Posts posted by bruce d
Hope you're OK, doesn't sound like a 'good flight'.
Found this unidentified vessel in an online collection of photograph albums ( [Photograph Album] : Eppler, Arthur O., 1873 - : Free Borrow & Streaming : Internet Archive )
Staring at this, I almost sympathise with the U-boat commander.
- Ryland Craze, AJohnson, druxey and 3 others
6
"ON NAVAL TIMBER AND ARBORICULTURE; WITH CRITICAL NOTES ON AUTHORS WHO HAVE RECENTLY TREATED THE SUBJECT OF PLANTING" 1831, by Patrick Matthew
The story behind the scenes of the techniques devised to keep the fleet afloat including the shipwright's methods.
This book is in the public domain. Another scan which may be easier to read is viewable here: On Naval Timber and Arboriculture - Google Books
It's interesting to see the difference between this build and my CAF longboat, purchased about five years ago.
The kit has evolved. One of the changes is the more detailed stern. I had already decided to replace the plain stern in my kit: now I see Tom has had the same thought.
hmcarlin, you're off to a good start, I will pull up a chair.
A tungsten dart works very well.
If you plan on working with metal, it's worth considering having a dedicated scriber for metal and saving your awl for wood.
Welcome to MSW from rainy Sussex.
- AJohnson, Keith Black, Mashuno and 1 other
4
36 minutes ago, tmj said:
You can 'also' purchase a scale ruler and save yourself from doing the math.
This is good practice, you will probably find yourself reaching for it constantly.
- Canute and Harvey Golden
2
Can I suggest the screen protector material for phones? My first attempts at cutting this stuff to exact sizes were encouraging and I have set aside a couple for use on the stern windows of my Mediator (when it eventually returns to the workbench).
I successfully stuck a mocked up window frame in place with a tiny amount of acrylic varnish in my experiments.
It's also cheap if you don't get one for a current model phone.
Bruce
2 hours ago, Dr PR said:
4. The only drawback I have found with the hollow tube handle pin vises is that they do not have a finger rest on the end of the handle - just the end of the hollow tube. This is a bit uncomfortable when using a finger to press the tool as you are turning it to drill holes. I have thought about making one - perhaps adapting the rotating finger rest from one of my other pin vises that has multiple collets. Bit this hasn't been a big problem
I agree with everything Phil says and there is an easy fix for the finger rest.
If you wrap a rubber band around a small bolt, M5 in my case, you can simply slide the threaded section into the open vice end and the head will form a finger rest. The rubber band has a friction grip inside the barrel of the vice to hold it in place.
One of mine has a longer bolt wrapped in electrical tape instead of the rubber band so it rotates smoothly when drilling.
Multiple pin vices are the way to go, IMHO. I have Starretts and others and for most jobs the cheap ones work just fine as long as the collet is gripping.
HTH,
Bruce
- palmerit, Canute and Ryland Craze
3
Hello Paul,
Having viewed thousands of files at The National Archives I am pleased to say that the summaries in the descriptions are reliable. There is an in-house system for reporting any discrepancies and the only time I found something to be scrutinised it was reviewed and edited in a couple of days.
For what it's worth, I will view the original on my next visit and transcribe the full text for posting here.
However, the first thing to do will be to look at any correspondence leading up to this instruction from the Admiralty as I expect it didn't come out of the blue.
In the meantime the flat statement 'don't do it anymore' tells us that (A) it was being done by someone and (B) it stopped from this date. I feel confident on this last point because the dockyards and contractors would know they would not be paid.
FWIW, this was the period when dockyards were still buying in most of the copper plates before the Admiralty took control of copper production.
Don't have my notes but I'm sure I read a report of a ship's coppered hull being damaged to a greater degree than expected when a false keel was torn off; if I can find the incident (or someone recognises it?) then it's possible this was a factor in the Admiralty order.
Bruce
- Chapman, Thukydides, mtaylor and 2 others
5
On 3/30/2025 at 5:30 PM, bruce d said:
February 15 1782 directing shipyards ... "... not to copper the false keels of ships in the future".
40 minutes ago, dafi said:Is there any hint or knowledge if the keel was coppered underneath going round th whole keel or if the coppering went "full stop" at the edge of the false keel?
