Everything posted by Hubac's Historian
What you are seeing on Marc’s model is a scupper for the manger. Because the timber is flush with the wales, in this area, it is not necessary to have a projecting scupper. On the interior, the Manger is like a big slop-sink that helps to shed water from the cables as they are hauled, inboard. The interior surfaces of the manger are lined with, I believe, lead sheet. On my model, I think what you are referring to are timber fills between the middle pair of wales. These are specifically to support the preventer plate links and eye rings. See, again, frolich’s model: Frolich didn’t blacken these timber fills, and their edges are a little hard to see, but they only extend the width of the chanels.
- 109 replies
- Ship of the line
- Heller
I am also quite impressed with how neatly you inlet the hawser piece. I found this a very fiddly thing to do well.
- 109 replies
- Ship of the line
- Heller
Eric, I like your scarf jig - those scribes look very clean. Since you are starting fresh, I will encourage you to pay close attention to the sweeping lines of the anchor lining. With permission I will use two pictures from Marc Yeu’s photo archive to illustrate the point. First is Frolich’s L’Ambiteaux: Next, is Marc’s magnificent scratch-build of Soleil Royal: What I’d like to draw your attention to, specifically, are the places where timber is filled flush with the neighboring wales; only between the pair of lower main wales does the surface run flush all the way up to the stem. As for the hunting port, I personally tend to find the VdVelde drawings to be credible guides for the placement of ports, as so many original drawings show the ghosts of prior port placement, which were erased and re-drawn. In other words, this was an important detail that they were trying to get right. So, yes, I think many French ships carried this hunting port as far forward as possible, so that the in-haul tackles were likely affixed right next to the cable manger, and so that gun recoil was less likely to foul the cable bitts. Once again, you’re off to a great start!
- 109 replies
- Ship of the line
- Heller
I like your barrel hoist, by the way.
- 1,503 replies
- Le Soleil Royal
- Heller
Yeah, I’d say that is quite reasonable.
- 1,503 replies
- Le Soleil Royal
- Heller
Actually, Bill, I would say that is quite reasonable. How do they look on deck? They’re cast metal?
- 1,503 replies
- Le Soleil Royal
- Heller
Prieser makes figures in 1:100 scale, but they have to be heavily modified to look like 17th C. sailors. I thought the old Revell Spanish/English galleon kits came with figures in 1:96. Might be worth seeing if you can locate those on the market somewhere.
- 1,503 replies
- Le Soleil Royal
- Heller
For ease of consideration, Bill, consider the scale of SR to be 1:96, 1/8” to the foot. If the Hermione figures are 7/8”, or taller, they will not seem credible at all.
- 1,503 replies
- Le Soleil Royal
- Heller
Yeah, I have to agree with Ian, here. Straight out of the box, the Heller Victory is a significant undertaking. I have a pressing from the mid-90’s. Plastic quality is high, and the hull does not seem to suffer from the same warping issues as with the Soleil Royal. There are a TON of parts to deal with, though. As others have said, the sky is the limit when it comes to modifying and adding to the kit. Doing a creditable job on this kit definitely requires some advanced skill and even more patience.
I agree you could go either way with this. Simpler may be better, though.
- 131 replies
- Sovereign of the Seas
- Airfix
With your most recent comments in mind, Haiiaphnk, I do not think the French ever designed the ornamental programs of a pair or even a series of ships to follow a single conceptual idea. The ships were named individually, and their names reflected the multiple virtues of Louis XIV, while the capital ships like the Royal Louis and Soleil Royal were given ornamental programs that reflected the hegemony of Louis XIV’s reign. The common threads are virtue and dominance above all other nations. The ornamental programs of each vessel explored numerous stories from antiquity to express those ideas. As I have been reading more recently in Ms Pin’s dissertation, La Symbolique Sur le Vaisseau de Guerre Francaise, individual ornamental programs were not literal representations of the actual influence and might of the monarch, but rather projections of his own grandiose self-conception. Propaganda, in other words, with the intent of cowing the opposition.
Thank you Michael and Dan! I will continue to tinker with the chainplates. Eventually, I will arrive at something acceptable.
- 2,444 replies
- heller
- soleil royal
(and 9 more)
The one example of very close sister ships that comes to mind are La Superb, and L’Orgieullieux. The following is often captioned as La Superb, but it must actually be L’Orgieulliex because La Superb was not present in English waters in 1672 for the Van de Velde’s to draw her. It is said that these two ships were built to the same specs and that they were virtually identical, although the ornamental programs must have differed.
I’ve become somewhat stymied in my chain-making experiments, lately, as one of the tips of my Xuron PE snips snapped off, while cutting soft annealed wire (28 gauge). Maybe I’m using the wrong tool here, but should the tip really snap off after such relatively light use? Is there a better tool in the Xuron range for 1:96 chain making? Anyhow, that’s all on hold until I buy better/more appropriate tools. In the meantime, I just wanted to make some progress doing anything, so I finished detail painting the main deck gun carriages. I appreciate all reasonable advice to correct the implausible/impossible carriage trunnion mounts. After much hemming and hawing, during my phase of no progress, I have decided to let this one go in the interest of keeping things moving onward and upward. I am satisfied enough that I spread the trucks, and I will re-position the barrel trunnions themselves, so that the cascabels don’t overhang the back of the carriage to an unreasonable degree. Good enough for this go-around the May-Pole. I have blacked-out the truck axles and the glue blocks underneath all visible carriages. One other incorrect detail of my model that I would like to better understand the “why for,” is the rake of the channels. I have chosen to back-sweep the forward and aft edges of my channels: This just feels intuitively correct to me. To the contrary, though, all credible monographs show a slight forward-sweep to the fore and aft edges of the channels. What is the logic behind the design?
- 2,444 replies
- heller
- soleil royal
(and 9 more)
You certainly have a loyal audience, but I feel like the broader MSW community is really missing out by not seeing the magical things that you do. You don’t strike me as one for self promotion, Michael, but MSW should have a featured builds page. I’m as guilty of it as anyone because I tend to stay within the late 16th into the 17th Century category, but I am frequently amazed at what I find when I do check-in on the 18th Century. Anyway, I love what you are doing here!
- 131 replies
- Airfix
I will also mention that when I did my lower battery guns in a dark bronze with a ver-de-gris wash, those decorations pop very visibly: Looking through my file pics to find the guns, I saw John Ott’s brilliant Photoshop (or some similar program) adaptation of SR’s sister ship La Reyne into Soleil Royal. This makes me happy every time I see it.
- 109 replies
- Ship of the line
- Heller
Correct you are - breaching ropes through the carriages.
- 109 replies
- Ship of the line
- Heller
You might find that the stock lower battery 36-pounders look more to scale on the upper main deck battery, if you wish to take advantage of the nicely detailed Heller barrels.
- 109 replies
- Ship of the line
- Heller
I agree with what Ian is saying here. Generally, I find that it is better to go a little under scale than over scale - especially when it comes to hugely repetitive elements like the gunport lids and their hardware. It is useful to consider, not just how one lid looks in isolation, but how an entire broadside will look.
- 109 replies
- Ship of the line
- Heller
Hello Late to Soleil! Are you mapping out an SR conversion project of your own?
- 80 replies
- Soleil Royal
- Ship-of-the-line
