Everything posted by CPDDET
#2 should work. You will find there is a lot of trial & error, experimentation and such with this hobby. Remember you can always take a few pieces of deck planking and try things before hand. I would think your model is a 1/64 scale and at that scale the caulking would be very, very narrow. So narrow that some believe it isn't necessary.
Charles W. Morgan
CPDDET replied to shortgrass's topic in Building, Framing, Planking and plating a ships hull and deck
Looking forward to following your build. Many years ago I re-read Moby Dick and became so interested in the whaling industry I made a trip to both the New Bedford and Nantucket whaling museums.That led to eventually to learning to sail and buying a 30 foot sloop. Sold the boat years ago and now learning to be a model shipwright. By the way, Moby Dick gives some very detailed descriptions of the waling ship, rigging and way of life. Dave -
I've used 3M sponge pads with success. They hold sandpaper well and easily conform to surface shapes.
Vallorbe files have served me well. Not cheap but good quality. I have escapement files from them as well as a cheaper mini file set from Husky. The escapement files are smaller than the mini files.
I see WEN is another make worth looking at.
Byrne's saw accessories question..
CPDDET replied to CPDDET's topic in Modeling tools and Workshop Equipment
That would cover just about anything I currently use. Would it handle 1/64 birch aircraft ply as well? Dave -
Thanks Bob! -
And what about saw blades for scratch building? Since the saw comes with a 24 tooth, 4 inch blade I thought I would stick with the 4inch size and order the 36 tooth as well as the 100 tooth slitting blade which is recommended for use with tilt table. Are 3inch blades really needed at all? Is a 36 tooth blade needed or will the 24 tooth suffice for all cutting? Obviously I have no experience / knowledge of saw blades. Dave -
Got my income tax refund and will be purchasing a Byrne's saw. Which accessories are worth purchasing with it? Dave
Thanks Patrick, will definitely look into this tool. I have a micro Dremel and wonder how it compares to your tool. Here are the Dremel specs DIMENSIONS Speed: 5,000-28,000 Charge Time: 3 Hours, 45 Minutes Warranty: Limited 2 Years Length: 8 " Battery Chemistry: Lithium Ion Battery: Lithium-Ion Battery Height: 1.5 " Material: High Density Plastic Battery Voltage (V): 8 Model Number: 8050-N/18 Width: 1.5 "
"Embossing Stylus Tool Set by Craft Smart®" Got mine at Michaels craft store. 3 piece set with 5 different size ball shaped ends. Very reasonable price wise.
- 389 replies
- bluenose
- model shipways
Thanks Patrick. Almost finished rebuilding the skylight window frames. Went a different route and they came out much nicer. Will post an update later this week. Dave
- 389 replies
- bluenose
- model shipways
Beautiful work. I'll remember that tip about the lines when I get to my rigging.
- 38 replies
- bluenose
- model shipways
