drobinson02199
Everything posted by drobinson02199
  1. Dave: It is large, but I've seen some large ship models (like the Mantua Le Superbe and others) that are as large. I do have a large shelf, or I may mount it over the TV in my office. It comes with the smaller number of boats. Regards, David
  2. The basic hull framework is done, and it goes very smoothly. The laser cuts on the plywood are really well done and everything fit together without sanding or forcing. It's 42 1/4 inches long. The first two pics show the overall frame structure. The third one is the best of my attempts to show the adjusted bow bulkheads along with the line of the overall ship. When I sight down the hull, I think frame 5 has a bulge that's too far out -- and that may be because of the issue of printing/sizing the templates -- but it will be easy to adjust when I fair the frames for planking. The darker laminate makes it easier to compare the original line of the bow with the new line, and I like the new line much better. Regards, David
  3. Yes, and since the new bulkhead templates were developed by the Titanic Research and Modeling Association, I felt they were credible and went with them. For a kit this significant, it would not be too hard for Amati to produce a laser cut of the new bulkheads (only 6) and ship it out to their main distributors (like Ages of Sail) as a free mod to the kit. I would have struggled with this if lgfrench had not taken the time to lead me to the mod. Regards, David
  4. Great point, Chris, and thanks to Mr. Pucko for the follow-up. I guess I'll find out. Building this kit will be an adventure, and let's just hope I don't hit an iceberg! 😵 Regards, David
  5. To Greg and Popeye's comments: when I started this approach I thought I'd be in for a very long slog, as you both have expected. But as it turns out, using my steamer and doing two at a time (so the glue for one strip dries on one bulkhead while working on the other) makes the work go fairly quickly. Here's a pic of bulkheads 6 and 7. Now I just have 3, 4 and 5, which have decreasing amounts of fill going from 5 to 3, so those should go fairly fast as well. As this will end up, to my surprise it's no more time than I'd have spent sourcing 4mm ply, buying the saw I don't have, and then shaping the pieces with all of the cutouts. Regards, David
  6. Don: Thanks. I think I'll do that just to be safe. But they feel pretty strong. They are walnut (hardwood), and each layer is glued with CA gel, so the whole thing feels pretty solid. But I'd hate to discover the opposite during fairing, so the wood support is a great idea. Regards, David
  7. I've now had a chance to look at and deal with the bow bulkheads. First off, I want to repeat kudos, high fives and thanks to lgfrench, who forwarded me the post on this issue, and also the template showing how the bulkheads need to be adjusted. I started with the template. When printed the diagrams aren't to scale, so I ran it through Photoshop to isolate an individual bulkhead template (in this case, bulkhead #8 which has been my test case). I then printed that at different sizes until I got one where the "kit bulkhead" outline in white matched the actual bulkhead in hand. (see picture below). I don't have a jigsaw -- not even a coping saw -- and I don't have any spare 4mm plywood, but what I do have is a lot of leftover wood strip from previous models -- including a supply of 4mm wide walnut strip. So I decided to take the approach of laminating the strips onto the bulkhead and then each other, and the rough result of that is on the second picture. The third picture shows what it looks like when sanded down to match the red outline on the template. So that's one bulkhead -- and once I started working with my steamer and came up the learning curve things moved along more quickly. So now 5 more to go. Regards, David
  8. lgfrench: Thanks very much for the bulkhead info. I will look carefully and get back to you when I get there. Has anyone looked at whether the solution is to do more fairing of the previous bulkheads? Regards, David
  9. Don -- On the box it says 107cm -- about 42 inches. Regards, David
  10. Well I'm back from vacation, and it's time to dig into the Titanic, which I've had in my sights since I started modeling a couple of years ago. Here's the "What's In the Box" post: Manual with picture books plus lots of plan sheets A large wall poster of the entire model The stuff: plywood laser cut sheets, parts, wood strip, etc. Just on the surface, this looks like it's going to be a different kind of build from the Amati ships or other boats I've built. Because there isn't a complete log that I can find, I'll try to post frequently as I go. Regards, David
  11. Happy (early) birthday, Chris! She looks great. Regards, David
  12. FLY IS COMPLETED. I finished the H.M.S. Fly today -- competed pics are in the Completed Kits Gallery. Just a couple of samples here. I wanted to see what the lifeboat from the upgrade would look like, so I built it and liked it, so installed it on the ship. I made some mods to it, including using real wood planks down the side at the gunwales, vs. paint. A couple of kit build notes from my most recent work: I added some fine thread braces to the stays the crow's feet are attached to, to keep the crow's feet tight. Important as the stays are pulled up by the rigging and need some counter-balance. I ran out of 3mm and 5mm blocks, and 3mm deadeyes. Fortunately, I had leftovers (plenty) from the Amati Revenge kit, so I was OK, but a caution to other builders. I didn't lose more than 2-3 of each on the floor. Now a break from kit building while my wife and I go on a Greek Islands cruise. When I return in late September, I'm going to tackle the Amati Titanic, and I'll create a detailed build log for that as I don't see much on this site. Regards, and Happy Labor Day to the Americans, David
  13. The yard lifts are now up, so from here on to the final stage of rigging, then mounting & done. Regards, David
  14. Looks wonderful, Chris. The quality of your work is astonishing. Regards, David
  15. Chris: Thanks very much. Yes, I do have the next build planned. I'm going to do the Amati Titanic, which I have on the shelf waiting. Regards, David
  16. All the stays are now up. Some run close to the mast and shrouds so you have to look for them. Regards, David
  17. She is really a work of art. The cannons look beautiful on her. Regards, David
  18. Foremast crow's foot rigging is up. As I was snipping the last loose piece of crow's foot, I managed to commit the ultimate rigging sin and snip the crow's foot too. 😫 All of the "feet" are one long continuous line. So I spliced the last lead and saved it. You can see the splice if you zoom in on the second picture and look at the leftmost "foot". But it's hard to see with the naked eye, so all's well that ends well. Regards, David
  19. All shrouds are now up. 😂 I think I've been seeing ratlines in my sleep. Now on to other rigging, in between some business trips coming up this week and next. Regards, David
  20. I haven't posted in a while, because I have been traveling and also busy with some business. But this week I was able to do the mizzen lower shrouds and finish off the lower shrouds, futtock shrouds and ratlines, so here's a picture of that. Regards, David
