end of the deck, as well as the horizontal support tabs. There was about a 1/8" offset(!), which could be corrected by twisting the hull slightly. When gluing I sat and held the hull securely with the deck aligned until the glue set up. Same observation and procedure with the after well deck. Even the bridge deck required some hull flexing to align! But in the end it all turned out, although I'm not absolutely convinced that there isn't a very slight remaining hull twist. Hard to tell by eye.
A final note on adding the bridge and well decks: there are small "ledges" provided inside the hull to locate the bottom face of the decking, but they stick out LESS than the molded triangular "webs" reinforcing the bulwarks above deck level. So every time you press the deck past the bulwark webs, it falls into the hull past the ledges!! VERY frustrating! I added a few bits of evergreen projecting further out, below the decks, and it became child's play to slide the well decks in from midships due to their taper. This also avoided smearing model glue on the bulwarks.
On 6/19/2020 at 7:22 PM, Marter1229 said:
Does the gluing of painted parts give you any problems?
I try to avoid gluing painted parts, but if needs must I use cyano glue on painted parts.
On 6/18/2020 at 8:18 PM, Marten said:
Hi Ian.
Steel-wire, cable-laid, 21 strands, 70 mm diameter in all, runs aft from the main steering-barrel in front of the chart-house, down from the Liverpool-House to the after deck over two rollers, mounted in these "slots", further aft then through some horizontal on-deck rollers to the tiller below the poop. And please don´t forget: 21 strands it has to be .
Cable-, not hawser-laid 🙂
Gx Marten
Cable-laid....21 strands....0.5mm scaled diameter....got it! Thank you very much Marten! So I need to make little rollers where the slots are, then the wires pass over the rollers, angle through the railing down to the after well deck, run along this deck on say two more pairs of rollers, then (a) disappear through openings in the poop bulkhead? (b) pass through more rollers to go up to the poop deck then go down through this deck? I've seen such tiller lines on other build logs but didn't realize they would be routed like this on such a big ship. Do you have a reference book detailing things like this on the big windjammers....I'd like to buy a copy. Thanks again, Ian.
Dear Yankovitch: Not to worry, this log will continue until the bitter end. I tend to go a while between entries as opposed to reporting daily details.
I worked for a time on painting deck machinery. The instructions say to just cover all winches, bollards, capstans, and cleats etc with matte gunmetal grey, but that sounded awfully drab for the pride of the Laeisz fleet. Instead I painted the machine "frames" the same green that I used on the bollards, and used tank grey on the "innards", just to accent them. Here's a picture of the wheel just in front of the chart house on the midship bridge deck.
Incidentally, I wondered what those black round things were at the corners of the house until I noticed a line drawn in the instructions, with no reference. I realized the steering lines from the ships wheel pass round these swivels then go down through the deck in the slots just beside the aft ventilators. Does anyone know if that would be cable, or chain? Thanks in advance.
Here are all the decks at the moment. As I mentioned in an earlier post I decided to paint a white "waterway" at the edges of those decks confined by bulwarks to make painting inside those bulwarks easier after I glue in the decks. Capstan barrels are all glued in but not yet the heads with bars because they're fragile.
Of particular interest to me are the Jarvis triple brace winches. The photo below shows Heller's rendition of the full set of five beside one of the cargo winches. Each of these 1/2"x1/4" machines has three pairs of brace lines emanating from it. Looking forward to rigging them **not**. Also I want to add a shaft with hand cranks at each end from brass microrod, somehow. Don't know why Heller didn't provide cranks - the pumps and halyard winches have very detailed little crankwheels and such. Incidentally, "Royal Clipper" replaces each of these triple brace winches with a pair of hydraulic winches turning in opposite directions with each single brace line from a winch fanning out to the three lower yard ends on its side of the ship. Not sure how they handle the brace geometry problem which these brace winches with conical barrels were designed to solve.
I also painted the gilt work at the bow and stern. This has given me the merest hint of what it will be like to paint all the gilding on the "Soleil Royale" when I get to her next. It is pictured below, not ideal but pretty good to naked eye. I'll need to improve. I ordered vinyl adhesive lettering for the name "Preussen" in white letters aft of this gilt work on each side, and also the name and home port in gold at the stern. Unfortunately I could not find sub-2mm letters so I will have to use the decal for her name in the gold-framed spaces which is too bad as I expect the decal will show between the letters. The order was from UK and it is certainly taking its sweet time getting here.....alas covid....
Getting tired of green and grey machinery I decided to start assembling the masts. First I had to try to reconcile Heller's basic diagram with Underhill to decide where all the stays and backstays attach. I cut off the too-large molded plastic eyes and drilled holes for copper eyes. Then I started painting the masts and lower yards, completely painted in one colour as in ships of the time (Humbrol #63 according to Heller, which looks about right).