XXXDAnSorry, that is all the summary says. If I visit The National Archives later in the year I will look at the original document to see if it explains further. Personally, I expect the keel was coppered and the false keel attached afterwards. I can't imagine they would copper the whole hull underwater and still leave the keel vulnerable to the dreaded worm.
Regards,
Bruce
6 hours ago, bruce d said:
ADM106/1273/36
Hi Pat,
It's not downloadable but the summary I quoted is from the description.
Use the ADM reference above in the advanced search section of Discovery (the National Archives online catalogue) and you will see the description.
Let me know if you have any questions.
Cheers,
Bruce
- mtaylor and thibaultron
2
The National Archives (UK) has a searchable catalogue so I searched 'carronade' and 'deck' and came up with some interesting anecdotes. Posted below are extracts from the text of file descriptions relating to ships I identified as 74s, including captured ships. Please note the file descriptions are summaries of the contents so may not be exact quotes of the wording within the document. The ADM xxx/xxx reference you see in most of them is the individual file number.
This first item is interesting by pointing to Admiralty instructions on the subject:
Folios 168-169: Davidge Gould, HMS Majestic, Hamoaze.
Reports that his ship has been fitted and that there is a Navy Board order to put 32-pounder carronades on the quarter deck, but that they await orders from the Admiralty. The carronades are ready to be taken aboard as soon as it is received. Admiralty note on rear says was not a general order given re fitting Line of Battle ships with carronades on the quarter deck except in the wake of the rigging? Orders dated 17 March 1797 and 23 March 1797 from the Navy Board, described the fitting to be made.
1801 Mar 30 ADM 1/1848/127
The extracts below are mostly general correspondence from Captains or Port authorities concerning individual 74s.
Arthur Kaye Legge, HMS Repulse, Hamoaze. States the Carronades fitted on board HMS Repulse having been found to answer in every respect and being clear of the rigging and the ship being equal to carry the four Eighteen Pounders on the Quarter Deck and Forecastle. He requests they give directions for their remaining as they are never without any attention.
1805 Nov 17 ADM 1/2074/116
Home Popham, London
Colonel Congreve informs him that there will be no difficulty in fitting the 'new principle' carronades on HMS Sterling Castle, and this mode will enable the guns to be worked with fewer hands, while taking up less room on the quarter deck.
1813 Jan 23 ADM 1/2344/20
Samuel Hood, HMS Courageux, Woolwich. Regarding the difference between the number of guns and carronades on Courageux's quarter-deck and the forecastle and the establishment, and requesting that directions be given to the Officers of the Ordnance at Woolwich Warren [Arsenal] to fit such guns as their Lordships deem fit for the ports fitted to those decks.
1800 May 20 ADM 1/1922/240
Sir Benjamin Hallowell, HMS Tigre in Portsmouth Harbour.
Asks to be allowed to have 2 x 68m carronades fitted in the Bow Port of the lower deck instead of 2 x long 32m he left at Malta. Also asks for small sweep pieces to be fitted to the gun carriages instead of the horns they now have. Comments that the foremost gun on the lower deck is placed so far in the round of the bow as to risk injuring the men working the next gun.
1808 Feb 10 ADM 1/1934/11
Henry Blackwood, 30 Edward Street, Portman Square, London. Requests replacement of guns on HMS Warspite (four long heavy 12 pounders on the 2nd deck and two in the forecastle), with 32 pound carronades, which will reduce the load significantly. Also considers that the ship will benefit by changing the long 24 pounders to 18 pounders as the vessel is suffering with the weight.
1809 June 12 ADM 1/1545/121
Edward Codrington, Charles Street, Berkeley Square, [London]. Request for his ship (HMS Orion) to be supplied with eighteen pound guns for her forecastle and quarter deck, instead of the thirty two pound carronades and twelve pound guns and explains his reason for the request.
1810 Feb 16 ADM 1/1656/92
William Sugden in the absence of Commissioner Proby. Receipt of warrants to provide all two deck ships with 18-pound carronades on their round house instead of 12-pounders and to receive candles from Mr. Bedford on contract.
1781 Oct 16 ADM 106/1264/222
William Hargood, HMS Belleisle, the Hamoaze. Asks permission to leave the six Carronades on his Poop Deck ashore, as in action he has found they are too heavy for that deck.
1806 Mar 12 (note: this is a captured French 74) ADM 1/1932/68
Robert McDouall, HMS Ganges, Portsmouth Harbour. Requesting that carronades be supplied for the quarter deck to replace the 9-pounders, as these would both strengthen the ship's force and reduce top weight.
