Hubac's Historian
Everything posted by Hubac's Historian
  1. Happy New Year, Marc! I'm just re-visiting your build because I've been reading J.C. Lemineur's monographie on the Saint Philippe, and enjoying that very much. What you have achieved with your hull, from the main couple forward and aft, corresponds very well with what Lemineur details so clearly about late 17th C. practice, while also seamlessly incorporating the pre-1673 transom framing. It really is a marvel! I wasn't really understanding, until just recently, that it was the placement of the wing transom above the stern chase ports (pre-1673) that cause this peculiarity of SR1's transom profile. Michel has tried to explain this to me - and other things that, owing to a lack of common ship vocabulary were hard to grasp - but now they are coming into focus. I hope that life, fatherhood and work are being kind to you, and that you will soon be working on your magnificent ship again. All the best, M
  2. Thank you, Dan, for the Rochefort link - lots of excellent models and perspectives, there, and thank you to everyone for looking in, your likes and comments. Heinrich does raise one of the “issues” with my build log - that being that it is lengthy and tangential, and as I write most of this on subway trains - it’s a rambling stream of consciousness on the subject of SR and her times. I do have a tendency to go on (see below). I will never say that I can provide an accurate glimpse of what SR1 looked like at any time in her career - the closest to approach that are the scholars; Michel Saunier, Marc Yeu, and J.C. Lemineur, whose latest monographie on the St. Philippe provides a highly plausible (IMO) starting point for creating a hull form for SR1 (1689). But, really, Michel and Nek0 (Yeu) have already crossed this threshold - paying particular attention to the subtleties of SR1’s pre-1673 transom. The only thing I’m striving for, here, is an impressionistic attempt at historic plausibility. Speaking to Heinrich’s suggestion, though, maybe I can create an image database in a separate topic thread, in the general forum, where a wider cross-section of MSW might see and have some knowledge of these portraits and images that I’m struggling to identify and put into a period context. I will make an attempt at brevity, in my captioning of these images. Maybe call it something like Colbert’s Navy Under Louis XIV.
  3. Welcome, Kevin!
  4. That depends a lot upon what materials you are building with. Is this a kit, or a scratch-build? Wood, plastic or card?
  5. I suppose you could scribe in planking on this flat area, but it really isn’t visible when the model is in a display base. The important thing, I think, would be to raise the load waterline by a solid quarter inch. If you do not cut away the lower hull to make it a waterline model, then you will have to carefully scrape away the moulded waterline, because it will telegraph through whatever paint you use for your “white stuff.” This one simple alteration really improves the appearance of the model. Just look at your hull clipped together; without paint clearly demarcating the stock waterline, the hull form looks pretty good, and sufficiently rounded in the hold. If you decide to experiment with Evergreen wales, you could probably raise the lower two wales another 1/8”, at midships, and then correct the exaggerated forward sheer of the wales. Keep in mind, though, that doing so will require alterations to the head rail arrangememt and the hawsers.
  6. Yes, this surviving ornamentation of the Reale gives a perfect sense for the style and weight of the carved figures, and perhaps even the likelihood that gold leaf was used a little more extensively than might seem reasonable, considering the huge expense.
  7. Well, there isn't any hair left, so no worries, there! Thank you for this link Heinrich. I will check this out, right now, in fact. I'm also going to pack up your spare parts today and ship them out this coming Saturday. This Tanneron model of the Foudroyant/Soleil Royal, no matter it's omissions and sources of inspiration is still the most remarkable example of the ship carvers' art. I've been sanding and scraping, and thinking about adding some additional through bolting to represent the hanging knees that support the deck beams. The St. Philippe monograph is really illuminating when it comes to fleshing out certain details, as per example: a notably wider scupper on the middle deck level, in line with the pumps, for quick draining of water from the bilges. The other revelation is that I need to pad out my construction of the lower stern counter, so that I can properly create a false-gallery ledge upon which the Four Seasons figures can sit, comfortably, and support the main deck stern balcony that wraps to the quarters. So, I'll have to add back a little plastic, there, but it shouldn't be a big deal and it will save me the disappointment of an improbable appearance to my stern counter. This was one of the qualms that J.C. Lemineur raised, concerning the black and white drawing of the quarter galleries that is my avatar. As it is drawn, there is not a proper ledge for these rather large figures to rest upon. Now that I understand this better, I have to agree with him, there. I do not, on the other hand, agree that this detail, along with the incongruities between the QG figure of Africa (sans elephant head dress) and the way the figure appears on the stern drawing, completely discount the credibility of this representation of the quarter galleries. As I have detailed at great length, earlier in this log, there are many corresponding elements between the stern and quarter galleries, with regard to mouldings, banding arrangements, and the shape of the windows at each level. Mr. Lemineur comments on the improbability of the fish-tailed, butterfly winged mermaid figures that flank the quarter gallery, however, I personally believe that this may be Berain's nod of the cap to the earlier styling of the Puget figures that likely graced the first version of the ship; Puget was fond of split-fishtailed figures supporting each layer of the gallery. In this way, I think that Berain may have been attempting to incorporate a sense of continuity into this later development of the ornamental scheme - in other words, that the ship would not be totally unrecognizable from it's earlier appearance. In fact, the filigree banding that borders these color gouache drawings by, I believe, Etienne Compardel (Lemineur cites Pierre Vary as the creator of this color portrait), includes vividly colored representations of these split-tailed figures, amidst the very Berain-styled banding of the filigree border; something new rising from something old. As with most of what I write, here, this is all theoretical and may be completely wrong. I don't believe it is implausible, though. And the reason I cite Compardel, as opposed to Peter Vary, is that it bears many direct similarities to this known Compardel portrait of the Konung Karl. At the time that Berain had taken over the artistic oversight of ornamenting the King's ships, there was an established relationship between Berain and Compardel, as noted by Andrew Peters in his book, Ship Decoration 1630-1780. Not only are there similar issues of proportion and scale that show up in both of these ship portraits, but the particular style of rendering the sea and sky is nearly identical. I leave it to you all to form your own opinions, though.