It was a long and ongoing process:
Wife"What did you do today?" Me"Painted spars".
Next day: Wife"Did you work on your ship today?" Me"Yes I was painting spars".
Next day: Wife"Did you paint spars again? Me"Yes""
Next day: Wife"Are you finished the spars yet?" Me"Nowhere near"
There are many many spars on a 5-master. My #63 paint seems to need four coats to give a consistent colour coverage. To add to the pleasure, every one of the thirty yards on this ship has five ejector pin marks to fill on its upper surface. Could not Heller have put them on the lower surface , out of sight? Similarly, each topgallant mast has three of the same on one side. All these parts are each molded in a single piece so perhaps Heller were making sure they'd come out of the mold without warping?
I mentioned earlier that the Passat model has much more detailed yard trusses. Here is a typical yard (as yet unpainted) from this model. Not a very realistic appearance. The mast has a tiny little semi-circular pin to engage the hole in the "truss". I've decided that the risk of these attachment points breaking if I brush a yard while rigging is too high, and could be a nightmare to fix, so I am going to make some basic trusses from 1/32" brass rod. Nothing fancy, just replicate the basic shape and not worry about trying to produce bolt heads etc at the swivel points. This stalled for a while due to COVID isolation until I discovered that my local hobby shop is doing curbside pick-up of orders so I just got some rod yesterday. I will do the same as on my Heller "Victory" i.e. have the rod inserted in a hole drilled in the mast, unglued, so the yard can "give" if I happen to knock it.
Speaking of rigging, this kit does not provide the rigging screws to tighten the shrouds and backstays. I figured I would make something out of micro brass tubing and 0.3mm brass etched eyelets. I've discovered that K&S no longer sells 1/32" brass tube at the retail level. One can, however, order direct with minimum 30 pieces at USD$3.60 each.; you can do the math. Fortunately I've since found tubing by Albion Alloys in even smaller sizes and plan to order from UK.
That's all for now.
Thank you "Blue Ensign". You'll have noticed I copied your idea of having a little Nelson and Hardy, in addition to all the other inspiration I got from your build on Pete's website. 🙂
- Blue Ensign and Bossman
- 2
Rob, I love your Cutty Sark diorama with the famous jury rudder! And your "Great Republic" scratch build is incredible. I fear my efforts will seem simplistic to you, but here are some photos anyway.
Hull plates I added below waterline:
I taped the decks in place so we can see where we are going. That's my serving machine in the background (it makes a handy stand for the upside-down hull at this point):
Deck close-ups. This is the first time I ever used a wash and I like how it turned out. But there are so many coats of paint and varnish I worry about gluing stuff down, especially the pin rails which will have stress on them when rigged. Haven't painted the inside bulwarks yet. I think I will paint a white "waterway" along the deck edges so I can glue in the decks then paint the bulwarks without fear of getting some paint on decks. They call for the cap rail to be painted Humbrol #63 (same as all spars) but I may leave it white just to make it easier.
That's all for now.
- coxswain, GrandpaPhil, Blue Ensign and 8 others
- 11
Thanks everyone, I'm quite proud of it.
Y.T. --- Plastic kits are all plastic, no wood. Where my topmasts and topgallant masts etc. were unpainted wood, I painted the plastic with a suitable light base coat colour (suitable for a pine spar) then dry-brushed sparingly with Humbrol matt khaki, then applied a coat of Humbrol satin varnish. This is one of the things I learned on Pete's web site and I was amazed at how easy it is to make plastic look like wood. I used wood dowels or bicycle spokes on the inside to stiffen them when gluing halves together.
As for blocks, the Heller kit does indeed supply "blocks" but they bear little resemblance to blocks. Most people building this kit discard them and buy after-market wooden blocks. I recommend the beautiful ones from https://www.syrenshipmodelcompany.com/
Speaking of discarding, the Heller kit has many shortcomings which I will just mention now to forewarn potential builders:
It comes with two odd colours of thread in a couple of sizes, and recommends dying in tea or coffee(!?). I discarded it and bought Amati rigging thread in about seven different diameters and two colours. I also learned about this thread on that website.
Plastic deadeyes are hard to mold. To have the three holes, the mold must pull apart from the two faces of the deadeye, but then it is not possible to mold a groove around the circumference to encourage the shroud to stay in place. Heller did their best, adding a single ring around the circumference which prevents the thread from slipping off in one direction only. I found this impossible to rig and followed the advice on the website i.e. discard the deadeyes and buy wooden ones. I wish Heller had simply molded the deadeyes in two halves which we could glue together and save some money.
The kit does not include the chains for the shrouds. They show a half-assed method involving loops of thread. The solution is to buy one of Daffy's brass etch sheets which provides beautiful chains and preventers as here:
The kit lacks any means of attaching the yards to the masts. In the case of the lower yards, this is sort of ok because they were restrained by rope truss pendants which you can rig but you need to know where to add eyebolts to the deck to rig properly. For the other yards you need to make parrals of some form; see previous photos for one of mine made with small seed beads and small pieces of wood.
