flying_dutchman2
Posts posted by flying_dutchman2
  1. When the weather is warm I don't work on the boat, I work outside in the garden. We did have some rain in between so I worked a bit on the Fluit.
    I used tracing paper and copied the curvature of the wales from the plan and transferred the lines to the hull.
    1606568311_215FluitZeehaencorrectwalew-templ.thumb.jpg.a24f5a38e28d10df9066e2b25047627a.jpg
    Compared to what I initially installed as the lower wale, the one on the plan follows the curve of the Fluit better. My original wale has a too steep of a curve towards the center of the hull.
    Then attached 2 long planks as a temporary lowere wale.
    1738282529_217FluitZeehaencorrectwaleposition.thumb.jpg.32300bd9a8b56d8d984a4173e2788f13.jpg
    It takes about 8 strakes from the keel to the bilge and 6 strakes from the bilge to the lower wale.
    Marcus
  2. I could not wait till Monday so I did a strake next to the keel. Started with a straight butt beginning at the lowest wale and continued with the Dutch scarphs. Used 4 pieces of 20cm long cherry planks and a little piece to finish the strake.
    Creating joints when the wood is wet, let the planks completely dry and then glue them together on the hull works well.
    Marcus
  3. 11 hours ago, YankeeD said:
    0,4mm and it is soft copper, so no need for annealing in fire or so. bought at a Dutch internet modelshop
    What is the name of the Dutch internet modelshop? So I can see the material that you got and compare it to material that I can get here.
    Thanks,
    Marcus
  4. 13 hours ago, Ab Hoving said:
    For the time being you get the benefit of the doubt. If this really works it would be a fantastic system. But how to deal with ending planks in the bow and extra planks in the stern? Like here:
    You really got my attention, Marcus.
    Ab,
    I would not use these joints at the stems of the bow and stern. Similar to the picture if that ship in your post. Monday I will do a practice strake and post it so you can see.
    Marcus
  5. 2 hours ago, Jean-Pierre said:
    Marcus,
    you are a honest modeller but you should learn to cheat a little:  in my opinion it is much easier to use full length planks whenever possible, and afterwards, to indent the joints.
    Jean-Pierre
    Jean-Pierre,
    I used full length planks on my Boyer and indented them at certain lengths. This time I want to try to use 20cm lengths and fit the scaphs as I go along.
    2 hours ago, YankeeD said:
    Marcus, when doing the planking and scarphs on my ship I found that each scarph-joint was different due to the bending etc of the planks.
    Maybe that is also something that Ab means by his comments?
    I also had a mould but needed to sand each scarph afterwards for a nice, flush fitting.
    Hans,
    I expect the scarph joints to be different while following the curvature of the ship.
    Marcus
  6. Thank you for all the likes.
    Preparing the second layer of cherry planking. Most of the planks will be 20 cm long with a Dutch scarph joint on each side. There will also be smaller lengths.
    Put the planks in some water as they will cut better without splitting. Once the scarphs are cut the planks will be dried.
    1267190856_210FluitZeehaenDutchscarphjoints.thumb.jpg.420f0716b02fbbe690e5f5be213ddb2b.jpg
    Top plank is to show what the scarphs look like when cut.
    Middle plank is to show when the scarphs are together.
    Bottom plank being cut to make a scarph.
    603207770_211FluitZeehaenDutchscarphjoints.thumb.jpg.675924751d7aa6a617c5b78e796d15e3.jpg
    Close up from a scarph being created.
    971535795_212FluitZeehaenDutchscarphjoint.thumb.jpg.f59c72661e2bcea76f125efe300b0123.jpg
    I will be creating joints on about 80 planks.  Not all joints will be created now, some will be made when I plank the ship.
    Marcus
  7. Thank you for all the likes and Patrick, thank you for the compliment.
    Finishing up on the location of where the bowsprite goes into its holder and the little deck located at the tip of the stem.
    546199460_201FluitZeehaenbowspriteholder.thumb.jpg.fb75c16946d14f0d2f96cf8071014c84.jpg
    540213183_202FluitZeehaenbowspritedeck.thumb.jpg.aad89104becef31285be92cddd46f05c.jpg
    Started working on the bowsprite panel. Cut a piece of veneer by 0.5mm wider than the actual location of the panel so it is both a tight fit and slightly bowed or curved. Started paneling the veneer with 5mm wide cherry strips.
    1145961899_203FluitZeehaenbowspritepanel.thumb.jpg.462702cb7693a1f0be674557573edb6e.jpg
    298150807_204FluitZeehaenbowspritepanel.thumb.jpg.57e244dcfc9b993eb46b092496a4f57a.jpg
    663892233_205FluitZeehaenbowspritepanel.thumb.jpg.44047d5f9e08c1f8cff8e42b73b0dce4.jpg
    511564497_206FluitZeehaenbowspriteholderadj_ht.thumb.jpg.4ac59d52508c6225a7058330a086a2f2.jpg
    I still need to raise the wall from hull by 4mm. So then it is even with the other side.
    2000262387_207FluitZeehaenbowspritepanel.thumb.jpg.9edef22cddb79fef7d1777279134ca1a.jpg
    Bowsprite panel can be removed for easy adding 2 catheads squares, 1 gunprt and 3 steps.
    Once the glue dried the paneling was marked for the catheads and gunport.
    176507196_208FluitZeehaenbowspritepanel.thumb.jpg.e86af368e34b2aa8e6c5e8b2684e9d9f.jpg
    1033973747_209FluitZeehaenlocationgunportdavits.thumb.jpg.2c4e3bdd55f94cc22740ba47c820b0ee.jpg
    Tomorrow the 2 catheads squares will be removed.
    Marcus
  8. Worked on the bow most of the day. Figuring and creating a bowsprite holder.
    1317717756_195FluitZeehaenstrengthenbowarea.thumb.jpg.2d4b6970a6e54ce5d7f825e9016e73e4.jpg
    Strengthening the deck.
    Glued deck in place.
    Used card to make a template of where the bowsprite goes.
    12039987_198FluitZeehaentemp.andbowsprite.thumb.jpg.46a01ce6dbc763afbda3afa4be565956.jpg
    195303836_199FluitZeehaenbowspritepositioning.thumb.jpg.524d703d7f68514b7b1c15b7500a8647.jpg
    With a hand drill, drilled a hole through the bowsprite, deck and part of the wood. The drill bit kept it all in place while i could draw the lines for the holder.
    The area where the bowsprite goes into the ship, is there a name for that area?
    1037209117_200FluitZeehaenbowspritehousing.thumb.jpg.5b2632c8b3dee18397d08eec54bd6a68.jpg
    Bowsprite holder.
    225396460_201FluitZeehaendryfitplanking.thumb.jpg.7035d1019541ee54bf429d6b687f6ec5.jpg
    968099975_202FluitZeehaendryfitbowspriteandplanks.thumb.jpg.1b719fa7025dea8b371fb44017d550b2.jpg
    Dry fit planking and bowsprite.
    Once i have planked that area and made a hole in it, I can slide the bowsprite with some glue into the holder.
    Marcus