1796 Nov 28 ADM 1/2131/9
Charles FitzGerald, Portsmouth. Requests the Admiralty consider ordering six 24-pounder carronades to be fitted to the poop deck of HMS Brunswick.
1794 Oct 12 ADM 1/1794/82
William Essington, HMS Goliath, Portsmouth. He asks that the quarter deck on HMS Goliath is fitted for 2 carronades.
1801 July 7 ADM 1/1767/66
Richard Grindall, HMS Ramillies, Torbay. Requests an order for HMS Ramillies to be supplied (when she is next in Port) with 32 Pounder Carronades in the room of the 9 Pounders on the Quarter Deck as other ships in the class have found them of great utility. Also two additional 18 Pounder Carronades for the Poop Deck Having only four at the moment and space for more.
1799 Aug 25 ADM 1/1846/159
Thomas Graves, HMS Cumberland, Portsmouth Harbour. Request for HMS Cumberland to be equipped with six 32 pounder Carronades in lieu of her six 18 pounder Carronades on her Poop. Tow of the former he would wish to have placed on the Fore part of the Quarter Deck also with two Carronades 68 pounder on the Forecastle which are in store at this Port.
1799 Sept 26 ADM 1/1846/82
Alan Hyde Gardner, HMS Resolution at Portsmouth Dock.
Requests that HMS Resolution be fitted with thirty two pound carronades on the Quarter Deck and Forecastle instead of the usual nine pound carriage guns.
1800 Nov 3 ADM 1/1847/14
Reiterates his request for a complete fitting of carronades on the Quarter Deck, having with the builder in Portsmouth dockyard, established that there is little difference between the carronades and carriage guns in how far they throw their muzzle.
1800 Nov 10 ADM 1/1847/15
Askew Pafford Hollis, HMS Achille, Portsmouth. Having written on 20 December 1813 to the Admiralty through Admiral Sir Richard [Hussey] Bickerton Bart requesting two 32 pound Carronades on trucks might be embarked for the Quarter Deck of HMS Achille, in lieu of two long 18 Pounders. As HMS Achille's Guns are about to be embarked he requests directions be given for the two Carronades to be supplied.
1814 Jan 25 ADM 1/1949/21
Receipt of letter and warrants to report on the feasibility of fitting carronades on the Princess Amelia, to prepare the quarter deck of the Cambridge to take carronades, to report on the number of ships that could be fitted with carronades and serve in the Summer in the North Sea ...
1782 Feb 15 ADM 106/1273/36
There are plenty of other ships and smaller craft mentioned as well but I have not included them. If interested, the site is ... Discovery | The National Archives
HTH,
Bruce
- druxey, AON, chris watton and 1 other
4
Further to my above post, I thought the wording from the source might also address another point. It is a contemporary example of carronades not being counted in the armament as rated.
"The Berwick was a good ship, and, in addition to her metal, had two sixty-eight-pounder carronades on the poop..."
From "Memoirs and Correspondence of Admiral Lord de Saumarez, Vol. I" by Sir John Ross.
Bruce
Chris, has the glue been allowed to freeze?
- Desertanimal, mtaylor and Some Idea
3
1 hour ago, Chapman said:
In addition to the shop in Brussels, there is also a Chinese manufacturer called Neverland Hobby
https://www.scalemates.com/de/kits/neverland-hobby-8001-das-u-boot--1510553
This is the company I was thinking of, thanks.
Is the firm NEVERLAND HOBBY a legitimate model manufacturer? They make injection moulded kits with PE and may produce other things as well but my question boils down to whether or not they are on the 'pirate list'.
Regards,
Bruce
Good grief no, keep it going!
Bruce
A bit more ...
Hello Alex,
As wefalk says, seven to ten is common. I found one Spanish example with twelve but who knows if that was a reflection of available materials.
The CAFModel longboat has ten (plus the elevated board above the rear sheets) and he based his design on, if I recall correctly, a monograph by Gérard Delacroix. The image below has the right perspective to allow you to count them.
If I find any scantlings I'll post them but it looks like you have a free hand.
Bruce
HMS Bellerophon 1786 by AON – scale 1:64 – 74-gun 3rd Rate Man of War - Arrogant-Class
Take care of yourselves, we will wait.
Billy Ruffian is looking good.