Those are the major issues. There are others, like the difficulty painting the stern moldings and figurehead shield due to uncrisp molding, the plastic hammock stanchions with no holes which are best replaced with Daffy's etch, the complete lack of guide pins when gluing things like cannon barrels and spars, horrendously awful rigging notes in the instructions (buy a book), and for the completely detail-oriented the erroneous deck plank shift pattern.
But for all that, it builds up into what is widely considered the finest and most accurate plastic ship model on the market.
I had a build log on the now apparently defunct "HMS Victory Modeller's Knowledge Repository..." by Pete Coleman, but all this is gone now. I thought I'd just show a handful of progress shots, and the completed project. I never could have built her like she came out without that web site; it's a shame about it. For any readers contemplating a build, know that there are now available seven sheets of brass etch to enhance the kit. Everything from accurate shroud chains to nice stanchions to trigger locks for the cannon. They are superlative, although I only ordered two as this was my first model in decades and I had never seen brass etch to that point in time.
You can find the brass etch here:
http://www.dafinismus.de/plates_en#anker2
Never served thread before. After reading about serving machines I made one out of my old meccano. Here are the first served shrouds around the foremast head. The deadeye strops are brass etch. I later changed the jeer block lashings to natural colour, just to make them jump.
My serving machine.
I bought this kit in the early 80's. The decals crumbled to bits when I wet them, so I ordered adhesive vinyl lettering for the figurehead. I painted the false panels blue instead of black because I liked the look with all the other blue trim.
The brass etch binnacle, with (barely visible) lantern and compasses. Home-made post and rails at the poop deck ladders. Syren 2mm blocks on the cannon tackle. Larger brass rod belaying pins so my big clumsy hands could tie off to them. Notice the brass etch boarding pikes on the mainmast. Hammock netting from HobbyLobby, on brass etch stanchions. Added brass handrails down the main companionway ladder. Ready to proceed with rigging.
First look at masts plunked in dry assembled. Looking like a ship!
Lower shrouds complete.
Psychedelic mizzen ratline guide from cereal box. Why not the blank side, you ask? I have no idea now.
Home-made topsail yard parral.
The main top. A good look at the futtock shrouds, the mainyard sling, and the jeers timber hitched to the yard. Catharpins visible aft of the mast. Also seen are the foreyard braces and blocks. The mainstay and preventer mice were made by gluing beads to the stays then wrapping in thread. I did not attempt to actually stitch the cross threads on the mice. Note also the serving on both stays around the mast. The bullseye pairs lashing the ends of the topgallant shrouds are just inboard of the topmast shroud deadeyes. As I mentioned before the jeer block lashings are natural to enhance the aesthetic, at least in my eye. Amusing story - when I ordered the large wood blocks for the fore and main jeers, and the cat blocks, I ordered six from the supplier. Unfortunately I did not read closely enough and received six packs of multiple blocks which I am unlikely to ever need in the future. It wasn't worth the postage to send them back to the UK and pay their restock fee. 🙄
After-market stream anchor lashed to port sheet anchor. Anchor buoys, one of which is attached to the port bower anchor, lashed to shrouds. Brass etch chains replace Heller's ridiculous proposed scheme using thread and over-sized strops on the lower deadeyes. Note the evergreen lining inside the gunports to give the plastic hull a more realistic thickness. Each gunport lid received four brass etch eyes, one pair inside and one outside for the lanyards.
A good look at the brass etch futtock hooks. I cheated on the futtocks/catharpins by forming each set from one continuous thread running from hook to hook. Tying the true-to-life knots was just beyond necessary, for me.
The stern. What a pain to paint the not-very-precisely-defined decorative elements especially the ballusters (and those lanterns) !
Decided to use evergreen strips to enhance the ships boats, whose hulls are rather bare as supplied. For example the launch. Speaking of which, Heller supplies fewer boats than she had, mostly at wrong lengths. I shortened one of the supplied hulls and augmented the set with others from my parts shoebox.
The set. The pinnace and Admiral's barge are painted according to the whims of the officers and the Admiral respectively. Other "working" boats are all the same colours. The blue pinnace was fun to do with its additional trim at bow and stern.
Nearly there! Decided to rig bowlines too, hitched to yards.
Copied Blue Ensign's idea to make little Lord Nelson and Captain Hardy figures. Faces aren't very good but ok to naked eye. Nelson's legs were broken and a slice removed at the knees since he was a relatively short man whereas Hardy was tall. Hats fashioned from Evergreen. The donor figures, again out of the old shoebox, were left over from the Revell Constitution I made in the 70's.
