Posts posted by SardonicMeow
I've been spending a little while looking at your diagram. The only major issue I see is the foresail sheet. Perhaps you intended to assign that to the aft pinrails, but put it on the fore pinrails by mistake? Also, I don't see what a foresail halyard would do, as the foresail can be raised and lowered with the gaff peak / throat halyards.
Hi, Max. If you have discovered any new techniques in Fusion 360, please share.
As for including pictures, start a reply, then click on the "choose files" link at the bottom where it says "Drag files here to attach, or choose files..." Move your cursor into the position in your text where you want the image to appear, then click the plus sign on the image. For more help, look in the "How to use the MSW forum" forum.
Very interesting to see a different take with the painted hull, coppered bottom, and modified anchors. Thanks for sharing.
Here's a picture I took of the figurehead on the E. C. Collier. I love how yours captures the same feel and style of this and other skipjack figureheads I've seen.
- Ryland Craze, Matt D, schooner and 4 others
- 7
3 hours ago, aymodeler said:
I discovered a couple of mistakes that I made
Nope. The mistake is not yours, it's Artesania Latina's. You're finding flaws in the kit that every other builder also encounters.
I like your fix for the rudder. I think it'll look better than the correction I made to mine.
To my eye, your stem still looks a little low. You'll need the bowsprit at an angle such that a line from the end of the bowsprit running aft towards the bow will be able to go over the bow railing.
Yes, the horizontal lines are the waterlines. In the plans you posted, they are labelled F, G, H, and I in two of the three views. They are not labelled in the side view, but you can figure out which match the corresponding lines in the other drawings.
To make the vertices match up to the lines, you'll need to subdivide the plane object to get the right number of lines, then slide the lines up, down, left, or right to match up with the lines in the plans.
Ok. You're asking about the waterlines. On the plans that you posted, the waterlines are marked F, G, H, and I. These lines appear as straight lines on the first two pictures and are curved in the view from above.
In my procedure, I create a Blender plane and subdivide it so that it matches the way the lines are arranged on the plan. Here is the side view of the plans I used and below that the blender object. By subdividing it this way, there is a vertex at every intersection of each of the lines.
Here is another view of the same. Notice that at the beginning, the object is flat. The vertices will need to be pulled out into the hull shape.
Here is a similar view with the other plan image visible. Also, I have deleted some of the vertices that I know will be unused.
At this point, to follow the curve of a waterline, you have to go along each vertex of the waterline and move them one by one outwards to match the line on the plans. This picture is the view from above after a single waterline has been completed.
And here is the same from a different viewing angle. I have captured both a wireframe and solid view. You can see how the vertices for a single waterline have been pulled out to match the proper curve.
To complete the hull, it's just a matter of repeating the same procedure for all the other lines.
I hope that answers your question, but if not, let me know and I'll try to explain further.
Thank you for this, Phil. It's by far the best explanation of schooner rigging I've seen in one place.
I do have a question about the jib / fore staysail inhaul. Wouldn't the more common arrangement be a downhaul that starts at the peak, runs down the stay (either through the hanks or free) to a block at the bowsprit, then to the bow? That would allow the sail to be entirely hauled down to the bowsprit, which isn't possible with a line attached at the tack. In this arrangement, the tack would simply be attached by a hook at a fixed point at the bowsprit cap or traveler. Maybe there would be an inhaul for a flying jib, but a downhaul + hooked tack for a jib or fore staysail?
Welcome to Model Ship World! You're off to a great start. The trenails on your deck are particularly well done. I look forward to seeing your further progress.
All the lanyards have been tightened and the sheer poles have been added.
The next logical step is to run the ratlines.
Yes, the ratlines are definitely the next thing that should be done.
I have never done ratlines before.
I'm really intimidated by the ratlines.
An so, to avoid doing the ratlines, I worked on the boom and gaffs. First, of course, a few 3D printed parts.
The dowels for the boom and gaffs were cut and formed.
And all of it was glued together and painted black. Also pictured is the jib boom which I worked on a little while ago but haven't pictured here before.
- Roberto96, Matt D and GrandpaPhil
- 3
I haven't tried 3D printing blocks, but could give it a try. Now would be a good time, as I am actively avoiding the unpleasant task of tying ratlines on my Sultana.
I did try printing deadeyes, but did not take any pictures at the time. From what I recall, deadeyes of diameter 4.5mm and larger were acceptable, but attempts at smaller diameters were malformed.
Looking through my pictures, I did find the one below where I tried to produce grating. Left to right the hole size increases. Top to bottom the distance between holes increases. For the covers for the hatches on my Sultana, I used gratings with holes of 1.1mm per side and .7mm between holes.
Below is a picture of my Sultana, still in progress. As an experiment, I have been using 3D printing for as many parts as I can. Results have varied. Some parts are convincing, others suffer from the limitations of 3D printing with a consumer-level printer. There is a limit to the level of detail, and sharp edges are often impossible to achieve. And, of course, even when painted well, plastic can't match the texture and appearance of wood.
Anyway, look it over, try to spot what is 3D printed, and I'll list the 3D printed pieces below the image.
List of 3D printed parts:
White figurehead
Yellow quarterbadges
All the black railings, caprails, stanchions, hull trim, channels, catheads, etc.
Most items in red including the tiller, binnacle, hatches, pumps, windlass and bitts
Gratings on the hatches
Mast hoops
Mast cleats
Mast caps and bowsprit cap
Have a look at my build log for details of each specific part.