  8. Okay, Doris - now you’re just messing with us! Really? A perfect card model recreation of your Nissan?! Whenever it is that both of my children have stopped believing in Santa Clause, I will let them know that it is perfectly real to believe in you - the magical maker of things. I don’t know how you do it, or where you find the time, but it is a real treat every single time. Happy New Year to all! - Marc
  9. Hello, Heinrich. Yes, I have also found this book by Winfield and Roberts to be a great help, and the depth of their research lends the work great credibility, IMO. These are the dimensions I will be checking against. I have also lately become acquainted with War Hammer, as my Godson is really into it. I visited their shop in lower Manhattan, recently, and was quite impressed with the array of colors. Of course, there is no shortage of YouTube videos that demonstrate how to layer their paints and use distress washes to pick out details. I will probably re-visit their store for a really light distress wash for experiments in toning down my upper bulwark colors just a little bit. As for the decks, I am leaning toward making them from styrene sheet for several reasons. First, I can easily lay out and scribe in the tapering plank widths, and the plank butts on their beam locations. My earlier paint experiments were quite a success, and I think that one of my samples would make a really good deck treatment. Also, I’m not sure the marriage of a real wooden deck (scribed veneer, or individual plank) wouldn’t seem jarring on what is mostly a painted plastic model. Finally, as I am going to continue scratch-building deck furniture in plastic, for the most part, I prefer to bond plastic to plastic. I am sure cyano glues are perfectly up to the task of wedding wood to plastic, but this is simply a stubborn idea in my head. Sometime this week, I will do a post on the St. Philippe monograph. There are a number of really great illustrations that I had never seen before, including yet another of the Royal Louis/Grand Monarque’s stern; this one is a mixture of good detail, reasonably well scaled, but a little primitive in execution. Anyway, he discusses SR, a bit. I still disagree with him, regarding the quarter galleries and their resonance with the Berain stern, however, he does make a few salient points, there, that I will unpack later. All fascinating stuff, and his reconstruction of the St. Philippe is really superb.
  10. One argument for the lining being flush with all four sides of the lid is that because it is nailed to the outer planking at right angles - perhaps a full height and width lining helps to more completely balance the forces of expansion and contraction, thus allowing for a tighter fit inside the opening. I will say that the Bellona model appears to be a very deliberate and detailed representation of this detail.
  11. With the exception of a tallow/lead white for the small portion that will be visible below the waterline, I have found all of the other colors I needed for the upper bulwarks. Although it will be used pretty sparingly, this Holbein ultra-marine was just the right shade that I was looking for. It will be a nice counterpoint to the Cerulean blue - which is probably too vivid a color for this time period, but I prefer it for artisitic reasons. Utrecht is the manufacturer of this irridescent gold. The ornaments should really pop against the yellow ocher of the frieze lattice. My beakhead bulkhead, the stern and the area between the main deck guns will be done in this red ocher color, with the acanthus escutcheons picked out in yellow ocher, ultramarine blue and the fronds and Royal monogram in gold. I think that the quarter galleries might also feature this red ocher color, but I have not figured out which areas that might look good on, as the QGs cross over the blues of the upper bulwarks. Perhaps the amortisement will be mostly Cerulean blue and red ochre from the main top wale down. Or, maybe the QGs will be all red or all blue. The answer will become more clear as I go. My SR will be a vivid riot of color above the top wale. It has been a pleasant holiday season, and I hope to soon get back to the scraping/paint prep of the lower hull. My St. Philippe monograph arrived while I was away, and though I have only skimmed through it - it appears well worth the investment. I will be very busy in the new year.