Had a cast acrylic case made for her, atop a cherry cabinet I made for the purpose. Sat three of the boats on the shelf to allow viewer to see down to the upper deck through the skid beams, but really you cannot see even the cannon rigging on quarterdeck. At least my eyes cannot. Print hung above is Geoff Hunt's "England Expects", depicting "Victory" among the British fleet approaching the combined fleet, at walking pace on a near windless day, on the morning of Trafalgar.
If, dear reader, you are trying to decide between this kit and "Passat", be aware that the "Passat" kit provides both blocks and plastic shroud/backstay turnbuckles but no sails i.e. the exact opposite of this kit. Further, the yard trusses are much more detailed (and fragile) on "Passat" than the simple trapezoidal blobs provided on "Preussen". But there was only one ship like "Preussen".
You can read about the "Passat" kit here:
https://modelingmadness.com/review/misc/ships/ger/komapassat.htm
If you elect to build "Preussen" then surf on over to the site below for very detailed rigging inventory and an extremely helpful and detailed belaying diagram you can download:
http://jans-sajt.se/contents/Navigation/Modelling/R_Preussen.htm
I highly recommend Harold A. Underhill's book "Masting and Rigging: the Clipper Ship and Ocean Carrier" to aid in rigging "Preussen" (or "Passat" for that matter).
One last note: I just returned from a week's cruise on "Royal Clipper" which is a 440ft five-masted square rigger inspired by "Preussen" which carries 226 passengers and 106 crew. It's an awesome ship to sail on; I've never had any interest in a trip on one of those "excessively excessive" cruise ships but THIS is a different world. I never got tired of watching them make sail, or of coming up on deck in the middle watch to see the stars and the sails drawing. Here is the ship:
And here I am steering all 5000 tons of her (still in my bathing suit from snorkelling just before we set sail again). The fore lower topsail was damaged in a strong wind and was sewn by the bosun on deck the next day. Sorry, no front views for reasons of internet privacy:
If you are interested in sail, and I guess you are if you're on this site, consider a cruise in Med or Caribbean, or better yet a transatlantic crossing on this ship (disclaimer: I have no connection to the ship or company). You can read about "Royal Clipper" and the company's other sailing ships here:
https://www.starclippers.com/en/
- coxswain, Grey, Blue Ensign and 3 others
- 6
Just recently started this kit after finally finishing Heller 1/100 Victory. What a change from 18th century rig and cannons. Long narrow all iron hull with midship bridge. Five iron masts. The decks are crammed with machinery such as manual brace & halyard winches and several capstans..
Kit Summary: Hull halves were crammed across the kit box diagonal; I think they must have wanted to use the same box size as the Passat kit. The stem and lowermost rudder mount were bent because the diagonal really is slightly too small. Kit includes thermoplastic sails. Kit does not include blocks, or any representation of turnbuckles for shrouds and backstays. Aside from sprues holding the 5 decks (foc'sle deck, fwd well deck, bridge deck, aft well deck, poop deck) and some hatch covers, there are only six parts sprues four of which are identical - a very tiny pile compared to the ~21 unique sprues for Victory. The instructions are good for assembly, with many fine diagrams showing what goes where, but rigging details are sparse. The good news is that Heller did not scatter the rigging instructions all through the assembly drawings but instead devote several drawings at the end to rigging: stays; shrouds and backstays; lifts and braces; buntlines and halyards. The bad news is that belaying points are in Heller's patented microprint. Also the proper connection of Jarvis brace winches is not shown i.e. leading blocks.
At this point I must mention that Heller's engravers depicted the steel hull plates nicely, but they mysteriously disappear below the waterline. It bothered me enough that I bought Evergreen 0.005" sheet and cut it into plates which I glued on individually, in a double layer every 2nd row to simulate the riveting overlaps. It looked like hell at first, but after some caulking (acrylic painter's caulk squeezed out of the tube via a very small hole drilled in the cap end to provide a very small bead) and painting it actually turned out pretty well.
I have joined the hull halves and painted the black/white/red colour scheme. I have painted and washed and varnished the decks and I am busy painting various bits of deck machinery and steel bulkheads. I need to attach it to a stand before gluing in the decks, though.
One question for anyone who may have built this kit: there is a little auxiliary bridge on the after storm gangway with a second binnacle. Around two sides of this bridge there are rows of something similar to plant pots (?!) outside the railings. They are hollowed out. They do not appear to be for something to glue into as far as I can see in the instructions. Anyone know what they might be? The only thing I can think of is, possibly, fire buckets?
I will try to figure out how to attach some pictures later; it's late now.
HMS Victory by Ian_Grant - FINISHED - Heller - 1/100 - PLASTIC
I hope you get one rkwz! If you buy all of Daniel's etch sheets you will have a museum quality build. Just be sure to obtain a copy of "Anatomy of Nelson's Ships" by Longridge in order to rig properly.
