niwotwill
Everything posted by niwotwill
  1. I can't find more to say that hasn't been said by others, so add my comment to the list. Wonderful example of a build and log. Its a beautiful model you've made. I use your log as reference while I slowly build my Cheerful. Its like having a good book on how to build a scratch model of a British cutter. BROVO
  2. A lot of work but not much to show. Completed the chain plates and attachment to the channels. I kind of followed the instructions making the chainplates with the exception of soldering the joints rather than glue. First I made the deadeye strop using a time trued method of trail and error using jewelers ring pliers. Several tries and a 5mm diameter ring fit on the 3.5mm deadeye and when squeezed it created a loop with the correct amount between the deadeye and loop for the middle link. The 2.5mm deadeye was the same except a 4mm ring was needed. The middle link, eyebolt link, toe link, and preventer link were formed as described in the monograph forming the link squeezing the link finished link ready for soldering I was fortunate enough to use my soldering mat as the holes were the correct spacing of the different links. The strop links and toe links were soldered prior to assembly. To complete the chain plate the middle link was soldered after capturing the strop and toe links. Using silver solder allows the soldering of close proximity to previous joints due the solder that melts at different temperatures. High heat for the links and low heat for the joining middle link. With the links assembled I squeezed the deadeye in position The black is liver of sulfur residue that comes off after washing. All my work And like I said a lot of work not much to show On to rigging
  3. Well folks chapter 6 is officially done. Adding the fancy moulding added a lot to the visual of Cheerful. Its amazing how much a little finish will add to the overall image. Not much to explain just followed others logs and the monograph. The one thing that was problematic was scratching the fancy moulding out of AYC. Being soft wood my tool kept leaving fuzzy surfaces. I decided to you Boxwood as I have had excellent results with other fancy moulding. I had a sheet of 1/16" and ripped off 1/16" strips. Using the brass scraper to form the detail. When done with detail I applied a coat of WOP and when dry the Byrnes thickness sander was used to reduce the thickness to .025. I found it much easier to work with the thicker strip and thin it to the desired thickness. On to chapter 7
  4. Planking completed and a light coat of WOP. Next is the stern post after the WOP dries. While waiting I'll get the fancy pieces ready to be put on after the stern post. Port Side view Starboard Side view Bow view Stern view Oh yeh! I painted the counter while working on the planking. Followed Chucks helpful hints and thinned the paint and added many thin coats to get the even coverage. Red is somewhat translucent and when you have thick areas it becomes a darker red and doesn't seem to matter how many coats of paint. So using a 1/2" natural hair water color brush with slow even light coats worked to get an even color. Really glad the planing is finished and excited to get some details done and then on to the deck.
  5. Like your idea of wire to make the stirrups off the model using the third hands. I'll definitely be using that technique when I have to do mine. Will
  6. Thank you Steven great catch and very helpful. I'll add the block before going any further.
  7. Finished the lower band of strakes. This has been the first time I carefully lined off the frames before planking and I can't believe how well it worked. When I measured the "0" frame and divided the dimension by 10 the planks needed to be .2 instead of 3/16". On the advice of Chuck I ripped strips that were .2 wide. Interestingly enough at frame 16 the measurement was closer to 3/16". Instead of trimming each plank I left them at .2 and on the garboard strake the end was then a little larger that 1/8". It was easier for me to do it this way rather than fiddle around each plank to meet the lines which always have the line width to deal with. Lightly sanded and one coat of WOP On to the port side
  8. Thanks Glenn and all the others likes and comments. As to the top even with the counter, it is almost even but a little more careful sanding is required. When I get it where I'd like I'll start painting the counter. I asked Chuck for suggestions of how to get even color with the semitransparent red paint and have tested his suggestion of many coats of thinned paint with light sanding between coats using 400 grit paper.