  12. I have been following this debate from the sidelines, and not commenting until now. For all practical purposes, and thinking like a tradesman, it would seem to make the most sense to stop the planking a few inches short of the frame siding, along the sides of the ports, and to cut the plank opening around the sills. Although ship carpenters of yore would have been fantastically adept with their tools, chopping additional mortises into the frames and sills would be remarkably labor intensive, with the disadvantage of weakening, to some small degree, the underlying frames. Also, from a practical perspective, it would seem to create a better gasket, if the lid linings were stepped back around all four sides of the lid, so that they fit into the opening. While it is good and usefull to look at surviving examples, like Victory, as Druxey points out, the history of repairs - even on an important ship - isn’t always reliable; sometimes modern carpenters do strange rot-prone things like filling the lower rabbet with short stock - for whatever reason, I can not tell you. Perhaps a better surviving example, albeit from a much earlier time, is the Vasa. She has not been altered, but re-assembled, and she exhibits stepped lid linings and rabbeted ports. It just seems to me that a shipyard, regardless of the epoch, would work as efficiently as possible. And there are sound mechanical advantages to fitting the port lids in this way. Certain details on contemporary models, on the other hand, are often simplified for the sake of making models more quickly.
  13. It is interesting that, on this model of the SP, the sheer of the wales, near the quarter galleries, rises sharply enough that the aft three, or so, gunports cut completely through the wales - especially at the main deck level. On the Heller/Tanneron models, the aft most ports cut into, but not through the top wale. You could sand away the wales completely, and increase the degree of sheer of the wales, to match this, but unless you also adjust the moulded sheer strake just above the main deck ports, you will see an unflattering narrowing of the distance between the top wale and this sheer strake. I’d have to check, but I believe the rabbeted bottom edge of the aft upper bulwark runs paralell to this moulded sheer strake. That being said, the moulded sheer strakes/drift rails above this first one, increase in sheer as they extend aft, so that the planks in-between are wider aft than they are in the waist. My frieze obscures this fact of the kit architecture, and it would seem that a conversion to the SP would also require scraping away the SR ornaments and drift rails to make room for the diamond-hatch frieze of fleur-de-lis. If this (the widening aft) happens to also be true for the space between the rabbeted bottom edge and the first moulded sheer strake, then increasing the sheer of the top two wales so that they run parallel to that first moulded sheer strake would be an improvement to the authenticity of the model, in my opinion.
  14. Well, I’m not sure what you are asking, exactly: The Heller kit is in the scale of 1:100, which works out pretty neatly to 1/8” = 1’. If you are asking what scale this would represent for the Saint Philippe, then one would have to take the actual length and breadth of the Saint Philippe and convert that to a common unit (I know inches and feet, so I would use inches), and divide that by the length of the kit main deck, between stem and sternpost, in inches. That would give you a reasonable idea of scale. Now, as it relates to my conversion of the Heller kit into her 1689 appearance, I have so far used 1:100 as a guide for scaling my new, scratch-built parts, but I won’t really have much of an idea what scale my broader and longer model is (relative to the known dimensions of SR1), until after I have mounted my hull halves on their flat bottom and built up the transom to the main deck level. Once I get there, I will take measurements between perpendiculars, just for fun, but the answer hardly matters for this model, as it is an impressionistic effort, and not a wholly realistic one. I just want to see whether my greater breadth and length bring the model closer to scale with the actual ship. For my purposes, though, 1:100 is a good enough guide.
  15. I think you can definitely make a very compelling model of the St. Philippe, without going to modification extremes. It just requires acceptance of certain hard realities of the kit. Earlier, in my modification of the upper bulwarks, it was pointed out to me that the main deck port frames appeared to run perpendicular to the top wale, as opposed to parallel with the underlying (in this case, imaginary) framing. Well, since I had the extra set of bulwarks, I convinced myself that it was worthwhile to sand away the aft 7 or 8 port frames and replace them in the correct orientation to the top wale. It’s a small detail, but I am glad I did it because the upgrade lends just a little more credibility to a kit that is full of silly errors. But, then, the actual size of these main deck ports is exaggerated - they should be smaller, as displayed to good effect on the St. Philippe model. I accept this design defect though, because on the balance - the frames are nicely moulded and my ornamental port enhancements worked out well enough; although, if they were the correct size, in the first place, I would not have had to let the very tops into my sheer strake, in places. I was thinking, Heinrich, that I could pay the favor forward and send you the forward halves of the scrap hulls that I’ve been cutting from and experimenting with. The starboard side has a pretty severe heat warp in it, along the upper wale, which is why Popeye2Sea, had to start over, but the port side is good. Perhaps you could use these to experiment with cutting down of wales and replacing with Evergreen to see whether you want to go that route. The upper bulwark pieces still have enough frames attached that you could extract them, if you wanted to correct the port frame issue. I just want to save one piece to experiment with upper bulwark paint protocols. I will say, though, that I felt much more free to cut into my good hull because I could do a dry run/dress rehearsal on the donated kit parts. This really gave me the confidence that the broadening and lengthening of my hull was probably going to work out. Private message me with your address, if you are interested.
