flying_dutchman2
Everything posted by flying_dutchman2
  1. Great review, Chris! I got it a couple of weeks ago and it is another excellent book from Ab and Emiel Hoving. This book will give me the courage to build a ship in card. Marrc
  2. Hi Chris, Thanks for the link. I am going to check some Dutch sites (I speak it fluently) and plug in the weight of paper/card numbers mentioned in Ab's new book. Marcus Thanks Phil, for the information. Marcus
  3. Hi Chris, I am going to try my hand at scratch building paper models. Yesterday I received Ab Hoving's book "Dutch 17th Century Ship Models in Paper", from Seawatch Books. I will start with a small Dutch merchant ship. In his book, Ab discusses the types of weight of the paper but it is the Dutch kind he uses. Can't seem to find a conversion table (European to US paper weight). What do you recommend I use? Abe mentions 0.5 mm thick, 1mm thick and 2mm thick. Thanks in advance, Marcus
  4. Every Fluit you have built is always beautifully executed. I always learn something looking at your Fluits. I use this knowledge on my own fluit to make sure the Zeehaen is correct. Marcus
  5. Ab, Beautiful pictures, so realistic. Emiel does an excellent job with Photoshop. Do you have higher resolutions of all your pictures, especially the ones in your book of 17th Century Dutch Merchant ships? I would be interested in the Fluit pictures. Thanks, Marc
  6. Ab, Glad you are feeling better. Looking forward to the Photoshop composition. Marcus
  7. Jules, I second that from @druxey, is there a thesis or dissertation on the above information? If so, I would love to read it. I would also like to see the biography list of all the references you are using as you have some interesting articles that I have not heard of before. Thanks, Marcus
  8. This is a fascinating topic and I have been reading this thoroughly. It also gives me a better understanding of it all (Thank you Jules). I use Witsen's manuscript and Hoving's book which is an interpretation of Witsen's manuscript plus several other books to attempt to either built another Fluit (First I need to finish the Zeehaen), or the war yacht, the Heemskerck. Marcus
  9. Hallo Jues, The following link are from two Dutch model builders that are building models "shell first". They are both very interesting threads to follow. Winter's Hollandse tweedekker 1/75 POF bouw door Stephan Kertész | ModelbouwForum.nl Marcus
  10. Thanks for posting. It is amazing how this was done and the work that went into this. I like how all the figures were swimming a backstroke when the ship went down. Marcus
  11. Same here. I was just in the Netherlands but due to time constraint it wasn't possible to see it. Marcus
  12. WOW, Beautiful. Clean Lines. Well Done. Marcus
  13. I second that "and" I will think about your questions and come up with something that may answer or not . Marcus
  14. @mangulator63 "I'm just curious, does anyone still sit at a drafting board and design and draw anymore?" Yes, I do. I still have my drafting table and Rotring pens (from 1978 when I studied landscape Architecture at the Horticulture College in the Netherlands) and still use them. My present built went from 1:75 to 1:37.5. I have a fast pc with TurboCAD installed on it. But firing that up and scanning in the plans, blowing that up to twice the size, printing them all, and then taping that all together takes much longer then cutting a piece of velum from a 5 ft wide 100 ft long roll. Measure by hand the dimensions on the original plans and transcribe them on the 1:37.5. Marc
  15. After reading with much interest, this has been very educational. Philemon1948 "Is this true? Were drawings not used before they started building a ship in the seventeenth century?" The Dutch were well known for not putting anything on paper. The master shipwright had it all in his head and they taught the younger shipwright and he taught it to the next on and so on. Nothing on paper so when you read through books lets say the book "17th Century Dutch Merchant Ships by Ab Hoving and Cor Emke" , drawings/plans are from paintings, edgings, maritime archeological excavations and contracts from Witsen and other authors. Nothing like "we got plans from this and that. Unlike other Western European nations that put everything on paper and some of this has survived to this day. This makes it more difficult for the present model ship builder to built a model because it never is exact. Reading through these 2 books I have mastered the art of reading and understanding contracts. It did take several years and help from Ab Hoving. – A. Hoving, A. Lemmers, In tekening gebracht. De achttiende-eeuwse scheepsbouwers en hun ontwerpmetoden, 2001, – A. Hoving, Nicolaes Witsen and Shipbuilding in the Dutch Golden Age, 2012. I figured if I master understanding contracts I can built any Dutch Ship. Philemon1948 "The flute and the pinas represent two different ship types although they tend to have many features in common". On the site of De VOCsite : Scheepstypen van de VOC it discusses a "Hekboot", which is the best of both worlds. The bottom part of the ship is a Fluit and the top part is a Pinas. Dutch quote "Het is een soort mengvorm met als onderschip de kenmerken van een fluit en de bovenbouw van een pinas". Just my 2 cents. Marcus
  16. I have the book and it is a great addition to my library. It has helped me with building my Dutch ships. My interest in building Dutch ships is the method and technique the Dutch used. Ab Hoving has written a good book about this and he has several articles on this as well. Marcus
  17. As a frugal Dutchman, I have been making them for the last couple of years (I make almost everything myself, about 95%). I take a round dowel, clamp it, on a drill press put in 3 holes in a triangle. Use my crude home made lathe and put the dowel in the chuck from the drill and use an abrassive cord to make the groove. Cut off the deadeye a bit wider and sand both sides a bit round. As someone already said, if you only need a few, you can purchase them from any online store. Marcus
  18. Wow, the transom looks awesome. The details alone are amazing. Just imagine you had to carve all that by hand. I am glad that the transoms of so Dutch merchant ships are so much simpler. The transom on my fluit is in 2 parts and was easy to carve. Marcus
  19. I purchase most of my K&S strips of brass and copper which are wider than 1/2" or get the 4" wide sheets. They are always in stock somewhere and reasonably priced. When I just need one or two thin and narrow strip of brass I dont use the tablesaw. Instead I cut it with a #2 Xacto blade. This is what I do. I get a sheet which has the thickness I need for the project. Then I measure the width I need and do that several times just to make sure. I use a pencil and draw a line so I know the width. I clamp a metal ruler where the edge of the ruler is on the pencil line. (I clamp everything to the edge of the table). I insert a new #2 Xacto blade in the holder, and press on the blade and slowly cut the metal from left to right and right to left. This process is slow going but it works and the thin strip does not curl. Marcus
  20. Check the following sites. It is where I get narrow brass strips. I go to K&S Metal site and check the SKU number of what i need. Than you can either do a Google search with that number and manufacturer. Example: "Flat Bars Brass 2Pcs 1/64 x 3/32, sku 815021" Or go to the below sites and compare prices. hobbylinc.com onlinemetals.com zoro.com micromark.com Marcus
  21. I've read some books on Shackleton and when I read about the discovery of the Endurance I thought "Cool" what a find. Marcus
  22. I agree with @popeye the sailor on this, too expensive for my budget. Marcus
