Everything posted by Keith Black
I can't wow and laugh at the same time, I'm emoji disfunctioninated.
- 235 replies
- Banshee II
- Bottle
Keith, ole Bob's found a job. Eric, the Tennessee is 1:120 and all the leftover bits from her build will fit the driver. Plus, 1:120 is real simple math of 1/10 inch = 1 foot. This will not be a stand alone model should I live long enough to complete the project. This floating pile driver is not self propelled so there will needs to be a paddle wheel tow barge at some point and if you have a pile driver and tow barge, well, you need a dock and if you have a dock you need a.........and on it goes. This will be my final hurrah.
Below gives a rough idea of where I'm headed with this. It'll be slow to develop but hopefully will pick up steam as we get into August. Old skid mounted pile driver. That was some tough ole hombres. Floating pile driver. This will be what I try to replicate. Pile driver drawing. HO scale pile driver kit model, pretty neat.
I've resisted starting another build log before the Tennessee was completed but a recent gift of assorted woods from fellow Michigander Dan Kimmer @Daniel Kimmer (thank you, Dan) has made resistance futile. The pile driver will be part of a larger project that I'll go into as this build nears completion. I can't wait to get started. The hull will be a solid waterline hull highly weathered and work beaten. Pile drivers have a special place in my heart having worked on and operating one (skid mounted) when working on the salmon cannery docks in Alaska. Pile drivers are loud and dangerous, preventive maintenance was always an afterthought. Climbing up to the Head Block (my Beach Gang foreman called it a Head Log) was done without a safety line. The Head Block sheave greasing and block inspection was only done at the beginning of the season. Personal experience.......when driving piling two men with peaveys would pry/hold the piling into the sled (Hairpin Lead, see terms below) to insure the pilling didn't kick away from the intended vertical path, this was the Hospital Side. The two men were hanging on with their toenails trying not to slip as the hammer rammed into the pilling. Footing was iffy because of flying sap being beaten out of the piling. Piling tops would often times splinter when the hammer hit and the two men holding the pile into the sled were unprotected and extremely vulnerable. The pilings were slippery, the skid was slippery and as the jarring blow of the hammer hitting could cause a man to loose his footing and be tossed off and forward into the water. Oh, I didn't mention that a skid pile driver is moved around the docks with block and tackle and to minimize drag tallow was smeared on the dock decking along the drivers intended path. Glossary of Piledriving and Foundation Construction Terms TERMS DEFINITIONS H-Beam See Steel H-Pile. H-Beam Lead See Spud Lead. H-Pile See Steel H-Pile. Hairpin Hammer A lightweight hammer, resembling a clothespin or hairpin, dropped by gravity to tap the pile down while setting the pile line. Also to tap sheets down that are hung up in the interlocks before reaching the template. Hairpin Lead A structure in which a pile hammer is mounted to adapt it to box leads with rails spaced wider than the hammer width. See Telescope Lead. Also called Pony Lead or Sled. Hairpin: A gravity hammer in the shape of an inverted "U" used without leads to start sheet piles into the ground. Sometimes called pants. Hammer Cage See Hairpin Lead, Offshore Lead. Hammer Cushion See Pile Cushion. Hammer Efficiency The ratio of kinetic energy of the ram immediately prior to impact divided by the rated energy. Hammer Energy See Energy, Impact; Energy, Rated. Hammer Grab A heavy tool used in breaking and removing obstructions in large diameter caissons or other excavations. Hammer Line The wire rope line of the crane assigned to raising and lowering the hammer. Hammer Speed The number of complete strokes of a pile hammer achieved by the ram per minute. Hammer Uplift See Cylinder Lift. Hand Spike A short slender pole used to position and hole a pile in the leads. Handling Holes Hole or holes located near the ends of each piece of sheet piling, and used to facilitate handling procedures during installation. Hanging Leads See Leads, Swinging. Hard-Bite Proprietary cast-steel driving tip with cutting "teeth" for H-piles. Hardpan 1. Most commonly a very dense heterogeneous mass of clay, sand and gravel of glacial drift of glacial origin. 2. The hard stratum of consolodated earth underlying surface soil, too hard for roots to penetrate. Hawser A very large soft line, 1 1/2" or larger in diameter used for towing or mooring. It is generally used to refer to all three strand right lay rope. Hay Donnage or timber used to stack rows or layers ofpiling, lumber, or other building materials. (aka Chocks) Head 1. Shortened form of the phrase pressure head, referring to the pressure resulting from a column of water or elevated supply of water. 2. The top of the pile. Head Block Top section of a fixed, semi-fixed or extended pile driver lead with sheaves for carrying lines holding pile and hammer over top of leads. Also called Cross Head, Sheave Head Assembly and Top Head. Heave 1. The uplifting of earth between or near piles, caused by the displacement of soil by pile driving. 