  9. Very nice Andrew a job well thought out and executed. The results are amazing. A fellow modeler, I know, uses resistance soldering with outstanding results without burning the wood. Seeing his work I bought a system but am still learning how to use it on such small parts as I've only used silver soldering and the flame immediately burns the wood holding substrate. Your work is amazing.
  10. Very nicely done it makes me even more anxious to start my ECB which is sitting on the shelf so I can look at the box everyday. Great Job. 👏
  11. Square tuck completed and now ready to line off the lower 10 strakes. Building the frame for the square tuck was straight forward but the fiddlely little vertical pieces were another matter. First I tried to free form the curved end and when fit align the length to fit the opposite end. That piece has a slight curve and that was the issue. After many attempts there had to be another way. Being a straight line kind of thinker maybe a template would work, but how to make the template. To make a template I stretched a piece of painters tape across the port side tuck frames and using a new #11 blade cut the tape using the inside edge of the frame as a guide. Cut 5 pieces of wood and taped them together using the triangular shaped tape template. Tracing the outline left the pieces a little long for final shaping. System worked and was able to finish the square tuck. The coat of WOP made the joints more visible than I thought they would be but we'll see. I think I've become too critical of my planking lines and the transom and square tuck are about the same,
  12. love to watch your work and how I may use some of your techniques.
  13. Many thanks to everyone with likes and especially thanks to PRS, Chuck and Glenn for the very nice complements. Chapter 4 is finished I realized that I hadn't described how I taper the planks and file the mating edges. Somewhere I saw a board with a slot cut to hold strips during shaping. I took a piece of boxwood and with the table saw cut a slice slightly wider than the plank strips. After measuring and marking the strip it is set in the slot and using a sanding block with 150grip paper sanded to shape As you can see this plank is almost to the mark Another tip I learned from gbarlow was to sand an angle on the adjoining ends of planks to make tight straight butt joints. Thanks Glenn Starboard side completed with no sanding Both side done and lightly sanded Coat of WOP on both sides My planking has gotten much better and as Glenn has said I wish the boat had three sides. On to chapter 5 starting with the square tuck when the WOP dries.
  14. We're here wishing you the best. Please don't go off the recovery program. That will set you back and maybe have to start over. I've never had shoulder surgery but my wife has had to have both sides repaired and recovery is a long process.
  15. I like the work you're doing its coming along beautifully. I only wonder if the grey deck is not brown/grey enough. A couple photos of the Charles W. Morgan deck for reference. Deck when dry Deck wet from a rainy day I hope I'm not being to critical.
  16. Little update on planking. Finished to first 8 strakes on the starboard side. The lining was very helpful as this is my first one layer planking. Each plank was lightly sanded and the mating edge beveled prior to carefully marking each plank using the tick strips and then shaped the plank before bending. Taking the strip to the ship and finding the apex of where to max bend was located. The strip bending was done using Chucks method of a hot iron. The butt ends of each plank were finished using a razor saw and sanded with a bevel making tight fitting butt joints. Planking after light sanding with fine paper. After one light coat of WOP. For my first planking I'm very proud of the result. After WOP dries the port side will be started. I also put WOP on the counter as it will be painted. Reading gbarlows comments regarding painting over WOP made sense so why not follow as his work is beautiful.
  17. Andrew something to think about is scale verses actual. Meaning .016 band equates to a 1/2" thick steel band. So that being said I think .032 is way too thick. For the sake of accuracy its only a 2 hour drive to Mystic and ask maintenance crew on Emma. Just a thought. Its looking fantastic.
