Keith Black
Everything posted by Keith Black
  1. Thank you to everyone for the likes. Thank you, Dan and Keith. When I picked up the wood from Dan I shared a vision that's a long term project. With a limited amount of time (a few more years, hopefully) I don't see duplicating pile drivers unless, maybe, once the main project is completed and I still have time I might consider building a skid driver as it would fit in with the overall scheme. Once this build is completed I'll share my vision with everyone. I added a flue damper, whistle, and pressure gauge. The figure next to the boiler shows how large the boiler actually is to scale while the US penny shows how small this is in real life. I think the cylinder is too large but that ship has sailed, it is what it is. I have the other components pretty mostly done and should have the engine completed by Sunday. Yesterday, I was sorting through my metal bits collected over the years and finding those bits that would work on the engine. My wee brain was working faster than my fingers could keep up and I found myself jumping from one piece to the next, It was counter productive but I felt good about the build, the ideas were flowing fast and I could clearly envision the necessary steps needed to make it all work. It was a fun day at the worktable. Thank you everyone for taking the time to follow along. Keith
  2. Welcome to MSW. Glad to have you aboard.
  3. A screwdriver, a couple of monkey wrenches, some gasket material, and a can of black paint would have fixed anything. Thank you, Tom. Thank you, Eberhard. In the next photo I post I'll add one of the figures next to the engine to give a better sense of size. Thank you, Pat. How the engine turns out will be the deciding factor on how much visibility inside the shed there'll be. If it turns out well I may get some pointers from Gay, @FriedClams to help me add one oil lamp light inside the shed. Of course if you add lighting inside the shed I'd want to add a bench, tools etc etc. The shed would then become the focal point of the project and I think I want to avoid that. IMHO a equal blend would serve the model best. Thank you to everyone for the likes and for following along. Keith
  4. Same here because there's less chance of creating slack in the lines going from stern to bow, IMHO.
  5. These days poly is the only way to fly. The one caveat is poly stretches but you can pre stretch to avoid the issue.
  6. Ilhan, glad to see you back working on the Loreley. Lovey work as always.
  7. Thank you to everyone for the likes and for following along. Thank you, Glen. Thank you, Keith Thank you, Phil. Tom, thank you for having faith in these ole fingers. They're being tested on the Steam Donkey. Thank you, Gary. Thank you, Rick. Thank you, Brian. Today I started on the Donkey engine in earnest. As I mentioned in an earlier post the boiler is a bit oversized. I did so intentionally as the whole engine assembly needs to be oversized to give myself a legitimate chance of making the engine pieces. The frame rails are wider than the drawing to provide more glueing surface and measures 1.0 inches x 0.60 inches. I'm oversized approximately 0.15 inches in width and 0.30 in length. I got the frame, valve chest, cylinder, steam supply, and steam exhaust lines made today. The lines are 22 gauge brass wire, I'll leave the frame unpainted till the very end so as not to interfere with glueing. With the exception of the frame all the pieces need some attention; valve chest and cylinder both need to be cleaned up around where the wire is inserted and another coat of paint, the top of steam exhaust line needs to dressed and both lines need to be painted. This is a challenging/fun part of this build. It gets covered with the engine shed and depending on how well I do on the engine, either the shed doors will be wide open or just a crack. I attached the engine plan at the start of the log but have attached again here since we're at this stage of the build. It's pool league tomorrow so it'll be a couple of days before the next post. I want to thank each and everyone of you for inspiring me to put a shine on this ugly duck. Keith
  8. Amazing work on the fairleads and thank you Roel for the shift information and the fairlead comparisons. Your experience brings this build log to life.
  9. That turned out swell, Chris. No evidence of the issues encountered in post #49.
  10. Fantastic work, Andy. Showing photos of the build coupled with photos of the restoration provides easier comprehension of the task at hand.
  11. Bob, I can't believe how far you've gotten on this build in just 15 days and still have had time to do yard work. Have you given up sleeping? looking mighty peachy.
  12. Thank you to all for stopping by and the likes. Thank you very much, Eric. Thank you and jump in, Tom........... and Ribbit. The pile driver and barge are finished with the exception of weathering. The last eight pieces of the tower fought me tooth and nail but stubbornness won the day. The fairleads were the last bits added to the barge. The next three photos show the wear board/plate added at the base of the tower throat thus saving the barge hull from damage. Now that the driver and barge are done I can move on to the Steam Donkey and the engine shed. Lots of micro building from here on out. Thank you to everyone for your support and for being part of the journey. Keith
  13. Chris, I think it looks great. One side is going against the wall, who's gonna know?
  14. Tom, it's good to see you making headway. IMHO rigging the bowsprit is the toughest part of rigging a ship.
  15. Keith, my apologies. I thought we had clarified the bow issue in post #88 and #89.
  16. Thank you to everyone for the likes and for the kind comments. The driver and barge are now permanently attached. The card represents the 16x20 engine shed and is placed where the shed will be located. As I'm trying to represent an early 1880's pile driver the tower stays are rigged with rope and bullseyes. The bullseyes measure 2.77mm. The loose lumber at the bow will be my pastels test piece when I reach that stage. The only items left for the tower are the side braces and once they're completed I'll be able to start on the Donkey. Thank you to everyone for your support and for following along. Keith
