Baker
Everything posted by Baker
  1. Beautiful work Michael. During my visit to Vasa I took this picture. Looks to be a simple but effective solution.
  2. Indeed Jan After having checked my problem a second time. The channels can be made 1.5 mm smaller without getting into trouble. So about 85cm wide to scale 1/1 Thanks,
  3. Thank you for explaining the "chains / channels" question. Good idea to look at channels of the Mary Rose and other ships. Turned out i have a drawing of the MR. Looking at Mary Rose I find about 65 cm. The ship with the barrels is about 75 cm My channel of 90 cm is therefore very wide. it will have to be thinner. Thanks for following and likes
  4. Hello Have not started building again. But I did start thinking about the next step. The places where the deadeyes and schrouds are attached. I do not know the correct English name, but in some logs they are called "chains". Strange "chain" means something very different for me in the English language?? Looking through my documentation there are several possibilities. A simple method as on the Vasa ship (early 17th century) and also applied to most Golden Hind scale models. And, an older method where multiple vertical support beams are used. The second method seems better for this time (about 1570-1580). She can also be seen on drawings by Mathew Baker. So it becomes the second method. Biggest question: how wide were these things? I find narrow and wide versions in my documentation. So first i test how wide they should be on my model, to get no problems later with the schrouds who can come against the hull. Somewhere in a log I saw this method. Ideal if you work without a plan. So we go for the wide version (no other choice) otherwise I will get into trouble later. This makes about 90 cm (3 feet) on a real ship. Reasonably wide, but it can explain how they could place barrels here that served as sanitary facilities. Thank you for following, and hopefully more updates soon.
  5. Indeed, a very delicate work. Am already curious about the result.
  6. And greetings form Belgium
  7. Beautiful work Welcome to MSW and greetings form Belgium
  8. Greetings. Groetjes vanuit België
  9. Nice work, Remember, speed and modeling are not always good friends. Enjoy the drink
  10. Welcome back Greetings Patrick
  11. Steven, Interesting information can be found on this site (You can download a pdf file) : http://www.earlymodernengland.com/2010/06/the-evolution-of-hull-design-in-sixteenth-century-english-ships-of-war/ Google search : The Evolution of Hull Design in Sixteenth-Century English Ships of War
  12. Welcome to MSW Greetings from Belgium
  13. Welcome to MSW. Would also like to see your photos Greetings
  14. Impressive what you do with plastic. I have been building plastic military kits for more than 30 years myself (kits, semi scratch and scratch). This is great work and really worth following.
  15. Greetings Patrick
  16. I found this buildlog on a Dutch forum. Impressive model. Of course with Dutch text but with nice pictures. http://www.modelbouwforum.nl/threads/hms-victory-caldercraft-1-72.205911/ http://www.modelbouwforum.nl/threads/hms-victory-caldercraft-1-72.205911/page-23
  17. Proficiat met je afgewerkt model. Congratulations on your finished model.
  18. Beautiful planking. I have the same idea to use Plexiglas as a base. But I have not reached that point yet. I am therefore curious about your working method and the result. Good work.
  19. And greetings from Belgium
  20. Thanks, I'm doing my best. LOL 😂 I do not like sports. The only "sport" i do is rifle shooting (completely legal according to all Belgian laws of course!!)
  21. The following parts are ready and installed. From now on, the shipyard is on hold for a while. I have had pain in both arms for some time. Doctor's conclusion: tennis elbow on both arms, so rest for a while, no model building, no gardening... grrrr. Thanks for following, And it is not because the shipyard is on hold, that I will not be active on this forum
  22. Marius, I made holes in the hull and then glued the gunport surrounds into these holes. Then they are sanded flat with the hull. Ik maakte gaten in de romp en kleefde daar de kanonpoorten in. Daarna zijn deze mee vlak geschuurd met de romp. I glued pieces of wood behind the gunports. This method proved to be very cumbersome. Gluing pieces of plywood between the frames is much easier, and paint the inside black. You can find this method in several logs.k Ik lijmde houten blokjes achter de kanonpoorten, deze methode is zeer onhandig. Lijm stukken triplex tussen de spanten en schilder deze zwart. Je vind deze methode beschreven in verschillende bouwlogs. Normally under the waterline, the color is white. Normaal is de kleur onder waterlijn wit One of the reasons why the Vasa sank so quickly was too little depth. Eén van de redenen waarom de Vasa zonk was te weinig diepgang.
  23. this ? http://modelshipworldforum.com/resources/Rigging_and_Sails/ScaleSails.pdf
