Keith Black
Everything posted by Keith Black
  1. Tim, welcome to MSW. Glad to have you aboard.
  2. Phez, welcome to MSW. Glad to have you aboard.
  3. Real silver wire might be good choice as it would be less noticeable in the sail edges. I've had some spools for over twenty years with no visible tarnishing.
  4. Ships from the world's Navies constructed during the transitional period of 1860 to 1900.
  5. Dave, welcome to MSW. Glad to have you aboard.
  6. Phil and Rick, thank you. That means a lot coming from the both of you. Thank you, Brian. I also like seeing string getting strung to places where once only imagination linked intersecting points. Thank you, Tom. The camera I'm using is a Canon EOS Rebel T3 with a standard lens. I get the best results using autofocus and flash. Thank you so very much for the likes, everyone. As I move forward with this project it's a comfort knowing you're there following along, generously lending your support. Keith
  7. Kevin, I had the same problem and eventually I had to use a smaller photo.
  8. I held the cordless with my left hand and jewelers files/ sandpaper in my right, free handing. Please poke around in my Tennessee build log, you'll find many of the examples shown of those listed in my first post.
  9. I don't have a lathe, I use a cordless drill. I've made mast, yards, gun barrels, support post, water buckets, flagpole, and cowl vents. I would love to own a lathe but the ole cordless works well and is invaluable.
  10. Kevin, welcome to MSW. Glad to have you aboard.
  11. Eric, I agree with the thoughts that coal sacks were stored alongside the boiler and dumped in front of the firebox as needed. The bumper/backstop (for lack of the correct term) used to stack the coal against for shoveling into the firebox could have been as simple as a 2x12 stood on edge running on the inside edge (facing the firebox) up against the two outside support columns. There could have been rotating clips attached to the support columns to keep the board from falling flat. When finished shoveling the board could be simply laid flat till needed again. This type of arrangement would not necessarily have been seen on any of the Peerless photos.
  12. JJ, Eberhard, Gary, Tom, and Rick, thank you for the kind comments and thank you to all for the likes. Fore's main yard brace line temporarily run to the block under the main's top. I'm pleased the model's skyline matches the above photo as well as it does. The existing outside single block became the fore's main yard brace line block. I had to add a single block for the fore's top yard brace line and it was quite the challenge. I had to drill a .034 inch hole into a .080 top support frame between the outside single block and the inside double block looking up at an awkward angle. The pen vice was up against the lines and I worried through the whole process that disaster would strike any moment. But it didn't and except for the wood crumbs it all went very well. And that concludes the inside work. Isn't it rich? That after all of this time I've developed the itch Where are the shrouds? Send in the shrouds That's right, it's time for the shrouds and I'm looking forward to adding them so much more so than I was a couple of months ago. Hopefully this will go quickly, I'll add progress post throughout the process. Thank you again to everyone for following along, stay warm. Keith
  13. Walter, welcome to MSW. Glad to have you aboard.
  14. James, welcome to MSW. Glad to have you aboard.
  15. JB, welcome back. i look forward to seeing you around.
  16. Greg, check out the below. These folks are out of New Zealand, their products are gorgeous and very pricey. The third link is their 1:72 boats which is as close to your 1:80 scale that they sell. Search through all the boats, you might find something that would work for you. i've not bought from them but I'm very tempted, let me know what you think. https://micromaster.co.nz https://micromaster.co.nz/collections/royal-navy-ships-boats https://micromaster.co.nz/collections/royal-navy-ships-boats/1-72-scale There's also Cornwall Model Boats in the UK. Very nice folks, I've ordered from them several times. https://www.cornwallmodelboats.co.uk/acatalog/aeronaut-liferafts.html
  17. If coal was brought aboard in sacks (seems the most likely case) there still needed to be a winged backstop from which the coal could be shoveled. A winged backstop would also help to contain the coal dust and grit to a limited degree.
  18. Congratulations, Scotty. Very nice build made even more so by the fact it's your first.
  19. Dare you try to match the bowsprit color to the mast color with stain? Looks like Golden Oak might work. Mast and bow work really looking nice.
  20. Eric, was coal the fuel of choice? If so where is the coal bunker located?
  21. Really neat work, Eric. I'm guessing the answer to you question is provided in the below? "Yes, there would be a safety valve atop the boiler and the venting pathway runs through a pipe that connects to the chimney. Steam for the engines draws off the top, there's usually a cylindrical drum up there, from which piping runs back to the engines at the rear of the vessel. Here's a view of the full machinery setup on my Arabia. You can see the steam drum, the piping to the engines, safety valves on both sides, and the vent pipe leading to the right side of the breeching."