For the deadeyes on my Sultana, I used the very thin beading needles pictured below. These are by far the thinnest needles I have found. However, even though the needles are flexible, I could not use a full needle because the deadeyes are mounted so close to the hull. I get around this, I cut a needle short and bent it into a curve. The bent needle, much abused but still in one piece after threading 16 pairs of deadeyes, is also visible in the picture.
Right. The single thread at the beginning really just serves the purpose of holding the ropes together so a little CA glue can actually bond them. The crepe paper covers the glued spot, and both adds strength to the bond and adhesion, since it's saturated in the diluted glue. I have tugged at the seizing points and they are held together well enough to endure some abuse. At 1/64 scale (and probably 1/96, 1/128, etc.) it's an effective illusion of seizing and much easier than seizing with thread.
Here is the method I have been using for seizing. I think I found this in the build log of Jersey City Frankie's Niagara, though I am unable to find that build log anymore.
The procedure is as follows:
- Tie thin thread at the point where the ropes join and secure with a tiny drop of CA glue.
- Cut off the loose ends of the thread.
- Use a tiny drop of CA glue to attach a small strip of black crepe paper and wait for it to dry completely.
- Using a mixture of 50% white glue / 50% water, dampen the crepe paper strip and wrap it around the ropes.
There is a 3D printed solution to every problem. I was thinking about how to get the correct spacing of the deadeyes, and came up the with part pictured below.
Here are the spacers at work. (The upper deadeyes are oriented incorrectly in this picture, but were turned the right way later.)
All the deadeyes were seized to the shrouds following the method described above.
Now it's time to thread the lanyards.
The greatest challenge at this point is the small space between the lower deadeyes and the side of the hull. In order to fit the lanyard line through the lower deadeyes, I cut short a thin beading needle and bent it into a semicircle. The final state of the poor abused needle, after all the lanyards were threaded, can be seen below.
All the lanyards have been threaded but not yet tightened, so they are not yet in their final, properly spaced positions. But this is a good stopping point for this build log entry.
- WalrusGuy, GrandpaPhil, yvesvidal and 3 others
- 6
The ship's bell can be found on the back of the mainmast.
These cleats on the bulwarks are for the foremast running backstays. There is no way I will be able to reach them once the shrouds are in place, so I attached some line and left a length sufficient (I hope) to rig the backstays later.
Here is a picture of that particular cleat on the actual ship.
Finally the masts were glued in and the trestle trees on top of them. The mainmast trestle tree has a platform for the radar.
Here is the 3D design for the trestle tree.
Next time, the shrouds.
The anchors have been added. I'm mostly satisfied, but in hindsight, I feel that a thinner anchor cable would be better. (I used the .045 miniature rope as in the Sultana practicum.)
- GrandpaPhil, yvesvidal, Bossman and 1 other
- 4
I attached blocks and line for the tiller. This was my first time using the Syren 2mm blocks. Manipulating them and threading line through them was a big challenge. There are some other areas of the ship that call for these small blocks and I'm not looking forward to it.
The bowsprit cap was glued onto the end of the bowsprit. I attached one heart and two deadeyes for the bobstay and bowsprit shrouds respectively.
I have been happy with some of my 3D printed parts and disappointed by others. The 3D printed hearts have been one of the more successful ones.
I glued the bowsprit into place and tied on the gammoning.
Among the (many many) reference photos I have collected of the Sultana replica, the gammoning is sometimes white and sometimes black. I thought that black looked better.
Finally the bobstay and bowsprit shrouds were attached. The deadeyes hanging from the eyebolts on the wales will be used in the future for the jibboom guys.
- Roberto96, yvesvidal, Rik Thistle and 1 other
- 4
On 11/3/2020 at 12:45 PM, Matt D said:
Did your 3D printed bowsprit cap look much different than the kit version?
Here is a picture for comparison. I included one of my 3D printed mast caps too (which hasn't yet appeared in my build log). The major difference with the bowsprit cap is that mine has a parallelogram cross-section while the kit piece has a rectangular one.
Some work on the bowsprit and jibboom has been completed. Chocks were added to the bowsprit and sections were painted black where appropriate. The bowsprit cap was 3D printed and an eyebolt was added to hold a block for the jibstay outhaul.
Here are the pieces dry-fitted. It sure does look fragile.
- yvesvidal, Roberto96, GrandpaPhil and 1 other
- 4
I have been trying to think about what final details I can add to the model while it is still easy to do so. Once the shrouds and other rigging is in place, it will be much harder to fix anything on the deck.
I stropped several blocks and lashed them to eyebolts on the deck.
The bitts were designed in Fusion 360.
And the bitts were glued into place. I also created a piece to cover the area where the bowsprit disappears below the deck.
- yvesvidal, GrandpaPhil, Roberto96 and 1 other
- 4
On 10/25/2020 at 10:49 AM, yvesvidal said:
You should offer a special add-on kit to the Model Shipways kit, with all the parts printed in 3D. The original kit would benefit greatly, from these very nice improvements that you are adding to your model.
Thank you for following along, Yves. I am very proud of the 3D printed parts I'm making. At the same time, not always satisfied with the results due to the limitations of 3D printing, and I think others would feel the same. My 3D printer can only produce a certain level of detail, which is often inferior to what a wooden or molded plastic part could be. Even so, I would be happy to pass on any of my 3D model files to anyone who wants to use them.
HM Schooner Ballahoo by egkb - FINISHED - Caldercraft - 1:64 Scale - First Proper Wood Build
Thanks for clarifying, Eamonn. I think the right name for the sail you're describing is the fore staysail. Looking at your (really lovely) pictures of the Ballahoo in profile, there is a very short distance between the fore mast and fore stay, so I assumed there would be no fore staysail. But it's certainly possible.
As always, I look forward to seeing your progress.
