Baker
Everything posted by Baker
  1. You have two cannons. Maybe you can build a part of the stern?
  2. When an old men makes a drawing on a smartphone ...🤣 Bleu = seize Kirill is more professional 😉
  3. Scratch modeling is fun. And you are doing a very good job. And yes, those little life boats are actually a model in themselves. I always enjoy following the construction of one of these, but starting building one myself...🤔 😉
  4. Good news. The clamp has been surgically removed and repaired. Model and clamp are doing well after this medical surgery.
  5. Thank you for the nice comments. In the meantime, I've had a moment where you say to yourself "kieke" Flemish for "chicken". A fun way to say stupid 🤣 The plank is clamped and the clamp is now blocked And the iron wire, which kept the sides of the rear castle at the right width, and on which I have already cut my fingers a few times. has been replaced by a pair of threaded rods. Safety first at the shipyard 👍
  6. His model participates in competitions, the aim is to follow the plans you have as faithfully as possible. He succeeds well in this and has already won several prizes. No one knows whether the model is completely historically correct, no detailed construction drawings were made during the era of 16th century period.
  7. With the beam for the swivels on the port side also installed and the frames made thinner, time to continue working on the transom. The clinker planking that was previously installed has been removed. And the intention is to install two stern chasers here, the openings of the swivels will then remain empty. Applying the same number of cannons as the Anthony drawing is not feasible. A nice drawing to show to a king, but not a practical design in reality. Several attempts... And after three attempts it became this. Finish the holes for the swivels with a beam on top First i make grooves. This is more work, but positioning the beam correctly is much easier. And above this beam back to clinker planking. This will provide more strength when the frames are made thinner later.
  8. If you drive it into a mine field, and the tracks "fly in the air". Then it does not matter which model of tank you are in. You are, as they so aptly say in English, a sitting duck. 😪
  9. And good luck
  10. wow. An comment with so much poetry gets not one, but three smileys
  11. All wales on the clinker planking are installed. On the starboard side a beam has been simulated where the swivel cannons will later be placed And the thinning of the frames has begun First a pencil line. Then the more "heavy tools", used carefully of course. One side is from 6 to 5 mm, the intention is to later make the frames even thinner above the beam of the swivels to 4 or, if possible, 3 mm
  12. You're doing very well. And it is very nice to follow. I would only attach the backstays of the fore and main mast more forward, like on the mizzen mast. If you tie them so far back they can get in the way of later rigging.