  16. I might add, also, that doing all of that would necessitate a complete scratch-build ot the cutwater and supporting knees, because you would be relocating the hawsers, as well.
  17. I suppose you could cut away the upper most wale and spacer plank above the next wale, which would then become your new top wale. Then, you could sand away every wale beneath that; shift the lower and middle deck ports down, in the vertical plane, to align with the new, corrected deck heights. Then, you could add back on the wales, correcting their sheer - particularly at the bow. But the cutting down and filling in of the gun port tops would be quite a lot of work. Huge amount of work. You would also need to cut back in a rebate for the fitting of the upper bulwarks. It’s all doable, but it is labor intensive and probably not worth it. Then, as you mention, there’s the question of to what degree cutting the top wale down cuts into the slope of the tumblehome. In my view, it’s just not worth it.
  18. Heinrich, you mentioned earlier that a Frenchman was building a model of La Reyne, on another forum. Do you have a link to that build page? Cedric, who is Belgian, began his build-log on LaRoyal Modelism, where it still exists. I would be interested to see, though, if someone else were building La Reyne.
  19. The thing about the Heller kit that bugs me more and more - although I have zero inclination to correct it, at this point - is the height between gun decks. Heller’s model allows for a very generous 7’, or so, of headroom; with those allowances, even Kristaps Porzingis could man the guns. This is something Cedric pointed out a long time ago, and as time has gone on, it is more annoying to me, but I accept it for what it is. In this over/under comparison with the St Philippe, you can really see the difference, as compared with what should be.
  20. That’s quite a build, there, Vic - although it would seem your rowers received some pretty rough treatment, in the painting process; it’s a wonder they can sit at all after that! I just went through the link to ModernNight’s Flikr page on French ships. There are some real VDV gems in there, for sure. Thanks, again, to Kirill for providing the link! Merry Christmas!
  21. Heinrich, thank you so much for your generous compliments! Your consideration of the Heller kit is an interesting one. There is a modeler here, Cedric, who is in the process of converting the Heller kit into La Reine. He is quite busy, in life, and has not been visible for a while, but his research is quite fascinating, and highlights many of the practical difficulties of converting a model of a particular ship - Soleil Royal in 1:100 scale - to her kissing cousin - La Reine, which was actually slightly smaller in full size, and consequently, the scale of the model must reflect that. Very tricky! Cedric has made an excellent start of it, and his build-log can be found here under his screen name, CedricL. I highly recommend checking it out. That being said, I do not think the Heller kit is suitable to convert to the Monarque/Royal Louis. Le Saint Philippe, on the other hand, is a highly plausible alternative, in my opinion. There is very much in the Heller kit architecture to recommend this approach. To answer your question about the lower hull, though, I am really captivated by this idea of creating a super realistic diorama, with my ship in a sea - at port of Brest, on the Penfeld. To me, the lower hull of the Heller kit is really problematic, and I just prefer to cut it away altogether.
  22. Welcome aboard, Jose! Thank you, I’m so glad that the project interests you. Well, the St Philippe monograph is my Christmas present, but it has been in transit for almost a month now. Perhaps it is sailing over here on Le Saint Philippe II 😉 For clarification, we had an “early” Christmas on Saturday, at home in New York because we flew down to Florida to be with family for the actual holiday. That’s why I know my big present hadn’t arrived. In the meantime, though, I’ve been browsing photologs from the Rochefort conference and this page has a ton of really good pics of the two models made for the monograph: http://www.modellmarine.de/index.php?option=com_imagebrowser&view=gallery&folder=rochefort18-3&Itemid=55 Thanks to Kirill for providing this link! One model is fully rigged, and the other is in the admiralty style. Right away, I can see how helpful this new resource will be for correctly outfitting the decks and resolving certain issues I am bound to encounter in the poop deck/poop royal deck from lowering the sheer. But the greatest advantage, for the model I’m building now, is the masting and rigging. I think it is reasonable to rig SR of 1689 to a 1693 scheme. So, anyway, this is a slow-moving monster, but things are starting to happen.
