Everything posted by Baker
Missing body plan
Baker replied to rafterrat_2005's topic in Building, Framing, Planking and plating a ships hull and deck
Does this help?? http://modelshipworldforum.com/resources/plans_and_research/InterpretingLineDrawings.pdf -
At about 6 km distance
And good luck with your first build.
Greetings from East flanders
And greetings
Attach the rudder to the stern. Making hinges. The plastic hinges will be a weak point. To fix this, copper pins of diameter 1mm are placed. Holes are drilled in the stern at the right place. A knock with the hammer, and the rudder is well fixed. This will not come loose anymore. Finish the hinges A light layer of metal paint is first applied under the white layer. The upper hinge is painted black. Bolts are attached on the helm. Painting on the bottom in white and after some polishing and dry brushing the rudder is ready. I do not find any paintings or drawings from this period with chains or ropes attached to the rudder. These will therefore not be applied. Thanks for following
- 756 replies
- galleon
- golden hind
Greetings Patrick
Hello everyone, Thanks Ondras for the compliment. Back from vacation and returned to the shipyard. The rudder and helm are sanded and in the right shape. The upper part is collored and the lower part has a first light coat of white paint. Now further details are made. I started with the hinges, as always in plastic. I would rather have made them in metal. But after a eye surgery, I have trouble viewing small metal objects under a lamp. All metal parts shines so brightly that I do not see what I do. Before folding the plastic, it is treated with thin plastic glue. This makes the plastic soft and bends easily. Gluing on the wood is with CA glue Thanks for following
- 756 replies
- galleon
- golden hind
Roter Löwe 1597 by Ondras71
Baker replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Well done Ondras. -
And greetings from Belgium
kit review 1/72 Cannon Jolle - Master Korabel - Baltic Sea Gunboat
Baker replied to ccoyle's topic in REVIEWS: Model kits
Does indeed look like a simple model to build and with clear assembly instructions. Also with enough extra detail. Maybe a good model as a first build ? A pleasant awakening for me when I read this. At half past six in the morning (in this part of world) 😪💤 -
Thanks Lawrence I started with the rudder. Nobody knows if the Golden Hind had a whipstaff or not. They came into use somewhere in the second half of the 16th century. so adding one is not completely incorrect. The rudder is made of 3 pieces of wood. The helm. I find 2 ways to attach the helm to the rudder. The helm passes through the rudder. Or the helm goes around the rudder Possibilily 1 is apparently from a later period, from the beginning of the 17th century. Possibility 2 seems to be the most common during this period. So this it will be. about in the right shape and bent. My roughly made rudder with the helm. Still a lot of sanding and detailing to do. Thanks for following
- 756 replies
- galleon
- golden hind
Thanks; Maybe I should install a mine juke box... Party 🎤🎸💿🎺
- 756 replies
- galleon
- golden hind
Beautiful work Dick, Very accurate and precise.
- 263 replies
- nave tonda
- round ship
Hello, Because of the exceptional warm weather in this part of the world and other urgent matters that came first, there is little progress to report. But in the meantime I have succeeded in placing the LED lighting. The quality of this work can be much better. But, once the deck is fully placed above it, little of this will be visible. The LED lighting is purchased just after Christmas and New Year. Then there is sale, 40 LED lights with battery holder for about 2 euros ($ 3?) The lanterns are made of plastic sheet. Where the lighting remains visible, lanterns have been placed. Not at other places. a first "prototype" There is still room enough to place the deckplanks above the lantern visibility through the cannon ports I do not think that in the 16th century there was one ship with so much lanters below deck as on my model .... Thanks for following and reacting (the like button is now a reacting button, i noticed 👍😉).
- 756 replies
- galleon
- golden hind
Greetings from Belgium
Cool old sail ship request for info please
Baker replied to Muskies's topic in New member Introductions
Your children can sell very well And -
Hello from therealangrysailor
Baker replied to Therealangrysailor's topic in New member Introductions
Greetings from Belgium -
HMS ROYAL KATHERINE 1664 by Doris - 1/55 - CARD
Baker replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Congratulations to you. And your assistant- 1,035 replies
- royal katherine
- ship of the line
Interesting build to follow. I had no idea how such a ship was built at that time. Until now. Great work Steven