2. The uplift of a previously driven pile caused by the driving of an adjacent pile. 3. The upward movement of soil and/or foundations supported on soil, caused by expansion occurring in the soil as a result of such factors as freezing and swlling due to increased water content or sulphite soils exposed to air. 4. Frost heave refers to the vertical soil movement which occurs in freezing temperatures as ive layers or lenses form within the freezing soila nd cause the soil mass to expand. See also Bottom Heave. Heaving The uplifting of the earth between or near pile, caused by soil displacement from driving piles, the uplift of an in place pile caused by the driving of an adjacent pile. Can also be caused by freezing and thawing. Helical Binders Mild steel rods spirally arranged about the main reinforcement steel to bind the latter to form a cage. Helical Shell Corrugated (usually 12 to 18 gauge) steel rolled into a sprial pipe with the joint crimped or welded watertight. The shell is installed as a pile with a mandrel. Helix Rebar bent to form a spiral shape. Used to reinforce concrete columns. Helmet See Drive cap, generally refers to cast steel component only. Hickey Bar A tool used for bending re-bar or conduit. High Chair A heavy wire device used to support and hold reinforcing steel in place in the form. Hiley Formula A dynamic pile driving formula for estimating the static load bearing capacity of a pile driven from its penetration resistance. It includes terms for pile weight to ram-weight ratio, pile rebound, and cushion properties. Hitch A knot that secures a rope to a post, ring, spar or rail, etc., or to another rope which takes no part in tying the knot. It won't keep its shape on its own. In climbers jargon, a "hitch" is often just a temporary fastening. Hoisting Engine A prime mover and a hoist with one or more drums mounted on a common sled base. Holding Bolts Used to connect wales or walers to pilings. Hollow-Stem Auger An earth auger with an end bit on a hollow center shaft. See Auger. Home, Pile A point at which a pile has reached specified soil penetration and/or blow count. HorsenSchitz What you say when you catch someone trying to use good ol' American traditions like home cooking and apple pie to sell products made in Germany. See also BullzenSchitz. Hospital Side A colloquial expression indicating the side of the pile driver which is the most dangerous. House The structure on a crane that covers the mechanical parts, motor, brakes, frictions, and drums. Also a term "let's head for the house" meaning "let's go home". Hydraulic Collapse The hydrostatic pressure in the ground (usually below a clay strata) which will cause the collapse of thin pile casing. Hydraulic Fill Earth fill moved and placed by pumping with water.
I think he wants to try getting a job on some kind of a barge? At least that's what he told me. I tried getting more details but he just stared at me with that wooden expression of his.
Tom@tmj, Rick@Rick310, Pat@BANYAN, Roel@Javelin, Keith@KeithAug, Gary @FriedClams, and Jay @Jay 1, thank you for your kind comments. Current work is painting the figures to be placed in those areas that will no longer be accessible once the main's main yard is in place and the brace lines run. Ole Bob' was recently found redundant with the addition of the Shapeways figures. I found a special place for him in my glassed bookcase as we fought a lot of sizing battles together over the years. I miss ole Bob. Thank you to all for the comments, the likes, and for following along. Keith
Ian, 0/15 is usually the smallest size available locally unless you have a dedicated bead shop in you area. Serious beaders don't normally buy beads at craft stores because of the quality and limited sizes. They buy from bead shops or online. Ask me how I know.
- 235 replies
- Banshee II
- Bottle
Rick, welcome to MSW. Glad to have you aboard.
Well, Bob, you found a place for the figure with the shovel. The King is looking fantastic.
- 87 replies
- King of the Mississippi
- Artesania Latina
Glen, 0/24 is the smallest seed bead size. You can still buy 24's from Japan but below is a link for antique Venetian beads. The Banshee is incredible. https://www.treefrogbeads.com/product/size-24-0-antique-micro-seed-beads-in-mohogany-brown/
- 235 replies
- Banshee II
- Bottle
Eric, I can see reworking the pitman arms but leave the opening as you have it. One photo in the early history of the Peerless doesn't mean that at some point the opening wasn't enlarged for ease of access and maintenance, exactly as you have it portrayed. I would think the structure on those old boats was pretty fluid.
- 393 replies
Very nice, Eric. She's looking every bit the part.
- 393 replies
She's looking fantastic, Bob.
- 87 replies
- Artesania Latina
Gunboat Philadelphia 1776 by tmj
Keith Black replied to tmj's topic in - Build logs for subjects built 1751 - 1800
Hey, it's got built-in dental floss. -
Questions about Artesania Latina HMS BOUNTY
Keith Black replied to felix nadeau's topic in Wood ship model kits
https://modelshipworld.com/search/?&q= bounty&quick=1&search_and_or=and&sortby=relevancy -
My very worst nightmare. I got the 6X glasses specifically to paint the figures but now I use them all the time when working on the Tennessee. The ole 2.75 reading glasses don't hack it anymore. The 6X work so well I'm considering buying a pair of 8X. Glen, great job on the shrouds and ratlines.
- 235 replies
- Banshee II
- Bottle
18th Century Iron nails
Keith Black replied to tmj's topic in Building, Framing, Planking and plating a ships hull and deck
Equals .047, rounded up. At 1:24 a fastener would be visible at arms length viewing distance but replicating a fastener head detail would be a tall order. I admire Tom's detail work on replicating caulking seams but that's a running length, not a single point. Tom, it'll be interesting seeing your solution.