  18. With Glenns question No I haven't done a test between gesso frame and plank. I've glued other things on top of the gesso with no issues, but I'd better test. Thanks Glenn for your input very appreciated. I made a quick jig using the plywood frame that held the bulkheads. Did some sanding to mimic the faired frames. Painted the gesso and let it dry. Took a ALC 3/16" plank and cut 6 1" pieces and glued them to the test sample with medium CA glue the same as i use to plank After glue set I pulled on the 1" strips. The gesso held and the wood to wood broke free with about the same effort as I've experienced removing planks. Then while pinching one plank I was able to lift the panvise. I realize this is a simple test and is purely subjective but enough to make me comfortable. vise being lifted Feeling better I ripped 60 3/16" x .046 planks Before ripping the wood was surfaced down to .185 uniformly across the surface using the byrnes thickness sander. Doing this ensures that all the planks are the same width. a closeup to look at the grain pattern and these are directly off the saw no sanding or finishing done. I am very impressed with the wood purchase from Modelers Sawmill. Can't say enough about the quality of the wood, the price, and quick delivery from Canada to Arizona. I highly recommend them for you wood to rip.
  19. After studying my lining marks and reviewing many logs I decided to start the lining using a sharp pencil. First I painted the frames with white gesso to smooth the surface and create better contrast. Where I had marked bled through the gesso so it took three coats before getting coverage. Now looking a the frame surfaces the gesso has made them smoother and should be easier to line off the frames. Couple of photos with the gesso drying throughly before lining off. I plan on using a drafting lead holder with 2H lead and sharpening between frames. Start lining off tomorrow
  20. Started to line off hull and got midships to stern completed on port side. This is a lot of work especially when I first was using the fan printed on my printer was not to scale. Had to mark a new 3'16" and use this as the reference point. Taking my time so didn't get as much done as I'd hoped. Where the marks were too thick I think I'll paint white gesso on the bulkhead and redo them.
  21. Switched gears and started working on Cheerful Sunday. Today I finished the first two strakes including the drop plank. I took a 3/16" plank and using the bulkheads as reference marked the 5/64" end and where the taper starts. Placed the plank in a jig I'd made and tapered to my mark. Using a long plank allowed me to cut at appropriate lengths making a nice butt joint. Started making a pattern when I realized that it would be best to have the second strake in place to determine the end of the drop plank. After many patterns one was glued to the 3/64" thick wood. After the glue had cured it made it easy to use a new #ll and follow the pattern. Minor sanding was required to fit into the opening. Starboard done now on the port side where I used the same process for the pattern and drop plank. The process was fun and turned out nice. I haven't done any sanding yet I think I'll wait until I get the next 8 strakes in place before sanding. Now on to lining of the hull. I've never lined off a planking and for the matter this is the first single planking I've done. Reading the monograph, Chucks Winchelsea, and many logs I am ready to start. First I made a tick strip for the bulkhead 0 and out of curiosity I divided it by 18 and OMG. The tick strip was 3.375" and when divided by 18 the result you guessed it .1875 (3/16") No way I could be that good but both sides are the same. I feel better to start lining off the bulkheads.
  22. Chapter 17 is DONE. Making the masts and poles was a challenge to say the least. I made 5 fore top gallant poles before getting one that looked correct and didn't break. The masts are in place but not glued due to the holes make them very secure and stable. Early on I put blocks between the bulkheads along the frame for strength and giving planking something to grip. Since I had no way to accurately drill 5/16" holes a friend, a retired tool maker, had a large mill and volunteered to drill the for me. Using the plans he made a jig to hole the skeleton and drill the holes at the correct angle on the centerline. Now I place the masts 1" deep into these holes getting the required stability. Everything else was a matter of being very careful not to break something using judicial clamping during the tying of blocks. Top mast lift blocks Top mast jeer blocks, and sling Lift and stay blocks on top poles Completed ready for standing rigging I've enjoyed this step especially using James Lees book about the rigging. I'll continue to use the monograph, Lees, and the TFFM vol 4 to get the rigging accurate as possible given my experience. Thanks for all the likes
  23. Great fix and wonderful picture. You can never have too many clamps, elastic bands, and initiative overcoming obstacles. Great job Glenn.
  24. Lotta practice cutting. I'm not sure that the stand visually takes away from the great job you've done on Cheerful.
