flying_dutchman2
Posts posted by flying_dutchman2
  1. Working on the bow area. Building it up and figuring out how to anchor the bowsprite in that area.
    For me, this ship is difficult to built. It is the ultimate challenge for me and I will finish her. As I said before maybe I should have built something easier before doing the fluit.
    Anyway, the steps I follow in my head from keel to flags is at times a bit overwhelming. Like the Dutch shipwright who didn't write anything down while building a ship, it was all in his head. I am doing something similar, I am not taking any notes like some modelers do.
    Marcus
  2. CBX 1050 and a GSX 1150 wow, I remember those very well.
    In college (no money for a car) started with a 1981 Honda XL250S, moved up to a 1983 XL600 and that was a kickstart. Had that till 1988 when I finished grad school.
    Went to work in Saudi Arabia and had several Huskies. No spark arrestor, short exhaust and go all out on sand flats with others. Always wore a helmet.
    Marcus
  3. Too many guns on that drawing. Someone had a dream and put it on paper. The average amount of sailors on a Fluit was around 20 and usually they all came from the same town. Narrow decks were for less toll.
    Some fluits had 6 to 8 canons, most had only a few. They sailed in convoys and were protected by war ships. I would not place those canons where they are now. There must be other places on the decks where you can put them without interference from the grate.
    Marcus
  4. Observation
    My Zeehaen needs 4 - 20 cm planks to cover one strake from stem to stern.
    If you plank with straight butts, top ruler, then 4 planks of 20cm long would cover 1 strake.
    If you plank with with Dutch version of butts, bottom ruler, then 4 planks will not cover 1 strake. You need more.
    That would be 4 - 1/2 planks.
    If a plank is 20 cm long and your Dutch butts are 2.5 cm each end, the full width of the plank is less then 20 cm long
    Now if the plank is 20 cm long and the 2 butts are 2.5 cm long then 2 x 2.5 + 20 = 25 cm long plank. This is wrong.
    Below I made various templates to form the butts. Top right a rectangular piece of brass of 2.5 cm long and two 90 degree edges on each end. Will need to sharpen one long edge so it is easier to cut the wood.
    Top left razor blade cut from 4 cm to 2.5 cm. On the hull I would overlap 2 pieces and make the cut so the butts would fit well. Bottom ruler just shows how the butts fit.
    Non of my models have all the same looking butts. I tried several kinds. On the fluit I will do all Dutch versions of butts
    Is there another word for the butts?
    Marcus
  5. 1 hour ago, Roger Pellett said:
    Somewhere I read that one of the Dutch Shipyards’ competitive advantages was the early availability of wind powered sawmills to produce sawn planks vs sawing them by hand over a saw pit.  Their lumber was also imported from the Rhine and the Baltic.  I would, therefore, not think that these vessels were built from inferior lumber.
    Roger
    Roger,
    Wind powered sawmills was a Dutch invention and you are correct about the wood.
    The Dutch had special fluits called "Houthaalders" which means wood haulers and they went to the Baltic to get wood. The taffrail could be opened and wood would be slipped in.
    Marcus
  6. Ab,
    Been reading about Dutch measurements on Wikipedia https://en.m.wikipedia.org/wiki/Dutch_units_of_measurement#Voet
    and have two questions.
    In post #186 you said and I quote "He specifies the planking needed as 4 1/2 for every strake for this length. That means that every plank is about 27 feet, which is roughly 7,50 m.
    1.     4 1/2 what?
    2.     What formula did you use to get 7,50 meter from 27 feet?
    Thank you
    Marcus
  7. Gentlemen,
    Ammonia is a Big NO-NO in making planks bendable.
    Technical background.
    Wood is made up of cells that have lignin, which is a complex organic polymer deposited in the cell walls of many plants, making them rigid and woody.
    Ammonia reacts with the lignin by making the cell walls mushy. It destroys the cell walls of the wood and over time warps the model. Your plank falls apart. Just think of what happens to all the planks of your model.
    Marcus
  8. Robert,
    Here is a link https://www.modelships.de/Fluyt-Zeehaen/Fluyt-Zeehaen.htm
    from a site of models made by professionals. The link shows the Zeehaen (which I am building) .
    If you have any questions, I might be able to answer those.
    On a Dutch site modelbouwforum.nl there are several modelers that have built fluits. Look under the thread called
    "Bouwverslagen historische schepen"
    Marcus
  9. Ab,
    I will look in Witsen's book and thank you for the suggested numbers.
    I am a bit embarrassed by the next question (and I should not be),
    What is the length of my planks in centimeters or inches for my model if the scale is 1:37.5?
    Do I divide 37.5 into something?
    Thanks
    Marcus
    Mark,
    Thank you as well for the measurements.
    Marcus
  10. 26 minutes ago, Pingu57 said:
    Marcus, very nice work sofar, but if you are going to make this buts in every plank, then i think you know what to do in your spare time.😇🙂
    Kind regards  Peter.
    ps. forgive me if i made any spelling or grammatical errors, i am better in Dutch
    Peter,
    Your English is fine not to worry.
    I am doing the butts on every plank. I practiced making these butts while building the Utrecht and the Boyer.
    Marcus
  11. The following question has probably been asked numerous times.
    If my ship is in X scale what is the max legth and width of my hull and deck planks?
    I have looked in numerous books i possess, went to several ship model sites and read several articles. There is not a clear cut answer or math formula available.
    In "Planking techniques for model ship builders" by "Donald Dressel" on pages 70 to 81 there is a discussion about some basic information.
    Example.
    On an 1/8th inch scale model planks should not exceed 3 inches.
    On a 1/4 inch scale model the planks are 6 inches in length.
    Also in general planks were between 4.6 mtr to 6.1 mtr (15' to 20') in real life.
    So if my model is in a scale of 1 cm - 37.5 cm, what will the length of my planks be for the model?
    Thank you in advance.
    Marcus
  12. Did what Ab mentioned in his post #174.
    First I dry fitted the taffrail to the batten that is screwed to the post.
    901545400_145FluitZeehaendry-fittaffrail.thumb.jpg.2deb18cb47d8c5743c437724bc9c6d21.jpg
    729189266_147FluitZeehaentaffrailscaledin.thumb.jpg.4fb0d43339769d4dd70d8f6260b6d467.jpg
    Glued the taffrail in place.
    1386448894_148FluitZeehaentaffrailglued.thumb.jpg.884f7d09d8a94642466259cabe7d608a.jpg
    After glue is dry remove the batten holding the taffrail and the excess of the planks sticking out backwards.
    Marcus
